BORLA
Old 07-28-2013, 01:12 AM   #1
ffcars
Drives: 2013 Zl1 Convertible
Part no for Tonneau mounting bolt, nut, plastic sleeve?
I bought a windrestrictor and while installing it, the bolt would not come loose on the drives side and I striped out the allen bolt head. So I tried to loosen it from behind and the 10mm bolt striped too! So I used a wrench to install the windrestrictor but now I need these three parts to fix my car.
Anyone know the part numbers for bolt, plastic sleeve and nut for the 2013 convertibles?
I looked online with no luck.
Thanks in advance.
Bill
ffcars is offline   Reply With Quote
Old 07-28-2013, 08:11 AM   #2
RolltideSS
RolltideSS's Avatar
Drives: 2011 2SS/RS Vert
Gm parts direct sells them - if you email them and they can tell you. I don't remember off the top of my head
RolltideSS is offline   Reply With Quote
Old 07-28-2013, 10:36 AM   #3
hworth18
Jus' Cruzin
hworth18's Avatar
Drives: 2017 Camaro 1SS Krypton Green
My Chevy parts guy told me the mounting bolts were not available to buy separately from the cover so I had to come up with my own solution.
“The moment you think you know what’s going on in a women’s head, is the moment your goose is well and truly cooked”
-Howard Stark
hworth18 is offline   Reply With Quote
Old 07-28-2013, 01:42 PM   #4
skipinminn
Chiquita
Drives: 2013 1LE/1SS YELLO1LE 1 of Only 28
So much for buying that item :(
skipinminn is offline   Reply With Quote
Old 07-29-2013, 10:08 AM   #5
ffcars
Thanks. I'll go to the dealer to see what they say.
Old 07-29-2013, 11:32 PM   #6
Baba
Baba's Avatar
Drives: 2011 Camaro 2LT RS Convertible
I'm not able to locate the part # for the bolts but they're officially called
"tonneau cover retaining posts", according to the installation instructions which, Unfortunately, does not contain the part #, either.
Summit White
Black Leather
3 Pedals
Build Date: 06/27/2011
Purchased: 07/30/2011
Title Received: 08/15/2011
1984 Camaro (3rd Gen.): Traded: 1987
"Meet the new boss. Same as the old boss."
Baba is offline   Reply With Quote
Old 07-29-2013, 11:50 PM   #7
RolltideSS
RolltideSS's Avatar
This is the spacer - there is a link at the bottom for the bolt
http://www.shopchevyparts.com/servic...-92253907.html
Old 07-30-2013, 01:20 AM   #8
Baba
Baba's Avatar
The bolt looks as though it is the correct one, however, the description of the bolt is "Windscreen Boot Screw". That might be confused as being intended for the "windscreen", add-on accessory. Perhaps they use the same screw? I think you nailed it, though.
Here's the link to the Screw. See description below from the page Rolltide linked to.
http://www.shopchevyparts.com/servic...-92253906.html
"This 6-lobed screw is used to hold down the Camaro Windscreen Boot. This part is used with Spacer (Part Number 22770125) and two of each are required to secure the Camaro Windscreen Boot into place.
Please note that these parts (11561656 and 22770125) should be included with your Convertible Camaro in the glove box or mounted by the dealer during Pre-Delivery Inspection (PDI).
IMAGE SHOWS 11561656 and 22770125 TOGETHER - ONLY THE SCREW IS PROVIDED WHEN ORDERING THIS ITEM".
Summit White
Black Leather
3 Pedals
Old 07-30-2013, 09:15 AM   #9
ffcars
Perfect! Thank you!
Old 07-30-2013, 11:52 AM   #10
Baba
Baba's Avatar
Originally Posted by ffcars View Post
Perfect! Thank you!
You're welcome.
Teamwork!
Summit White
Black Leather
3 Pedals
Old 07-30-2013, 09:24 PM   #11
RolltideSS
RolltideSS's Avatar
Just throwing this out there to prevent any confusion and reassure the op - the windscreen from GM is spring loaded, it doesn't use a screw
Old 07-30-2013, 11:35 PM   #12
Baba
Baba's Avatar
How is the windscreen attached to the interior / back seats(?)? By "spring loaded", are you referring to its ability to fold down?
Summit White
Black Leather
3 Pedals
Old 08-01-2013, 07:36 AM   #13
RolltideSS
RolltideSS's Avatar
Nope - the gm wind screen has two posts that slide into holes on the side of the back seat to brace there and then two spring loaded posts that slide straight out into indentions in the side trim behind the front seat. I threw the instructions out so I don't have any pics.
Old 08-01-2013, 08:07 AM   #14
hworth18
Jus' Cruzin
hworth18's Avatar
RolltideSS is right, the "windscreen" mounts in the backseat with springloaded pins and has nothing to do with the tonneau.
Here's a pic of mine installed although you cant see the front.
-Howard Stark
