Emblempros
Old 07-28-2013, 08:47 AM   #1
19941LE
Drives: 1994 Camaro 1LE
Question Getting old gas out of the tank;94 1LE
1st post. Have a low mileage 94 1LE bought new. Car is a "trailer queen" and not used on the road. From time to time I start the car and everything is fine. Have added "stay fresh" additive to gas to preserve it.
I tried to syphone the tank but it does not work due to I believe sometype
of baffle in the tank. Can disconnet the fuel filter and then run the gas out of tank by running fuel pump w/o starting the car. Just want a few comments on the subject. Larry
19941LE is offline   Reply With Quote
Old 07-28-2013, 08:56 AM   #2
RBD
RBD's Avatar
Drives: 2013 SS/RS Convertible
Just screw on a length of hose to fuel pressure test port on the fuel rail, use a length of hose long enough to insert into a container. Pull the fuel pump relay and jumper across to
power up fuel pump. Run pump till tank is empty.
RBD is offline   Reply With Quote
Old 07-28-2013, 11:53 AM   #3
19941LE
RBD: Thanks much; sound simple enough; not sure where this "fuel test
port" is on the LT1. Is it on the Drivers or Pass. side of engine? Front or
back? Thanks-Larry
Old 07-30-2013, 01:00 PM   #4
19941LE
back? Thanks-Larry
OK; found the fuel test port on the rails. Does anybody know what type
of fitting I would need to hook a hose up to drain the tank?? Thanks in
advance.--Larry
Old 07-30-2013, 01:55 PM   #5
19941LE
OK; I think I found the answer. Have Kent Moore fuel rail adapter#J34730-75 coming to me. Hopefully it will hook
up and then I can drain the old gas. Larry --Any comments
are welcome
Old 09-19-2013, 10:54 AM   #6
19941LE
are welcome
Just a followup; tried the above and it work to perfection. Did not even
have to pull the core in the test port since the fuel came up (volume) at
a good clip. Thanks to RBD for the idea. It is very tight in there so patience is a must. Only problem I had was that the small alligator clip kept falling off the "pump test connector". I will start a new thread with
a question on this connector. Thanks--Larry
P.S. Put fresh 93 octane in and started right up and ran fine.
Old 09-20-2013, 01:15 AM   #7
MrCool
MrCool's Avatar
Drives: '95 Z28
1995 LT1 Z28, "Bright Teal Metallic", Stock
MrCool is offline   Reply With Quote
Old 09-20-2013, 07:48 AM   #8
19941LE
Originally Posted by MrCool View Post
MrCool: I agree with you 100% but where I was working on it I could
barely get my fingers in there; let alone a camara! BTW; the service
manual give all the illustrations on my project.-Larry
Old 09-20-2013, 11:05 PM   #9
MrCool
MrCool's Avatar
Drives: '95 Z28
Oh, that would make it a bit hard! Ha ha. How many miles are on this LT1?
Old 09-21-2013, 12:37 PM   #10
19941LE
MrCool; less then 1ooo Miles. Thanks for asking.--Larry
Old 09-21-2013, 12:56 PM   #11
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
Where are the pics of said '94 1LE?!?!?!? I want to see my cars Grandma.
Firefighter is offline   Reply With Quote
Old 09-22-2013, 08:14 AM   #12
19941LE
OK; here is what I came up with. It took a lot of reseach and help from
other discussion boards. FWIW: The connector shown in the picture is
Delco#PT242 GM#12101850 (Female) The Male counter part should be:
Delco#PT220 GM#12101828.(Although not tested and confirmed)
Thanks to all. Larry
P.S. Picture of the connector is on my other post.
