ADM PERFORMANCE
Old 07-29-2013, 11:23 PM   #15
JokerAce69
Drives: 2011 RS
Also wanted to add, once i'm done with the painting how long after until i can reinstall the covers? 24 hours?
JokerAce69 is offline   Reply With Quote
Old 07-30-2013, 06:55 AM   #16
etmx183
etmx183's Avatar
Drives: 2012 Camaro 2LT RS
CAI is from Cold Air Inductions you can by it direct from CAI.
About $400.00
http://www.coldairinductions.com/sto...FYuk4AodEj0AKg
etmx183 is offline   Reply With Quote
Old 07-30-2013, 06:56 AM   #17
etmx183
etmx183's Avatar
I waited 48 hours because of the humidity where I live, you should be OK after 24.
Old 07-30-2013, 08:03 AM   #18
CamaroIOM12
Jim
CamaroIOM12's Avatar
Drives: 2013 2SS Camaro Convertible
I guess the krylon fusion holds up to the heat?
CamaroIOM12 is offline   Reply With Quote
Old 07-30-2013, 01:02 PM   #19
etmx183
etmx183's Avatar
About 6 months so far, it's doing good.
Old 07-30-2013, 01:13 PM   #20
CamaroIOM12
Jim
Good to know. Buy the way your paint job looks killer!!!!
Old 07-30-2013, 03:13 PM   #21
Buschman
Buschman's Avatar
Drives: 2015 1SS 1LE
Did it "crack" like a spider web? If so that usually happens when you spray too heavy of a coat. Spray lighter coats next time, and I usually wait 30 minutes between coats and wipe with a tack cloth or microfiber towel lightly between coats.
2015 1SS 1LE
Stock...ish
Buschman is offline   Reply With Quote
Old 07-30-2013, 03:43 PM   #22
vong
vong's Avatar
Drives: Hazard Yellow Holden VE SV6
This is awesome mate. I want to do that to mine. How'd you go about it? Were the covers easy to remove?
vong is offline   Reply With Quote
Old 07-30-2013, 05:32 PM   #23
JokerAce69
Drives: 2011 RS
No i didn't crack like a spider web. The paint more-so just came apart from one spot while it dried and separated. Anyways, So far so good! After applying the adhesion promoter, I painted it again using the dupli-color and it looks awesome! 3 light coats of adhesion and 3 light coats of dupli-color. I did the fuse box first and now I'm going to do the engine cover.
Old 07-30-2013, 06:37 PM   #24
Ivan @ Southwest Speed
All y'all....use the Bulldog Adhesion Promotor on anything that expands, contracts, flexes that you plan on painting.
Cheap, you can get it in a spray can at just about anywhere, and it is an awesome primer.
We use it by the gallons here at SWS.
Ivan
Old 07-30-2013, 11:00 PM   #25
etmx183
etmx183's Avatar
Covers are very easy to remove about an hour to do both sides. Thanks everyone for the feedback on the photos.
Old 07-31-2013, 02:45 AM   #26
JokerAce69
Drives: 2011 RS
Yes covers are super easy to remove.. Heck there are tons of diy's but just might throw mine up.
Old 07-31-2013, 09:02 AM   #27
vong
vong's Avatar
Sweet, that'd be great mate.
Old 08-01-2013, 02:54 AM   #28
HP Turbine
Boosted
HP Turbine's Avatar
Drives: 2012 1LT RS... with snails
If you are there do the hoodliner too.
Such a sweet hood liner! I love it
IPS Twin Turbos, Corsa Exhaust, Ported Throttle Body. 461 rwhp 443 rwtq!! *Cameron Hass.ani*
HP Turbine is offline   Reply With Quote
