Old 07-29-2013, 09:45 AM   #1
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
Pedders drop link question.
If anyone has followed my other thread I just got done installing the zl1 rear sway bar conversion with the xa coilovers. I'm getting a clunking sound from the rear at low speed and minor bumps. I checked every bolt that connects to the lca and everything is torqued correctly. The only thing that I can think of is the drop links. You can't tighten them till there is weight on the wheels so I can't get a torque wrench on them. How do I know they are tight enough? I was wrenching on them and got to the point where I can hear the bushings rub hard up against the metal. Should I tighten until I can't turn anymore? They look fine with weight in wheels. Once the car is lifted the bar drops a bit and I can see the bolt a little. Is this normal. Help please.
ADM tuned 412HP/407RWTQ. Kooks 2" headers w/ cats, ADM race intake, Vmax TB, Pedders XA coilovers and ZL1 sways. 1le clone
ackeight is offline   Reply With Quote
Old 07-29-2013, 09:47 AM   #2
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
When the nut stops. Crank em down.
Old 07-29-2013, 10:20 AM   #3
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
Ok. I'll tighten the crap out of them. Haha. I'll get back to you in a few hrs. Thanks.
Old 07-29-2013, 11:31 AM   #4
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
Ok I tightened them up. Still hearing rattling. Grrr. I'm running out of ideas. Here are pics of them. Name:  ImageUploadedByTapatalk1375111870.065210.jpg
Size:  151.7 KBName:  ImageUploadedByTapatalk1375111899.193890.jpg
