ADM PERFORMANCE
Old 07-05-2009, 10:38 PM   #1
derin11
Drives: 2010 Camaro 1LT
Resonators and cats
Hey guys, recently dipped into my savings to Get some stuff done to my car.
Can anyone give me detailed info of where i can get some 2.25 in/out High Flow cats and resonators cheaply?
I need 2 of each correct?
derin11 is offline   Reply With Quote
Old 07-06-2009, 01:26 PM   #2
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
Four cats, two resonators.
You're probably not going to get the cats for cheap. Magnaflow makes some good ones for about 100 each.
As for the resonators, your best bet (at least in my opinion) is to go with some short cherry bomb glasspacks. These specifically - http://www.jegs.com/i/Cherry-Bomb/545/87521/10002/-1.
- X
2017 1LT/RS A8 Hyper Blue Metallic
Xanthos is offline   Reply With Quote
Old 07-06-2009, 02:42 PM   #3
derin11
i only see 2 cats, where are the others?
Old 07-06-2009, 02:42 PM   #4
derin11
ugg why are they red lol
Old 07-06-2009, 02:50 PM   #5
derin11
Please also proide me a link to the cats i need
Old 07-06-2009, 04:10 PM   #6
Xanthos
PWA Relapse
Xanthos's Avatar
Paint them black or aluminum colored if you don't like the red. Personally I don't mind it because its so far under the car that you probably won't ever see it anyway.
Not sure if they've made any direct fit cats yet, but theres always the universal ones. http://www.jegs.com/p/Magnaflow/Magn...80686/10002/-1
- X
Old 07-06-2009, 04:47 PM   #7
derin11
Thanks, 2 more things, 1. Will the cherry bombs alone make a difference in the sound?? And 2. I live in Cali so magna won't ship them here
P.s: what about test pipes instead of cats
Old 07-07-2009, 11:18 AM   #8
Xanthos
PWA Relapse
Xanthos's Avatar
Living in california, you'd probably be better off not touching the cats at all. Magnaflow makes OEM spec high-flow cats, but, as I said before, I don't know if they will have any out for the V6 in the near future.
The cherry bombs will resonate less than your stock resonators - meaning the net sound will be louder, and may have a bit of the pop and sputter that glasspacks are known for. It may also make the sound a slightly higher pitch, though that is unlikely and the difference would likely be negligible. You only notice a pitch change when you remove the resonators completely.
Also, it will affect the sound more at idle and decel than at WOT (volume, pitch, etc).
Test pipes would be far from legal in california.
- X
Project "Xanthos" blueprint. Xanthos Member Car Journals 63 03-17-2013 08:52 PM
