Old 07-29-2013, 11:26 PM   #15
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
To enjoy it for years to come...I coulda bought something to toast the tires for a lot less than the gen 5...with age comes wisdom...sonnyboy
hunter1660 is offline   Reply With Quote
Old 07-29-2013, 11:50 PM   #16
steelersgeek70
steelersgeek70's Avatar
Drives: 2011 Chevy Camaro 2SS/RS
Originally Posted by FaytalsCamaro View Post
That is quite the feat. Your tires must be bald as crap. That or the roads you drive on must be made of clouds
I personally changed over to all season performance tires. Nitto Motivo excellent grip for an all season tire and rated for 60k miles
I too switched to the Nitto Motivo! Love them, much better traction on wet pavement than the stock Pirellis. Less road noise as well!
steelersgeek70 is offline   Reply With Quote
Old 07-30-2013, 12:24 AM   #17
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
I have 31k on my OEM's and they are some hard miles. Tons of burnouts, dyno pulls and many track passes. I have a new full set going on this weekend. They hold up just fine in my book.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 07-30-2013, 12:33 AM   #18
SSeniorMoment
Drives: 2010 2SS RS L99 IOM
Rocking chairs last a long time too.
SSeniorMoment is offline   Reply With Quote
Old 07-30-2013, 06:04 AM   #19
snaphappy
snaphappy's Avatar
Drives: 2011 Camaro Convertible SS2/RS LS3
I got 26,000 on my backs before I replaced them. Fronts are still there at 29,000 but they might be going soon!
snaphappy is offline   Reply With Quote
Old 07-30-2013, 07:03 AM   #20
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Put a 3.91 rear end in and you will eat them even faster. Mine made 11K. Moved over to Vredstiens on the rear.
Scott@Bjorn3D is offline   Reply With Quote
Old 07-30-2013, 09:12 AM   #21
Runawayhacker
Runawayhacker's Avatar
Drives: 2012 Camaro 2SS
If your going for the most Tread Wear(more Life) then it has to have a larger UTOG:IE:
TREADWEAR: 220
TRACTION: AA
TEMPERATURE: A
Nitto Motivo = UTQG: 560 A A (All Season)
Nitto Invo = UTQG: 260 A A (Summer Only)
Gmax as-03 = UTQG: 480 A A (All Season)
Falken 452 = UTQG: 300 AA A (Summer Only)(Front Original Size Only)
Perilli P Zero = UTQG: 220 AA A (Summer Only)
Hankook Ventus V12 evo K110 = UTQG:280 AA A (Summer Only)
Goodyear Eagle GT = UTQG: 400 AA A (All Season)
Firestone Firehawk Wide Oval AS = UTQG: 400 A A (All Season)
Continental Extreme Contact DWS = UTQG: 540 A A (All Season)
BFGoodrich g-Force Sport COMP-2 = UTQG: 340 A A (Summer Only)
Cooper Zeon RS3-S = UTQG: 300 A A (Summer Only)
VREDESTEIN ULTRAC SESSANTA = UTQG: 280 AA A (Summer Only)
Here's a good site for description of tires:
http://www.discounttiredirect.com/di...010&vid=016070
More Info: Uniform Tire Quality Grading (UTQG) Uniform Tire Quality Grading is a relative comparison system. Tires are graded by manufacturers in three areas: treadwear, traction and temperature.
The treadwear grade is a comparative rating based on the wear of a tire when tested carefully under controlled conditions. For example, a tire graded 400 should have its useful tread last twice as long as a tire graded 200. Treadwear grades are only valid for comparisons within a manufacturer's product line.
Traction grades represent the tire's ability to stop on wet pavement as measured under controlled conditions on asphalt and concrete test surfaces. As of 1997, the traction grades from highest to lowest are "AA","A","B" and "C". The grades do not take into consideration the cornering or turning performance of a tire.
Temperature grades represent a tire's resistance to heat and its ability to dissipate heat when tested under controlled laboratory test conditions. The grades from highest to lowest are "A","B" and "C" . The grade "C" corresponds to the minimum performance required by federal safety standard.
WHAT IS TPMS?
http://www.discounttiredirect.com/di...ticlePopup.jsp
Example for shipping Nitto Motivo to Quebec:
http://www.discounttiredirect.com/di...rt/viewCart.do
I just saw this for the threads on our tires:
CHECK TIRES THREAD DEPTH
GREEN = 8/32 or Greater
YELLOW = 7/32 to 4/32
RED = 3/32 or Less
RickRay gave me this awesome list when I was asking around. I've only got 17k on my stock Pirelis and they are SO BALD. right now, my top pick for balance between price, longevity, and performance is the Goodyear Eagle GT. Any other input is welcome!
Runawayhacker is offline   Reply With Quote
Old 07-30-2013, 09:16 AM   #22
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
Originally Posted by TNblackSS View Post
I have toyos on my 2011 SS - very pleased with them
Robby
always had great tread life on my toyo's.
Old 07-30-2013, 09:19 AM   #23
DesertCamaro
DesertCamaro's Avatar
Drives: Fast
Also running Toyo Proxes. Pirelli's lasted barely 30K. Toyo's are nice, not as grippy or quiet but ride pretty good and are SUPPOSEDLY rated for 45K.
DesertCamaro is offline   Reply With Quote
Old 07-30-2013, 09:42 AM   #24
Curley4301
Curley4301's Avatar
Drives: 2011 2SS Summit White
OP, look in the proper section to good advice. It's conspicuously hidden in the WHEELS AND TIRE TALK section.[/QUOTE]
Duly noted.
Curley4301 is offline   Reply With Quote
Old 07-30-2013, 09:47 AM   #25
2SS 2011
2SS 2011's Avatar
Drives: 2011 Camaro 2SS/RS M6 Black
I have 16K Miles on my 2011 SS/M6
The fronts are fine.. The backs look like the bald head of the guy Benny Hill used to slap all the time(I was told that was his father).. Anyway.. I honestly can say with the exceptions of a few slides around corners etc.. I have never done any burnouts in this car. These tires are thumbs down the worst I have ever experienced. If someone gave me a free set of new P Zero's i would throw them off a cliff..
2SS 2011 is offline   Reply With Quote
Old 07-30-2013, 09:48 AM   #26
IrocJack
IrocJack's Avatar
Drives: 2010 2LT/RS RJT
20,000 almost on mine and they look fine.
IrocJack is offline   Reply With Quote
Old 07-30-2013, 04:18 PM   #27
RoachDad
Drives: 2010 Camaro SS/RS
Originally Posted by The Beard View Post
I don't think I have a boat load of choices when it's time for me to replace my 21" Pirelli tires
I worked very hard to replace my 21s and ended up just paying the 2100 for Pirellis. If you have a Discount Tire store near you, they will price match any tire you can buy. So if you get a price from Tire Rack, they will match it and they will add insurance and all the stuff like tire checks and rotations that come from them.
Also, you will have trouble finding a place that can change your tires because of the size and they can do it.
RoachDad is offline   Reply With Quote
Old 07-30-2013, 04:21 PM   #28
RoachDad
Not to argue, but I have actually taken my to a road track and was very hard on them and I had no issues. I got 30k out of them. I would think that something is wrong. However, for what they cost, I would not blame you for never getting them again.
I will note though that no matter the cost they are only rated for about 18k so at 16 you may just have worn them out. They are not high mileage tires at all.
