sjm autoprod
Old 10-23-2013, 08:21 PM   #29
ssmike
Missing Big Red
ssmike's Avatar
Drives: '13 Equinox CRT
I've read that the HPS pads fade bad but I don't recall seeing any negatives with the HP+.
Old 10-23-2013, 08:55 PM   #30
Orange Crush 1LE
Orange Crush 1LE's Avatar
Drives: 2013 SS 1LE
What sold me on the HP+ was that Ron Fellows School at Spring Mountain is running them in probably 20 Corvettes with good success. I also like that I can drive them on the street with low noise compared to a more aggressive pad. And because they're rotor friendly, I likely won't have to turn my rotors next time or worry about rotor wear, just swap the pads myself.
But if there are horror stories out there, I'd like to hear them. I've heard they can squeak, but I've yet to hear them squeak and they are certainly quieter than a full track pad.
Sold but not forgotten! Pedders Supercar Coilovers, 32mm rear sway bar,bushings; APR wing and splitter
Forged 416 road course stroker. 514 RWHP, 497 RW Ft-Lb
1 Camaro, 75 Vipers: http://www.camaro5.com/forums/showthread.php?t=393697
Buttonwillow Raceway: http://www.camaro5.com/forums/showthread.php?t=389086
Orange Crush 1LE is offline   Reply With Quote
Old 10-23-2013, 09:02 PM   #31
ssmike
Missing Big Red
ssmike's Avatar
Yea I'd like to hear any comments or experiences with them too! Maybe I'll start another thread asking about HP+ reviews.
Old 10-24-2013, 12:22 AM   #32
So Cal Camaro
So Cal Race Team
So Cal Camaro's Avatar
Drives: 2013 Camaro
My experience with HP+ pads were they squeeled constantly unless you were driving hard on the track...my Cobalt Friction pads only occasionally make noise on the street....
So Cal Camaro is offline   Reply With Quote
Old 10-24-2013, 12:53 AM   #33
Synner
Drives: not stock
HP+ were ok on shorter tracks but the faster I got the worse they got. Went DTC-30's and 6-pistons for now but will upgrade pads again when they wear out. Will be trying cobalt friction as well.
Old 10-24-2013, 01:00 AM   #34
So Cal Camaro
So Cal Race Team
Drives: 2013 Camaro
You'll love the Cobalt Friction pads...they work great!
Old 10-24-2013, 08:23 AM   #35
Rob@WretchedMS
Drives: His Wife Crazy
DAMN Tbone, i'm impressed, lol
Mike, i think you will be fine, just keep in mind when you are driving that if the brakes feel 'funny' at all it's time for a cool down lap or two. As you progress with things the Cobalt Friction Pads are very very good. I run the HP+ on the Street, and the Cobalt Friction at the Track, both with the DBA 5000/4000 Combo. This on the GTO with Brakes that are a lot smaller than your Camaro has on it.
Rob@WretchedMS is offline   Reply With Quote
Old 10-24-2013, 10:00 AM   #36
ssmike
Missing Big Red
ssmike's Avatar
Thanks Rob! How's the new shop working out?
Old 10-24-2013, 12:25 PM   #37
Orange Crush 1LE
Drives: 2013 SS 1LE
Thanks for the info. Next time I need to turn or replace my rotors, I'll try the Cobalt Friction pads. For now I'll stick with the HP+, as they work well on the tracks that I drive.
Old 10-24-2013, 03:39 PM   #38
Rob@WretchedMS
It's going very well actually, just need more Camaro's to work on, lol
Old 10-24-2013, 06:28 PM   #39
ssmike
Missing Big Red
ssmike's Avatar
Wish I lived closer! I'm doing a Pedders FE4 sway upgrade soon. I should be able to tackle it myself on jackstands and take it to a local shop for an alignment!
Old 10-24-2013, 07:17 PM   #40
td195f
td195f's Avatar
Drives: 2015 Z/28 #786
Mike,
Hawk HP+'s are the pads I had on at Watkins Glen that I ended up taking off after I got the meatball flag two mornings in a row for sparks from the front wheels. The Trackmasters mechanic and I both found no reason fort the sparks. No signs of rubbing at all. After the second time we decided it had to be the pads. I put the stock Brembo pads back on and my instructor and I thought there was no difference in braking. Some people felt that the temp range of the HP+ pads are not high enough for a 4000 pound car and the braking required with the speeds at Watkins Glen. I won't run them again.
2015 Z/28 #786 - Black
2004 Silverado 3500 Dually - D'Max - Suncoast - Banks - Edge - Custom Tune by D'Max Tuner / Spitzer '32 Bantam Altered Drag Car - Blown Alcohol 380 CI Small Block Chevy
td195f is offline   Reply With Quote
Old 10-24-2013, 07:35 PM   #41
White_SS/RS
White_SS/RS's Avatar
Drives: 14 1LE
Originally Posted by td195f View Post
...I put the stock Brembo pads back on and my instructor and I thought there was no difference in braking. Some people felt that the temp range of the HP+ pads are not high enough for a 4000 pound car and the braking required with the speeds at Watkins Glen. I won't run them again.
^^This is good to know. Im running the stock pads at the moment and they seem to perform ok for the track I run which has fast long straights similar to the Glen. My future plans are to use cobalt friction pads on Racing brake rotors.
LMS Engineering
White_SS/RS is offline   Reply With Quote
Old 10-24-2013, 08:49 PM   #42
toehead93
Drives: 2014 2SS/1LE
My HP+ pads with racing bake rotors up front were fine at the Daytona road course but one day at Sebring on the short course and they were toast. I started getting less stopping power in the second part of the 3rd session and at the end of the 4th session they went out, luckly as i was exiting the track. I will be looking to do a CTS-V upgrade which ironically I have for sale or Cobalt Friction pads for track days.
The HP+ plus pads stop much better than the stock pads and have geat initial bite, but IMO are better suited for autocross.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
