Cold Air Inductions
Old 07-30-2013, 12:55 PM   #1
camaropop
Drives: 2010 Camaro ss eforce
car stumbles when the road leans.
Coming into my small town the road leans a little in a 35mph zone and the car stumbles like it is going dead. It does it everyday no matter how much fuel is in the tank. Has anyone ran into this issue?
camaropop is offline   Reply With Quote
Old 07-30-2013, 01:34 PM   #2
Unreal
Drives: 2006 Z06
Tune, plugs, wires, etc. Could be a number of things. Need more info. Probably just the eforce tune.
Nick
Corvette Z06 -1200ish rwhp
Old 07-31-2013, 09:28 PM   #3
camaropop
tune meaning something to do with the traction control... maybe ...plugs... really? how?
Old 07-31-2013, 09:32 PM   #4
Unreal
Drives: 2006 Z06
No, computer calibration.
Nick
Old 08-01-2013, 02:24 PM   #5
camaropop
can someone please go into more detail on this please?
Old 08-02-2013, 05:35 AM   #6
dan0617
dan0617's Avatar
Drives: 2011 Inferno Orange SS Convertible
Nobody can go into any detail. If your car runs perfect and only does this when it leans just a little, it could be dozens of things causing it. Likely mechanical, might not have to do with the lean, but the slowing down. Pretty rare for the tilt to cause the problem. We don't know from your description.
What has been done to your car, what have you tried to fix it so far. If you don't know what tune is then you need to do a search on this forum, do some reading. Try some of the simple things like a loose plug wire, look for wires touching bare metal.
You might have to datalog your car and send the file to your tuner for him to see what is going on. If it is in the tune, he will fix it.
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. Tuned by Ted.
dan0617 is offline   Reply With Quote
Old 08-02-2013, 05:45 AM   #7
Motion427
Drives: 2010 2SS/RS Red Jewel L99
Are you touching the brakes at that certain location when you get to that location.?
You might have a bad wheel sensor when you apply the brakes.The ECM thinks that 1 of the wheels is locking up and the traction control or abs kicks in.
Kinda a strange problem that you have. Good luck.
Would need more info on what you have done.
If you have headers,check the 02 sensors to see if they are not grounded somewhere.When the car moves abit,it might be grounding out and will cause the car to stumble or stall.
Motion427 is offline   Reply With Quote
Old 08-02-2013, 12:50 PM   #8
jrpimp00
jrpimp00's Avatar
Drives: '10 Black/IOM Camaro SS/RS
Check for a vacuum leak. DO you have any lines tied to the body that could pull and expose a hole/leak
2010 Camaro 2SS/RS Black/IOM //// 1998 Pontiac Trans AM 819 RWHP @ 12 PSI (Turbo)
jrpimp00 is offline   Reply With Quote
Old 08-02-2013, 01:41 PM   #9
camaropop
I can't get a log to upload. Any tips?
Old 08-02-2013, 09:34 PM   #10
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Drives: 2010 LS3 2SS
Could be a UFO hot spot ..
Mchlgrrsn is offline   Reply With Quote
Old 08-02-2013, 11:35 PM   #11
camaropop
https://docs.google.com/file/d/0B9az...it?usp=sharinghttps://docs.google.com/file/d/0B9az...it?usp=sharing
Old 08-05-2013, 11:35 AM   #12
east TX Muscle cars
east TX Muscle cars's Avatar
Drives: 2x 05 Vettes/65'AC cobra/68 camaro
again like your other two threads this could just be a tune issue. i f your driving the same way every time you come into that spot it may just be a MAF table that needs to be adjusted. sounds like your tune really needs to be looked at with all the little issues you have. did you not have it tuned? or just a CANNED tune?
east TX Muscle cars is offline   Reply With Quote
