Jason 98 TA
Old 07-30-2013, 05:40 PM   #1
Matt @ FSP
Matt @ FSP's Avatar
Drives: 2011 Camaro SS
*Dyno & Vid* 2013 ZL1 - VMax CNC TB Results, Stock TB vs. CNC LSA vs. CNC LS3
2013 ZL1
9400 miles
Manual Transmission
Only mods are RotoFab CAI.
NO tuning, stock tune. Runs are all done consecutively, no cool down period besides 5 minutes or so to swap the TB's.
The stock TB was tested first, although it shows Run #3 that is just how I pulled the dyno results up.
Run 1 = VMax CNC LS3 TB
Run 2 = VMax CNC LSA TB
Run 3 = Stock TB
21rwhp/12rwtq gain over stock TB
Matt @ FSP is offline   Reply With Quote
Old 07-30-2013, 05:46 PM   #2
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Nice.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 07-30-2013, 06:17 PM   #3
hawk02
Coupe Newbie
hawk02's Avatar
Drives: 2017 Mosaic Black Metallic ZL1
I swapped out the stock TB for a Vmax CNC ported one a couple weeks ago. I thought it was the best bang for the buck mod so far. Your numbers confirm what I thought.
Surprised the LS3 TB didn't give the highest numbers. I assume the stock tune was the limiting factor?
Anyone looking for a little more oomph at the low end and significantly better throttle response might want to consider doing a ported TB swap. It's a cheap and easy mod that provides a nice little performance boost.
hawk02 is offline   Reply With Quote
Old 07-30-2013, 06:24 PM   #4
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
Nice, will have to put this on my list ...
Old 07-30-2013, 06:33 PM   #5
Modern07
Mid-Florida Camaro Club
Modern07's Avatar
Drives: 2013 ZL1 #2303
It's a 2013 Matt!
Still, NICE results!!
Now I can't wait to see what happens with the rest of the build!
Although I'm still not a fan of your tight Mustang Dyno and it's stingy numbers!
Modern07 is offline   Reply With Quote
Old 07-30-2013, 07:02 PM   #6
babigguy
babigguy's Avatar
Drives: 2017 ZL1, 2015 Z51 vette 2005 gto
ok if I am reading this right the lsa did better than the ls3????
babigguy is offline   Reply With Quote
Old 07-30-2013, 07:15 PM   #7
Matt @ FSP
Matt @ FSP's Avatar
Yes the LSA did better than the LS3.. For now..
Once we add the 10% OD pulley on bottom, the 2.50 upper pulley, pfadt headers, and the Alky Control FSP ZL1 methanol kit we will be re-testing both throttle bodies.. I think the LS3 may do better when we have more demand for intake airflow. We'll see.
Old 07-30-2013, 07:17 PM   #8
DrkPhx
DrkPhx's Avatar
Agreed. Didn't expect to see such high results but the improved throttle response alone is worth it imo, plus it's an easy cheap mod. Can't wait to dyno mine.
Old 07-30-2013, 07:30 PM   #9
Ivan @ Southwest Speed
Heheh. Secrets out. Well done Matty!
Old 07-30-2013, 07:31 PM   #10
white ZL1
Drives: none
Do the LSA and LS3 throttle body blades open up in the same direction?
And in which orientation was the LS3 tb mounted in this test?
white ZL1 is offline   Reply With Quote
Old 07-30-2013, 07:36 PM   #11
Matt @ FSP
Matt @ FSP's Avatar
LS3 TB has to go with the throttle controls on the "opposite" side from the LSA controls..
VMax took some great pictures of the installations so we'll have to get some pictures from them posted up. I'll grab pics of the LS3 TB installed tomorrow when I am at shop before we tear this down!
Old 07-30-2013, 07:39 PM   #12
white ZL1
Drives: none
Thanks Matt!
With it mounted in that orientation does that make the blade open in the opposite direction as the LSA tb and does it affect power?
Old 07-30-2013, 07:58 PM   #13
MMXI SS
MMXI SS's Avatar
Drives: 2013 VR ZL1
Awesome Matt. Thank for testing
How did the afr look with the Rotofab and the ported LSA throttle body?
MMXI SS is offline   Reply With Quote
Old 07-30-2013, 09:19 PM   #14
Silverguardrail
Silverguardrail's Avatar
Drives: 2012 ZL1 #1448
Is the VMax CNC LSA TB plug and PLAY ? i.e. No tune ? If so how much ?
Thanks..
2012 ZL1 SIM, MN6, B92, RTQ
ZL1 - the true definition of joy ride
Silverguardrail is offline   Reply With Quote
