Old 07-30-2013, 08:34 PM   #1
000montoya
000montoya's Avatar
Drives: 2014 RedRock 1LE
steering wheel shakey after new wheels
i just installed the zl1 wheels from factory reproductions. i had the tsw's and used the same tires but now the steering shakes alot going faster then 25mph. i did the install myself and balance and it was perfect. im thinking its the hub centering ring.. i used the same one that came with the tsw's. could that be the problem?
498RWHP 439RWTQ Instagram: jm_103
000montoya is offline   Reply With Quote
Old 07-30-2013, 08:47 PM   #2
joeybsyc
joeybsyc's Avatar
Drives: 2010 Aqua Blue Metallic 2SS
Why do you need the rings? Just looking to push the wheels out farther? I'd check to be sure all your wheel weights are still in place. I had a couple fall off my new SLP wheels while it was sitting in the garage. it seems the glue on some of the latest sticky weights doesn't stick too well. I'd take the rings out, if that doesn't cure your problem look at re-balancing the wheels.
joeybsyc is offline   Reply With Quote
Old 07-30-2013, 08:57 PM   #3
000montoya
000montoya's Avatar
i left the rings on cause i thought they needed it.
so its okay if im riding with no rings on or do i need different ones? and yes i checked the weights when i got home and theyre all good
Old 07-30-2013, 09:06 PM   #4
joeybsyc
joeybsyc's Avatar
I don't see why you'd need the rings... Anyone else I know that has bought those wheels bolted them up directly to the hub without issue.
Old 07-30-2013, 09:58 PM   #5
000montoya
000montoya's Avatar
oh okay ill try it without them. hopefully it fixes it. the wheels feel like they're going to fall off but thanks for the help!
Old 07-31-2013, 03:58 PM   #6
000montoya
000montoya's Avatar
took the centering rings off and fixed the problem
Old 07-31-2013, 05:41 PM   #7
Rudy@Tirerack
Rudy@Tirerack's Avatar
Drives: 1-800-428-8355 X4664
Correct! OE wheels do not need centering rings. Just most aftermarket ones do.
When ordering online please reference "Rudy/Camaro5" as your previous contact. Please click on the link in the sticky thread at the top of wheel and tire forum so the forum gets credit for the sale.
Rudy@Tirerack is offline   Reply With Quote
