Old 07-31-2013, 12:47 PM   #1
camaropop
Drives: 2010 Camaro ss eforce
flare when shifts to 3rd gear only the first time it shifts
How do i fix this? The first time it shifts to 3rd gear it flares. Has anyone else had this problem and what did you do to correct it?
camaropop is offline   Reply With Quote
Old 07-31-2013, 01:59 PM   #2
BLACK10
BLACK10's Avatar
Tune issue
Old 07-31-2013, 05:00 PM   #3
2SSCAMARO
2SSCAMARO's Avatar
Drives: 2010 Camaro Auto
The 2-3 clutches are often the ones to give out first. The 6L80 tranny is not very forgiving if tuned improperly. It may already be too late to reprogram the TCM. If you have flared the 2-3 shift several times, you will most likely have to have the tranny rebuilt.
2SSCAMARO is offline   Reply With Quote
Old 07-31-2013, 05:14 PM   #4
Motion427
Drives: 2010 2SS/RS Red Jewel L99
Have the fluid checked.These tranny's are picky with the transmission level.
Had 1 doing the same thing with a customers Camaro,it will only do it in the morning when it shifted in 3rd. It was low in fluid.Filled it up,and it cured it.
May not be your problem,but would be the first thing to check.
Motion427 is offline   Reply With Quote
Old 07-31-2013, 05:22 PM   #5
mike@newera
mike@newera's Avatar
Drives: 2016 Camaro SS
I have also seen low fluid cause this, as well as tuning.
mike@newera is offline   Reply With Quote
Old 07-31-2013, 05:53 PM   #6
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
And both of those can cause premature clutch wear!
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
http://www.gwatneyperformance.com/
ryan@gogwatney.com jzajac@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
Old 07-31-2013, 06:20 PM   #7
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
Mine started on the 3 to 4 shift down hill from there.
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
Old 08-03-2013, 12:47 AM   #8
camaropop
It has an external tranny cooler on it. Would it need some pressures turned up?
Old 08-03-2013, 10:45 PM   #9
dan0617
dan0617's Avatar
Drives: 2011 Inferno Orange SS Convertible
Jannetty turned up the pressure on mine and tuned alot of other things with it as well. So far it's holding up to 12psi and the occasional 125 shot.
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. Tuned by Ted.
dan0617 is offline   Reply With Quote
Old 08-03-2013, 11:46 PM   #10
drumsbh
Drives: 08' Pontiac G8 GT
I know with our 6L80 trans for the G8's which I believe is the same for you guys? We have a 3-4th shift flare the first time e turn the car on. After it gets into 4th the first time it works perfect after. So at the drag strip we do a manual burnout through 1-4th and roll out of the box in 4th and since then trans has seen 4th it's fine. We have been told it's a safety thing that GM implemented into our trans. We have a good thread about it on our Grrrr8 and g8board forums but I'm not sure if I'm allowed to link them here or not? It is NOT a tuning issue for us. Like I said, after it sees 4th once from a turn of the key it then works fine. Can you guys confirm on your camaros as well?
Sent from my EVO using Tapatalk 2
08' Pontiac G8 GT 11.32@121.66 Rock Falls Raceway 10-11-14 - Kooks 1 7/8 LT's - Kooks 3" X - Kooks Mufflers - Vararam CAI - HSRK - 160° T-Stat - UDP - 3.45 Camaro Diff - Rick Crawford Modified "Air Ram" Intake and TB - Tuned by Rick Crawford - Lunati Crawford Spec'd Cam - LS3 Heads Ported and Milled by Rick Crawford (G8-4-Speed) - Coan Stall
drumsbh is offline   Reply With Quote
Old 08-04-2013, 09:18 AM   #11
dan0617
dan0617's Avatar
I don't think mine does that.
Has your tuner set new parameters for your trans or are you running the stock trans settings?
Is your fluid level full plus a quart? I installed a Lokar dipstick and right to the full mark on it is 1qt over what you have if filled from GM.
Old 08-04-2013, 10:31 AM   #12
camaropop
Thats exactly what mine does
Old 08-05-2013, 12:32 PM   #13
east TX Muscle cars
east TX Muscle cars's Avatar
Drives: 2x 05 Vettes/65'AC cobra/68 camaro
thats in the tune unless you have damaged the 3-4 already. the 6l80, as stated, is VERY picky to the tuning and fluid levels.
east TX Muscle cars is offline   Reply With Quote
Old 08-06-2013, 01:20 AM   #14
LSX-80MM
Ghostly Unknown
LSX-80MM's Avatar
Drives: Silver Ice 2010 SS/RS A6
Trust me it's on it's way out.
TS416,GMPPLSX-LS3 6 Bolt Heads,Custom 80mmComp Turbo,ID850 Injectors, Lonnies Twin Pump Setup,Level 3 4L80E,DSS,3in Magnaflow Exhaust,CoolingMist Meth,RX Dual Catch Can,InnovateWB,Aeroforce Interceptor,AEM Truboost Controller,matte black CF5 Forgestars.700rwhp/712rwtrq
LSX-80MM is offline   Reply With Quote
