BORLA
Old 08-01-2013, 12:33 PM   #1
Ishin
Ishin's Avatar
Drives: 2012 Camaro 1LT RS
93 V6 engine shuts off
So I bought my son a 93 Camaro with 73k miles on it.
we have had it for about 3 months, but yesterday the car shut off on him in a drive thru getting food. He said he was able to restart it, it sounded rough, and I thought maybe a spark plug went bad. (i dont know, not a mechanic)
so we went to pick the car up the next day, and it cranked right up. but when he drives it, it randomly was shutting off.
The check gauges light comes on. Also he started to smell a burning smell after he drove it some. Like burning wire or something. The radio doesn't cut off when it cuts off. Just the engine.
Any ideas what this could be?
Picture below is where i saw smoke curling up.
Ishin is offline   Reply With Quote
Old 08-01-2013, 12:51 PM   #2
Ishin
Ishin's Avatar
Old 08-02-2013, 01:19 AM   #3
Ishin
Ishin's Avatar
so 63 views and no one has any idea....
Old 08-02-2013, 01:22 PM   #4
RonnieG
RonnieG's Avatar
Drives: 2013 AGM 1LE/2SS/RS
I look into threads just out of curiosity and i'd be in the same boat as you. i'm not a mechanic and i'd probably look for one.
only other suggestion is to maybe buy one of those code scanner thingies to check what codes it is throwing.
sorry I can't be of any real help
RonnieG is offline   Reply With Quote
Old 08-15-2013, 03:24 PM   #5
2SS 2011
2SS 2011's Avatar
Drives: 2011 Camaro 2SS/RS M6 Black
Looks like the distributor coil pack. Not sure if there is an ignition module in it around it or built into it but that may be your issue.. I have an 87 Ford Crown vic and the ignition module went and the car just stopped dead on the highway .. after a few mins i would wait and it would start but it had to be replaced ..
2SS 2011 is offline   Reply With Quote
Old 08-15-2013, 06:56 PM   #6
Zabo
Gunning for Sixth
Zabo's Avatar
Drives: '03 ZR2 Blazer
Could be this or it could be a short in the wiring harness. But being that the engine just dies but cranks (I'm assuming?) and runs rough I'm thinking that could be either an intermittent failure of the coil or old wiring. Sounds like a classic misfire until the burning wire smell.
I'd pull the plugs and check them for burns. Case seal on that coil probably got weak and started leaking.
Zabo is offline   Reply With Quote
Old 09-14-2013, 02:24 AM   #7
KING_DJ
Drives: 2014 RAM HEMI
Turn off your A/C and see if that helps. Seems strange, but it worked for me! My parents helped me with that. It was something related to my A/C.
KING_DJ is offline   Reply With Quote
