Old 07-06-2009, 11:43 AM   #1
SSouthernboy
Drives: 2010 CGM 2SS/RS
Jet Performance MAF Sensor - Thoughts??
I saw on ebay that Jet Performance has come out with a MAF sensor for the camaro ss. Are these safe to run, worth the money, is there any real benefits. Just wondering if anyone has had any experience with these. Thanks.
SSouthernboy is offline   Reply With Quote
Old 07-06-2009, 11:57 AM   #2
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
You are better off just using teh stock sensor, and tunign the car properly. That is the way it was on the 4th Gen, and I will keep with it on the 5th gen.
ZZcamaro is offline   Reply With Quote
Old 07-06-2009, 12:06 PM   #3
blackedout010
Drives: on order black 2010 2ss
save your money for something else!!
blackedout010 is offline   Reply With Quote
Old 07-06-2009, 01:42 PM   #4
KoTToN
KoTToN's Avatar
Drives: 2005 SilveradoSS AWD
not worth the money, your better off with a tornado fuel saver
Sales Forcasting 101A:
Originally Posted by returnofcc View Post
Like I said before, there is a dealership that is 4 miles away from my house that has 3 2SS's just sitting on their lot. And this is a very small dealership it's not a high volume dealership in a populated area., Come early summer, when 2011's are coming out, the camaro will be offered for 0%. I guarantee it
Sales Forcasting 101B:
apparently you didn't understand my post correctly. If there are 4 (now 6) camaros sitting at a low volume dealership, just imagine how many are sitting at the high volume dealerships
KoTToN is offline   Reply With Quote
Old 07-06-2009, 01:44 PM   #5
blackedout010
i hope thats a joke!!
Old 07-06-2009, 02:06 PM   #6
KoTToN
KoTToN's Avatar
its the best power adder ever invented! I heard those gt500 guys put one of these in with a pulley swap and they are able to lay down burning strips of rubber allowing them to get back to the future.
Old 07-06-2009, 02:07 PM   #7
blackedout010
:l aughabove:
Old 07-06-2009, 02:50 PM   #8
SSRider
SSRider's Avatar
Drives: Black 2SS RS M6
No, No and No
Black 2SS/RS M6
VIN# 2G1FT1EW4A9121666 (Bayed)
SSRider is offline   Reply With Quote
Old 07-17-2009, 08:59 PM   #9
Daddyo01545
New England C5 Member
Daddyo01545's Avatar
Drives: 2010 Camaro 2SS/RS
OK, OK...Well I am going to give it a try anyway...I will put it on a Dyno with the Stock and then the Jet MAF and see if it makes any difference. I got the Jet in preparation for a supercharger.
Daddyo01545 is offline   Reply With Quote
Old 07-17-2009, 09:05 PM   #10
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
that last sentance is why you should not mess with an aftermarket MAF.
on a purely stock application, you will probably see some added power from swapping mafs, but as you start adding modifications, aftermarket mafs become wasted paperweights. and they are a pain to tune with as well. stick with stock. it will handle the power
I piss excellence
and fart awesomeness
Old 07-17-2009, 09:15 PM   #11
Daddyo01545
Thanks for the feedback.
Old 07-17-2009, 10:28 PM   #12
CamaroSpike23
Truth Enforcer
no prob, just trying to keep people from wasting their money
I piss excellence
Old 07-18-2009, 11:18 AM   #13
domano 68
domano 68's Avatar
Drives: 2014 1LE
Is the MAF sensor the electrical connector that plugs into the air tube portion of the stock air intake on the LS3? Sorry for the ignorance here and apreciate the education.
domano 68 is offline   Reply With Quote
Old 07-18-2009, 03:08 PM   #14
CamaroSpike23
Truth Enforcer
the MAF (Mass AirFlow) sensor is inside the intake tube. mass airflow sensors use electrical current to measure airflow. The sensing element, which is either a platinum wire (hot wire) or nickel foil grid (hot film), is heated electrically to keep it a certain number of degrees hotter than the incoming air. In the case of hot film MAFs, the grid is heated to 75 degrees C. above incoming ambient air temperature. With the hot wire sensors, the wire is heated to 100 degrees C. above ambient temperature. As air flows past the sensing element, it cools the element and increases the current needed to keep the element hot. Because the cooling effect varies directly with the temperature, density and humidity of the incoming air, the amount of current needed to keep the element hot is directly proportional to the air "mass" entering the engine.
I piss excellence
Hawk Performance Brake Pad "Updated" KILLER74Z28 Suspension / Brakes / Chassis 34 05-04-2016 12:11 PM
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 89 02-20-2015 09:43 PM
SEMA Camaro: Yellow Camaro Concept Tran Camaro Photos | Spyshots | Video | Media Gallery 45 09-01-2011 03:19 PM
No More GM Performance Division... leviticus88 General Automotive + Other Cars Discussion 1 02-19-2009 04:04 PM
Hardcore racers rejoice!! GM Performance Parts to offer new Camaro body in white radz28 5th Gen Camaro SS LS LT General Discussions 23 12-22-2008 10:57 AM
