Gen5DIY
Old 08-01-2013, 09:44 PM   #1
Retro69
Retro69's Avatar
Drives: 2011 2SS M6 Synergy Green
Pull When Accelerating/Decelerating
The last time I was at the drag strip I noticed a pull to the right when I would back off the throttle at the end of a run. After having look underneath when I got home I found I had lost a rear sway bar bushing bracket so I was confident that that was the cause. I had the bracket replaced and an alignment done. Seemed all good but I still am getting a pull to the left under acceleration and then back to the right when I let off the throttle. Anyone had this happen? Any ideas?
Sent from my iPad using Tapatalk HD
480 rwhp ERL 416 ci with JDP Stage II Big Bore Cam
JDP tune, CAI intake, Dynatech LT headers, hi-flow cats
VMAX CNC Ported TB. GMPP Z/28 suspension package
Prothane sub-frame bushings.
Retro69 is offline   Reply With Quote
Old 08-01-2013, 10:17 PM   #2
RBD
RBD's Avatar
Drives: 2013 SS/RS Convertible
will do this if tire pressures are off from side to side
RBD is offline   Reply With Quote
Old 08-01-2013, 10:20 PM   #3
Retro69
Retro69's Avatar
Hrm... that was a thought but I just checked and the pressures are within one PSI of each other.
Old 08-01-2013, 10:31 PM   #4
SSMickey
SECC
SSMickey's Avatar
Drives: 2010 IBM 2SS
Sounds like something in your suspension is loose or broke causing an alignment shift as you accelerate or decelerate. Most likely in the front but maybe in the rear. I'd get it up on an alignment rack and check it out. I wouldn't use a lift that will let the suspension droop. It might mask the problem.
Vengeance Stage II Cam, Halltech CAI, RX Catch Can, Full ARH Exhaust, QTP Cutouts, Powerbond 25% Underdrive, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 08-02-2013, 07:26 AM   #5
heymatt
heymatt's Avatar
Drives: 2012 IBM 2SS Vert.
Headers clear the steering shaft?
LS3/M6 K&N, VMAX throttle body, RX Catch Can, skip shift eliminator, DT shorties and Solo HFC, DRL harness and 5K LED DRL, ZL1 rear sway, 1LE front sway
heymatt is offline   Reply With Quote
Old 08-02-2013, 10:29 AM   #6
Retro69
Retro69's Avatar
Yeah... don't see any indication they have been hitting the shaft.
Old 08-02-2013, 06:01 PM   #7
SSMickey
SECC
SSMickey's Avatar
I'm at a loss on this comment. I fail to see how a header tube rubbing the steering shaft can cause a car to pull. Care to explain your thought process?
You had a chance to put the car on a rack yet?
Old 08-02-2013, 07:49 PM   #8
Retro69
Retro69's Avatar
Not yet. I had it up on jackstands the other night but didn't see anything obvious. I think I need to get it up in the air with the suspension under load to get a better idea. (Dang... shoulda bought those Race Ramps)
Sent from my SCH-I545 using Tapatalk 4 Beta
Old 08-02-2013, 08:26 PM   #9
heymatt
heymatt's Avatar
If the header on the drivers side is touching the steering shaft. As the motor torques it will raise on the drivers side forcing the shaft to pivot away from the motor forcing the steering shaft to the left. When you let off the throtle the motor would return to a nuetral position, pulling the shaft down forcing a right pull. A broken motor mount could also factor in to this scenario.
Kind of at the outer limits of options but the OP is looking for suggestions.
Old 08-02-2013, 09:13 PM   #10
Retro69
Retro69's Avatar
At this point I'm happy to entertain all ideas
Old 08-03-2013, 11:29 AM   #11
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
sounds like a loose end link or something to me. or a bushing not in time.
my car does it a lil and always had. but its nothing bad the average person wouldnt know it.
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 08-05-2013, 12:44 PM   #12
Retro69
Retro69's Avatar
So I spent quite a bit of time yesterday checking everything out and can't find anything that looks like a problem. I rechecked all the bolts for tightness, pried and pulled on all the suspension arms, links, etc. Didn't find anything other than what I would expect as normal movement from the bushings. I'm beginning to wonder if I'm just now noticing the pull since I have added my cam, headers, etc earlier this spring. Maybe it has always been there but is more pronounced with the extra power.
There other thought is that perhaps I'm experiencing the toe rods and trailing arms flex/bushing movement. I wish it was in the budget and I'd upgrade them to see if that takes care of the problem.
The only other thing that is odd is I have worn my left rear tire out before the other three, by quite a bit. I'm down to the wear bars yet the right side is still 4/32-5/32" remaining. I'm obsessive about keeping the tire pressure at spec and I don't do a bunch of burnouts, even at the strip... just a quick couple of turns to clean 'em up.
I'm hoping the recent alignment is going to take care of the premature tire wear but I'm still bothered by the pulling.
Any other ideas? Similar experiences?
Old 08-06-2013, 06:30 PM   #13
Retro69
Retro69's Avatar
So I'm at Discount Tire getting my prematurely worn-out rear tire replaced. After driving it down here I'm still convinced there is something wrong. It is a very pronounce pull to the left under acceleration and a shift back to the right when I let off. Feels like I'm driving a front-wheel drive vehicle with torque steer.
I definitely cannot find what's causing this. Might have to take into someone with better equipment to figure this out. (Dang! I had having other people work on my car!)
Old 08-06-2013, 06:56 PM   #14
driyac
driyac's Avatar
Drives: 2012 45th Anniversary 2SS
Have you done pfadts "bushing timing" yet?
driyac is offline   Reply With Quote
