sjm autoprod
Old 08-03-2013, 01:39 AM   #15
Arodr395
Arodr395's Avatar
Drives: 2014 Black Camaro 2SS/RS 1LE
Originally Posted by 2013 1LE View Post
Will it throw off the speedometer?
Yes by 5 or 6 MPH's.
Arodr395 is offline   Reply With Quote
Old 08-03-2013, 01:47 AM   #16
Midnight Rat
Midnight Rat's Avatar
Drives: 2013 SS 1LE
That seems like a lot.
Midnight Rat is offline   Reply With Quote
Old 08-03-2013, 01:52 AM   #17
Arodr395
Arodr395's Avatar
That's what I was told by the people that work at the service department.
Old 08-03-2013, 02:03 AM   #18
Bauer2
Bauer2's Avatar
Drives: 2013 2SS/1LE and 2009 R1
At 60 the difference from 285/35 to 305/35 is about 1 mph faster with the 305. Who ever told you 5-6 is crazy lol.
Sent from the future!!
Bauer2 is offline   Reply With Quote
Old 08-03-2013, 06:16 AM   #19
Matster
Matster's Avatar
Drives: 2010 2SS/RS IOM/IOM #3625
Think the rubber compounds used in the tire and tread pattern have a lot to do with traction as well. After my build I had 305/35/20 P-Zero Ferrari and while it handle nice the traction was horrible, like grease pigs. I changed out to Nitto Invo's 315/35/20 and the difference in traction was night and day. The car has been lower 1.25" on all 4 corners and the tires fit without any issues although my rear rims are 11" wide.
666 EVIL RWHP BUILT AND TUNED BY SHIFTED PERCEPTIONS INC.(SPi)
416 Forged Stroker, E-Force Supercharger, Blower Cam, Rotofab CAI, Stainless Works 2" LT Headers and 3" Exhaust, LPE ZR1 Twin Disc Clutch, DSS 1400 HP Axles, Pfadt Performance Kit Stage 3.
Matster is offline   Reply With Quote
Old 08-03-2013, 06:38 AM   #20
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
I need a yes or no answer.
This is not a simple yes/no for a forum as I assure you know one here has done a back to back test with the exact same conditions.
Their are two many other variable that can affect your 1/4 mile time before the 285 or 305 would increase ot decrease your 1/4 time because of their negligible differences in size, weight and overall diameter. Everything from weather, surface prep, fuel volume, shift points etc can change the E/T.
For example. 15 gallons of gas weighs in the neighborhood (depending on ethanol content) 91lbs. 4 gallons, about 24 lbs. The 76lbs will make the car car slower, but wait a minute.....that is more weight over the rear wheels to aid in traction. The 76 lbs may help if the track surface is not prepped
Example 2. If you put two drivers in a the same car and one has 285 and the other has 305. The better driver will win a drag race everytime.
Bottom line. If you like the looks of the 305 and the coin to spend I would do it. But I would also spend more time learning to drive the car instead of worrying about the diff in tire size as seat time will far outweigh any 285/305 changes.
Matt
Old 08-03-2013, 09:10 AM   #21
willc1980
Drives: 2013 Camaro SS 1LE
if you road course it you can say hello to the problem the regular SS cars have....understeer
willc1980 is offline   Reply With Quote
Old 08-03-2013, 01:26 PM   #22
2cnd chance
Too Many Great Choices
2cnd chance's Avatar
Drives: Grand Sport/Z07
Wouldn't it show a slower mph on the gauge due to the fact of less revolutions?
Also wouldn't the taller tire effect gearing negatively for the 1/4 mile.
2cnd chance is offline   Reply With Quote
Old 08-03-2013, 02:53 PM   #23
Dropspeed
Dropspeed's Avatar
Yes to both.
Old 08-03-2013, 03:53 PM   #24
Bauer2
Bauer2's Avatar
Yes the gauge would be slower so when it reads 60 your actually doing a little over 61. Guess I didn't explain it that well sorry.
Old 08-03-2013, 04:34 PM   #25
Arodr395
Arodr395's Avatar
Originally Posted by Dropspeed View Post
Yes to both.
How would it effect gearing negatively in the 1/4 mile?
Old 08-03-2013, 04:47 PM   #26
2cnd chance
Taller tire less revs = taller final gearing and weaker launch.
Old 08-03-2013, 05:01 PM   #27
Bauer2
Bauer2's Avatar
I could be wrong but the difference in diameter is only about 1 mph diff at 60 so the change in gearing it's going to be negligible.
Old 08-03-2013, 05:05 PM   #28
Arodr395
Arodr395's Avatar
Seems like I shouldn't even bother going to 305's on the rear then .
