SDTW Custom Wheels & Tires
Old 08-09-2013, 02:10 PM   #15
Unreal
Drives: 2006 Z06
Upgrade to a quality oil pump and that won't be an issue. A lot of kits use really cheap ones. That being said, once the new pump works the turbo maybe fine. Turbo oil seals are like piston rings. They just don't blow out. You can push oil past them if they don't drain well but it just doesn't fail like a normal seal.
Nick
Corvette Z06 -1200ish rwhp
Old 08-09-2013, 04:34 PM   #16
Blk_SS
Drives: black on black 2SS/RS
^^ you have any recommendation on the oil pump?
Blk_SS is offline   Reply With Quote
Old 08-09-2013, 04:45 PM   #17
SRT10KLLR
Drives: 2010 Camaro 2SS/RS
If you fix the oil problem the turbo will function normally again.
Turbowerx Exa-Pump
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock
2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo
SRT10KLLR is offline   Reply With Quote
Old 08-09-2013, 04:48 PM   #18
Blk_SS
^^^ thanks you but my turbo was blowing out a lot of white smoke and the back bumper are cover with oil.... and this is right after it got rebuilt too, you guys think just replacing the pump will work??
Old 08-09-2013, 05:45 PM   #19
Unreal
Drives: 2006 Z06
Worth a try. Call AGP and get their setup. Comes with a pre pump filter and the best pump money can buy.
Yes, unless you drove it like that forever then it should clear up. It is just a metal ring with a gap, when oil doesn't drain oil goes through that gap. Once you get it draining it will clog up with carbon quickly like designed and return to normal.
Nick
Old 08-09-2013, 05:50 PM   #20
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
I would think sending the turbos to the OEM and having them go through them isn't too bad cost wise compared to going with a whole new kit... We've had mine in several times... Then use a quality pump... And make sure the orifices are properly sized while they are in for service...
Old 08-09-2013, 10:14 PM   #21
Blk_SS
what are the pump you running?
Old 08-09-2013, 10:54 PM   #22
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
The name slips my mind, but I'll find out and send you the info... We even pulled some shrapnel from it when I blew a turbo up at the mile and it keeps right on pumping...
Old 08-09-2013, 11:06 PM   #23
Blk_SS
^^ please PM me as soon as you find out the name that pump sound like a beast
Old 08-09-2013, 11:21 PM   #24
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
I just checked with my builders fabricator, it is the Turbowerx
http://turbowerx.com/Scavenge_Pumps/.../Exa-Pump.html
Old 08-09-2013, 11:36 PM   #25
Blk_SS
thanks im gonna order one tomorrow
Old 08-10-2013, 12:47 AM   #26
SRT10KLLR
The dyno shop(Haddad Motorsports) I went to pinched the oil return lines and when I went to pick up the car it was smoking like a Nascar car when the engine lets go. I replaced the lines and still had smoke coming out the tailpipe and there was even oil on the charge pipe. So I removed the pipes cleaned them and everything seemed good until I got on it and the smoke started again. Turns out the intercooler had about 2 quarts of oil in it too. So back to cleaning and finally everything went back to normal.
If I unplug the oil return pump even for 5 seconds smoke will start coming out the tailpipe. There is a lot of oil going to the turbos even though I installed a restrictor.
That is what I bought even though the kit came with one becaus I wanted the best. it's like dejavue
Old 08-10-2013, 10:29 AM   #27
Blk_SS
^^ can I ask where you guys order this pump from, the email link don't work and they don't have any contact information beside a fax number
Old 08-10-2013, 11:02 AM   #28
SRT10KLLR
I got it through a buddy who bought it through on of there dealers but you can get it from Ebay. http://stores.ebay.com/TurboWerx
