Old 08-03-2013, 06:00 PM   #1
Rcfiddy1
Rcfiddy1's Avatar
Drives: 2010 Rally Yellow 2SS/RS #37115
What else is needed?
I am going with a ECS supercharger kit and small blower cam. I already installed a zl1 fuel pump and ADM fpcm. Since ECS will be doing my cam/blower install, what other items will be needed to complete this install? I plan on having a ls3 conversion at same time.
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust.
Rcfiddy1 is offline   Reply With Quote
Old 08-03-2013, 07:03 PM   #2
injector
injector's Avatar
Drives: LS3
At this stage along with being with one of the top workshops , i would recommend you to work on your heads..
Texas Speed & Performance Custom Built Forged 408 CID, PRC LS3 260CC,Fast Intake & NW 102 TB, Alky Methanol kit, ID850, LPE Dual pumps,,Melling HV oil Pump. D1SC 10PSI, Stage 2 Air Intake,Magnaflow Axle back, Mcleod clutch, Pedders XA coilovers and sway bars, HD bushings, Hurst shifter, ACS bumper and hood ports, DSS aluminum drive shaft, CSF radiator .
injector is offline   Reply With Quote
Old 08-03-2013, 09:30 PM   #3
dan0617
dan0617's Avatar
Drives: 2011 Inferno Orange SS Convertible
I'd suggest the ID850 injectors. If your car is an auto, put in a stall converter. I went with the JRE 2800 and next time I have the trans out (if ever) im going up to a 3200 stall. Neither of these are "needed" but one adds a huge safety margin and the other adds a huge performance gain.
Datalog your fuel pressure after the build, you might want to add a MSD BAP if the pressure drops. Depending on the boost you run you might be at the upper limits of the fuel setup.
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. Tuned by Ted.
dan0617 is offline   Reply With Quote
Old 08-05-2013, 11:07 PM   #4
BLACK10
BLACK10's Avatar
Trans cooler!
