Old 08-04-2013, 11:59 AM   #1
camaropop
Drives: 2010 Camaro ss eforce
keep getting code 0556 brake booster
What would cause this code?
camaropop is offline   Reply With Quote
Old 08-04-2013, 12:19 PM   #2
epstein
Drives: SS/RS
Send a message via AIM to epstein
need more info what mods ...
epstein is offline   Reply With Quote
Old 08-04-2013, 12:35 PM   #3
Indyblue98
2012 RS 2ss
Drives: 2012 2SS RS L99 WhippleCharged
Had that code pop up once.
Used a SCT Scanner to Clear it off.
Has not come back yet.
When it happened I did a search of other posts ,,
result of the PD Blowers like the Whipple on my car.
Appears the blower can reduce the vacuum in the booster long enough for the sensor to set a code.
Did'nt appear to effect my cars braking , and has not hppened again.
2012 2SS RS Whipple-Corsa-RotoFab-ZL1 Diff 3.73 Pfadt ZL Stage 3 Suspension+KW V3 Coilovers
Indyblue98 is offline   Reply With Quote
Old 08-04-2013, 01:14 PM   #4
camaropop
eforce with 12lbs, built motor, meth seems to do it after i get down on it and thats pretty often LOL
Old 08-06-2013, 08:42 PM   #5
camaropop
160 ther
cai
eforce
cam and springs will have to get the specs
l99 complete delete
kooks 1 7/8 long tubes
3in kooks exhaust no cats
ported and polished to the max stock l99 heads
forged pistons
zl1 fuel pump
adm zl1 fuel pump control module
ls-9 injectors
methanol injection Not using it at all right now
rx catch can
KB boost a pump
aem wide band
yank 2800
taylor wires
tr-6 plugs
Old 08-06-2013, 09:39 PM   #6
Camper
Banned
Drives: 10' 2SS LS3 M6
Did you actually check your brake booster hoses?
Camper is offline   Reply With Quote
Old 08-10-2013, 12:58 PM   #7
camaropop
yea I looked at the hoses on the brake booster and they looked fine
Old 08-10-2013, 01:15 PM   #8
Camper
Banned
all hooked up on the back of the manifold? mine came off once somehow.
Old 08-11-2013, 09:09 AM   #9
ayousef
ayousef's Avatar
Drives: 2013 ZL1
It might not like being booster, I guess you could hook it up BEFORE the rotors yet AFTER the throttlebody.
That or use a 0psi check valve on the brake booster before the sensor.
1150bhp Whipple 4.0 Supercharged 427ci Camaro ZL1
ayousef is offline   Reply With Quote
Old 04-25-2016, 12:39 PM   #10
alfonso1740
Drives: 2012 chevrolet camaro bumblebee
I know this post is old but there is a little design flaw with the hose connected to the brake booster pressure sensor, if you follow the hose back you will find that it's touching a very hot surface on the hose making it almost melt and this is what made my light turn on, it only takes 1 hundredth of a millisecond to turn it on. So i placed high temperature resistant material around the hose to prevent this from happening again.
alfonso1740 is offline   Reply With Quote
Old 04-25-2016, 12:44 PM   #11
alfonso1740
There you go
