sjm autoprod
Old 08-04-2013, 04:10 PM   #1
TBailey
TBailey's Avatar
Drives: 2013 2SS / RS / 1LE
Nitrous backfire
Just wondering what causes a nitrous backfire??? I saw some pretty bad ones on YouTube, I got custom plate kit ordered from nitrous outlet I got all the bells and whistles with it cause I want to make sure it's top of the line and done correctly....bottom line I don't want a nitrous backfire happening to me, any tips or info will help.
ITS A WORK IN PROGRESS
SIMPLE QUICK RACING
TUNED BY DANIEL TIMMONS @ SQR
TBailey is offline   Reply With Quote
Old 08-04-2013, 04:39 PM   #2
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
Make sure it's hooked up correctly and both noids are working and its jetted correctly.
JLE58 is offline   Reply With Quote
Old 08-04-2013, 04:53 PM   #3
shiznight
Drives: 2010 camaro ss l99
havent heard of 5th gens having any real issues with backfiring
TSP vvt-1 cam, Headers-catless xpipe, Knn intake 417/422
Nitrous 100 wet shot 520/585
Racestar super 94 17x4.5/17x9.5
highest trap to date 120.6mph
12.0@spinfest. rage
shiznight is offline   Reply With Quote
Old 08-04-2013, 08:59 PM   #4
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Don't activate it below 3000 rpm.
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
http://www.gwatneyperformance.com/
ryan@gogwatney.com jzajac@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
Old 08-06-2013, 02:59 PM   #5
LeanPocket
Drives: 2010 2SS
Alot of times it happens when used at too low of a RPM.
LeanPocket is offline   Reply With Quote
Old 08-06-2013, 03:09 PM   #6
102SS
waiting at the tree
102SS's Avatar
Drives: SIM 2010 2SS/RS A6
Fuel puddling in a dry manifold is the usual culprit on our cars.
A leaking fuel solenoid can cause this.
2010 2SS/RS A6 DD K/N CAI
60ft 2.03 13.08 at 107.82 (4/28)
102SS is offline   Reply With Quote
Old 08-06-2013, 05:05 PM   #7
Brandon@NitrousOutlet
Drives: Fast!
Not having a window switch causes a lot of backfires. Spraying at too low of an rpm or tagging the rev limiter will usually do it. Another reason is the tune up not being right. Too much timing can cause detonation and a backfire.
Brandon@NitrousOutlet is offline   Reply With Quote
Old 08-06-2013, 10:08 PM   #8
dan0617
dan0617's Avatar
Drives: 2011 Inferno Orange SS Convertible
Too lean. The more you spray the lower the AFR needs to be. Alot of people don't do this and end up with a lean backfire on a fairly large shot.
Spraying at too low of an rpm.
Advancing the timing during dialing it in passes without rich ending the mix. If you run it and the AFR is good then you decide to add a couple degrees of timing back in, it will then be lean.
Bad intake design. Not really a concern for the LS based engines.
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. Tuned by Ted.
dan0617 is offline   Reply With Quote
