Old 08-04-2013, 04:12 PM   #1
12 ZL1 #1725
12 ZL1 #1725's Avatar
Drives: 2012 ZL1 Black 6M
Tire size question.... Stuffing a 335 under ZL1???
Would a 20 x 12 wheel with a Michelin 335/35-20 ps2 fit a ZL1 rear?? Specs say tire width would be 13.5 inch wide? And using a 20 x 11 wheel with a michelin 295/35-20 ps2 work in the front? Spec says tire would be 11.9 inch wide.. Stock rear width is 12.3 inch rear, 11.4 inch front??? If anyone has some knowledge of this would be GREATLY APPRECIATED!!!! Thanks in advance!!!!!
Sit Back and Enjoy The Ride!!
12 ZL1 #1725 is offline   Reply With Quote
Old 08-04-2013, 05:52 PM   #2
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
335s don't fit under our cars unless you are ok with them sticking outside of the fender and being shorter in OD than the stock setup. And that 295 Michelin is too wide for the front as well. 305/35/20 Michelin in the back, and 255/40/20 are the only way that those tires will work.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 08-04-2013, 05:57 PM   #3
cvp33
America FVCK Yeah!
cvp33's Avatar
Drives: 2012 CTS-V coupe
Someone on here is running 295 fronts with 315 rears.....Mich SS's. I'm running 285/315. They're right at the edge on the rears. 335's would take some changes to the offset and I'm not sure you have the room to tuck them under inside.
REDLINE
2016 Corvette Z06 3LZ
Callaway SC757
"I lived my life by one motto.......mottos are for losers" cvp33
cvp33 is offline   Reply With Quote
Old 08-04-2013, 06:03 PM   #4
2SS45th
2SS45th's Avatar
295s fit sure, but they stick out farther than the ZL1 fitment already does. If you're the kinda person that likes that then go for it. I personally like the wheels on my car to sit flush and no further outside.
Old 08-05-2013, 01:07 AM   #5
12 ZL1 #1725
I'm running 315 also right now in the rear and they're fine no issues... I'd love to squeeze the 335's though... Ty for the input.
Old 08-05-2013, 01:09 AM   #6
12 ZL1 #1725
The nitto's I have on now are 12.48 inches on an eleven inch rim.... So would be an inch difference between the two.
Old 08-05-2013, 12:01 PM   #7
2SS45th
2SS45th's Avatar
The Michelins run much wider than what the are sized at. A 295 Michelin is a touch wider than the 315 Nitto for instance.
Old 08-05-2013, 09:37 PM   #8
12 ZL1 #1725
Dam!
Old 08-05-2013, 09:57 PM   #9
2SS45th
2SS45th's Avatar
Originally Posted by 12 ZL1 #1725 View Post
Dam!
Yep, great tires though
Old 08-05-2013, 11:09 PM   #10
14pilot
Original Bumblebee Owner
14pilot's Avatar
Drives: 265hp ZX-14, 500hp Silverado, V-ROD
335's fit if you are ok with 1/4" - 1/2" of sidewall outside the fender lip. Although the tread would still be tucked under the lip. 12" wheel with roughly 50-51mm ET is "ballpark". YMMV... caution. Working with a wheel reseller is recommended.
Search around in this subforum. Their are decent pics of 335's on. BFGs, Contis and Pilot Super Sports can be viewed.
#5 - 2010 2SS/RS MN6 ABM #142-Silver Rallys-GFX / Med Titanium
My previous Camaros:
#4 - 1994 Z/28 6M Black over Arctic White / Graphite-Red Inserts - traded
#3 - 1981 Z/28 Bright Blue Metallic / Black - sold
#2 - 1970.5 RS Mulsanne Blue / Blue - endo crashed it and parted it out
#1 - 1967 RS Butternut Yellow w/ Black Bumblebee Stripe-RPO D91 / Parchment-Black - sold
14pilot is offline   Reply With Quote
