Old 08-04-2013, 03:18 PM   #1
edog
edog's Avatar
Drives: 2010 2SS/RS IOM
Strut tower brace needed?
I added hex vents to my ride. The four point BMR will not allow the drip pans to install due to height.
I am looking for another STB to replace, or modify the hex vent pans for this application. Any cool STB out there?
NOVI1500 ECS SC, 13lb boost, LS3 Conversion 113/225/238 COMP CAM, Pro Yank 3600, 1-3/4 Doug Thorley Tri-Y LT/HF cat, X-Pipe, Lingenfelter dual fuel pump, ATI super damper pulley, Ported TB, 160 therm, Tranny cooler, Pedders sways/end links/sub frame bushings, BMR trailing arms & toe rods, 1" Eibach Drop, 3.45 gears. 705HP/589TQ
edog is offline   Reply With Quote
Old 08-04-2013, 05:33 PM   #2
LS3 SS
LS3 SS's Avatar
Drives: 2010 Cyber Grey Camaro SS (LS3)
I have a two point BMR strut brace, and my splash trays fit just fine. I have P/N STB013 and had my vents installed at the fest this weekend.
GPI SS3 Cam / PRC 255 heads / Forged 376ci bottom / Fore level 2 fuel system / D1SC ProCharger on 12lbs / Alky control dual nozzle / 770 whp / 649 wtq tuned by Ryan Stevens at GPI
LS3 SS is offline   Reply With Quote
