08-04-2013, 06:44 PM | #1 |
Drives: 2013 Camaro 2LT/RS Join Date: Mar 2013
ZL1 bumper with Apex washer and scoop
I recently converted my front end to Zl1
Is there anyone using air dam and washer relocation with zl1 bumper. I know it wont fit anymore, but can we trim something and still make it work?? Or should i go back to stock washer bottle? |
08-04-2013, 08:30 PM | #2 |
Drives: 2013 2SS/RS dusk edition . Join Date: Sep 2011
I had it on my v6 with the zl1 bumper. I just trimmed the scoop back a couple inches and it worked fine. The opening was a little smaller with the zl1 bumper so I cut the scoop in the corner bend and I bent the side out to the middle More and it worked better . Good luck
08-04-2013, 08:34 PM | #3 |
4 inch elbow flex tube from lowes and some zip ties...5$
08-05-2013, 12:59 PM | #4 | |
I will try next weekend and will let you know...Thanks for the information |
09-27-2014, 02:02 PM | #5 |
Drives: 2011 Camaro 2SS/RS LS3 Join Date: Aug 2013
how did this work out?
2015 Silverado Z71 6.2/2011 Camaro 2SSRS LS3/2014 Cadillac ATS 2.0T
09-27-2014, 04:30 PM | #6 |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
It works fine, all you do is trim back the inlet scoop back a couple inches, then your set.
Thread Tools | |
