Caryle Racing
Old 08-04-2013, 08:41 PM   #1
Brownster
Drives: 1966 GTO Convertible/ZL1 Vert
Camber
I was told recently that the ZL1's camber was set for the track from the factory and that if you were not tracking the car it could be adjusted for daily driving and would extend tire life.
Has anyone confirmed this?
Thanks!
Brownster is offline   Reply With Quote
Old 08-04-2013, 09:00 PM   #2
cpc63
cpc63's Avatar
Drives: 2013 ZL1
Not the case for mine.
cpc63 is offline   Reply With Quote
Old 08-05-2013, 10:25 PM   #3
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
Somewhere is the charts with the specs but the zl1 only has like 1* of stock camber front and I thought a little less in the rear, we are running alot more and have relatively even tire ware
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's, Exhaust Commander, GTO Clutch reservoir, Forgestar CF5V 19's
SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Wichita Region SCCA #98
ICTsccaCamaro is offline   Reply With Quote
Old 08-06-2013, 01:27 PM   #4
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 10 Legacy 2.5GT, ...
Your best bet here is to actually measure what your car has. Don't count on any particular car being aligned dead-on to Chevy's preferred alignment specs (that's why there is a range of acceptable specs).
Thanks!
Again, this depends on what your own car has for alignment settings and how often and how much harder you take corners than Joe or Jill Average in their grocery-getter sedan. If your car is at factory preferred camber (middle of the range) or less negative than that, I doubt you'd gain much tire life unless you're a really mild driver doing mostly highway driving.
Norm
Norm Peterson is offline   Reply With Quote
