Old 08-05-2013, 10:28 AM   #1
NJ-JRS
C5
NJ-JRS's Avatar
Drives: 2012 2LT/RS Red accents on Black
Oil in throttle body and intake tube
Hi Guys,
Considering I have an RX catch can, what would cause oil buildup in my intake tubing and throttle body?
I swapped out throttle body's this weekend for a ported one (which I've noticed ZERO improvement with in terms of the dead spot and throttle response, but that's a whole other issue to deal with), and during the process I found somewhat-dirty oil in the oil body and intake tubing that I had to wipe down with a paper towel. I had gotten the catch can at pre-1000 miles before I even had the intake, but they're not directly in sequence with each other anyway so I'm not sure if that matters.
Is some oil buildup around there just natural, or could there be an issue that I need to insect?
Thanks!
NJ-JRS is offline   Reply With Quote
Old 08-05-2013, 10:35 AM   #2
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
Is it hooked up correctly?
Have you drained your catch can?
Have you done a top end cleaning to get the pre-1000 miles gunk out?
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 08-05-2013, 11:09 AM   #3
Kessler
Kessler's Avatar
Drives: 2012 IOM 2LT RS A6 w/ BA
You have a 2 oil lines to the intake, dirty(from the pcv to the intake manifold) and another (clean side) that's supposed to be negative pressure from driver side valve cover to intake tube. I was wondering if a second catch can is required...?
ToDones -
Apex Scoop & Washer Relocate - CAI cai - VMAX Ported Throttle-body -
Elite CC - Elite Clean Side Separator - MRT v1 Axle Back customized w/ J-Pipes -
Blacked Out Headlight/Tail Light Areas - Blacked Out BowTies - Blacked Out 'camaro'
Brake Light Chrome Bezel delete - Front Plate Relocate
JL Audio XD400/4 - Sub Thump Sub Box 2 10"s - DRL to Halos - Escort Redline
Gary's Customs ZL1 Front Bumper, ZL1 Rockers, & ZL1 Spoiler - Paint matched IOM
ToDos -
?Vitesse Throttle Response Controller?
Kessler is offline   Reply With Quote
Old 08-05-2013, 02:09 PM   #4
NJ-JRS
C5
NJ-JRS's Avatar
I have drained the catch can many times, but have not done any cleanings.
Though I can say it seems the oil is coming from the pipe that is fed directly into the intake tubing to the left of the tube connector piece (RotoFab setup if that helps). Does that help narrow down if there's something in particular I need to fix?
Here's an old pic from when I installed if that helps anyway unfamiliar with how the roto fab is set up.
Old 08-05-2013, 02:11 PM   #5
NJ-JRS
C5
NJ-JRS's Avatar
Actually I have used Tectron's fuel system cleaner once or twice if that's what you were referring to.
Old 08-05-2013, 02:17 PM   #6
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
More than likely the Oil is coming from the Clean side which is the tube that runs from the rear driver side valve cover to the intake. You could place another catch can on there but there are other options. You could install a breather and cap off both ends or you could do something like the 1LE separator.
I myself will be doing the 1LE separator which should be coming in this week (was told it will ship today). That i know of i will be the first V6 on the forum to install it so I guess we will see how it works out.
Proud owner of litho #179 Click Picture for Build Thread
Old 08-05-2013, 06:10 PM   #7
Buschman
Buschman's Avatar
Drives: 2015 1SS 1LE
Correct me if I am wrong, but you said you installed the catch can before the cold air intake right? If you did, you may have installed it wrong. In the picture you posted the line I circled should be cut and hooked to the catch can. You may want to check this out
2015 1SS 1LE
Stock...ish
Buschman is offline   Reply With Quote
Old 08-05-2013, 06:34 PM   #8
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 Camaro 2SS & 16 Suburban LT
This line that I colored red is where the oil is coming from. It is your breather. The fastest way to fix it is to get a oil breather cap and seal off that line.
I just did this and now no more oil in my intake.
I have had my car for a few months and I found this when taking the oil breather line off of my intake.
You can see the oil in this image:
http://i714.photobucket.com/albums/w...ps62b162c6.jpg
New breather cap:
I will note... this breather cap seemed to have some sort of pressure valve on it that caused my cap to make sucking noises. I ripped the pressure valve off the bottom of the new oil cap filter and it works like a champ.
Final layout
Sledgehammer70 is offline   Reply With Quote
Old 08-05-2013, 06:42 PM   #9
Buschman
Buschman's Avatar
The breather cap will help with the RX catch can, but I stand by my last post if he installed the catch can before the intake. The picture shows the intake installed and the line that should be coming from the catch can to the intake that should be cut and run to the can, it clearly is not.
2015 1SS 1LE
Stock...ish
Old 08-05-2013, 06:44 PM   #10
Sledgehammer70
Lethal Camaro
I agree with that point.
Can we see an image of your catch can install?
The RX Catch Can install should look something like this.
Old 08-05-2013, 08:24 PM   #11
NJ-JRS
C5
NJ-JRS's Avatar
Hi guys,
Its installed the correct way according to your pics and instructions. I'll take a pic later when I'm home to post and confirm.
But the oil seems to in fact be coming from the line sledgehammer highlighted above with the red line/arroe
Old 05-16-2014, 04:57 PM   #12
NJ-JRS
C5
NJ-JRS's Avatar
Hi Guys,
Hate to resurrect this old thread but I'm still having the issue of the clean line from my picture above (the one running vertical next to the oil cap) leaking oil into the intake tubing. My catch can is installed correctly as per the RX instructions, but from a few things I've heard some people have had this problem with this line leaking oil.
Does anyone know of a solution for this?
Thanks!
Old 05-16-2014, 05:03 PM   #13
intensifi
Drives: '12 2LT Convertible
Sounds like you are referring to the clean side.
For that you need a 1LE separator or Elite makes a separator now. I wrote a 1LE separator install DIY for the LFX. Find it and have a look.
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
intensifi is offline   Reply With Quote
Old 05-16-2014, 05:45 PM   #14
911medic
911medic's Avatar
Drives: 2012 SIM 2LT/1970 Camaro
^^^^ This.
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller
RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting
Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting
911medic is offline   Reply With Quote
