BeckyD@RodgersChevrolet
Old 08-05-2013, 12:07 PM   #1
Decepticon21
Decepticon21's Avatar
Drives: 2010 Camaro v6
Brakes and Rotors where is everyone going
Next on my list is brakes and rotors and I was curious what everyone Is running and where your all buying your stuff from if its online?
Decepticon21 is offline   Reply With Quote
Old 08-05-2013, 12:15 PM   #2
Team STILLEN
Team STILLEN's Avatar
Drives: Varies
I can take care of you for your brake needs.
Our Stillen One - piece Sport Rotors are a great choice for performance, durability and style when staying with OE factory calipers. These high-performance upgrades directly replace those plain OE factory rotors with no modification required. Applications for cars are finished with a tough clear zinc plating for exceptional corrosion resistance and to avoid the pad contamination.
We are also an authorized dealer for Hawk Brake Pads.
If you are going the Big route, we have our AP Racing Big Brake kit available too!
This is a Front 6 piston 2pc 16" rotor and a Rear 4 piston 2pc 15" rotor.
Let me know if you have any questions.
Thanks
JT
Team STILLEN is offline   Reply With Quote
Old 08-05-2013, 12:55 PM   #3
intensifi
Drives: '12 2LT Convertible
You can buy everything from the dealer (expensive) or go aftermarket on some components. I have bought stuff from Apex and am very happy with them.
I bought a set of take-off SS Brembos to install on my V6 from a member on Camaro5. The purchase included SS calipers, rotors, pads and brake lines.
Sleez has a thread on here where you can buy all new components to obtain SS brakes. It's a great deal if you want stock calipers with aftermarket rotors (DBA), pads, lines, etc.
http://www.camaro5.com/forums/showthread.php?t=302623
There is an ongoing debate about rotors. The issue is whether to stick with OEM (style) or get slotted and/or slotted & drilled.
There is also an ongoing debate about pads regarding noise & dust issues.
Everyone seems to be in favor of stainless steel brake lines though.
Good luck!
Mods: GM Locking Gas Cap, RS License Plate Frame
intensifi is offline   Reply With Quote
Old 08-05-2013, 02:03 PM   #4
The Stig
knows 2 facts about ducks
The Stig's Avatar
If you can swing it I highly recommend Racing Brake rotors, they're easily the best option on the market currently.
Click to view my build thread
Old 08-05-2013, 09:38 PM   #5
SPCBA
Drives: pleather and Chiclets
racing brake has a whole kit coming out. rotors, lines, fluids, pads, front calipers.
SPCBA is offline   Reply With Quote
Old 08-05-2013, 09:42 PM   #6
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
I went with CTSV calipers and ZL1 rotors with SS lines and hawk pads... I'm done with low dust pads... I'd rather clean my wheels every day than deal with crappy pads...
Carbotechs will be next.
Old 08-05-2013, 10:15 PM   #7
So Cal Camaro
So Cal Race Team
So Cal Camaro's Avatar
Drives: 2013 Camaro
You have the same set up as me, I like the Cobalt Friction pads and Castrol expensive as hell brake fluid...thanks Pete....LOL
So Cal Camaro is offline   Reply With Quote
Old 08-05-2013, 10:17 PM   #8
GTAHVIT
Blessed
GTAHVIT's Avatar
OH yeah... forgot about the bazillion dollar liquid gold I run for fluid now.
yeah, thanks Pete...
Old 08-05-2013, 10:27 PM   #9
TBone
Negative Camber Junkie
TBone's Avatar
Drives: 2010 1SS LS3/6MN ABM 1 of 23
What are your goals with the car?
Street, Strip, Autocross, Road Course??
Whatever your Goal, I like to deal with JDP Motorsports since they carry a wide range of brands and have a car they actually race and test with so they know what works in each situation.
T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same.
Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different.
I can't wait for my next
Track fix.
DA HAWKS OWN DA CUP!!!!!
TBone is offline   Reply With Quote
Old 08-05-2013, 10:40 PM   #10
toehead93
Drives: 2014 2SS/1LE
It's really going to depend on what you want to do with the car, street driven, track days, show car, etc. Then we can give some better advice, if you have a budget that will barrow it down some more. I personally am considering the CTS-V upgrade because I found a good deal for the kit.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 08-06-2013, 05:27 AM   #11
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Thanks!
Old 08-06-2013, 08:07 AM   #12
plumber84
Duke
plumber84's Avatar
Drives: 2011 2SS RS M6
If you're going to run it on the road course then the first thing is brake air ducts. Otherwise you will be going thru rotors quickly. Stock Brembros are fine but upgrade the pads according to your driving skills. Slotted rotors will be best. Stainless steel brake lines and hi temp fluid is a must. You notice a big increase in stopping power with less foot pressure on the brake pedal. The pads you use will determine how easy it will be to stop this 4000lb car.
I use cobalt friction XR1 front XR2 rear. They will squeal under light pedal pressure and wear fast but they stop the car from high speed to low effortlessly. They also will give you "pad knock". If it's your daily driver I would not recommend these pads.
Vararam CAI, BFE 1 7/8" headers, 3" X pipe w/cats, Pfadt phase 5 suspension, BMR tunnel brace & subframe connector, Hurst Shifter, SRP racing pedals, AP Racing RadiCal Big Brake Kit front, Cobalt Friction Brake Pads XR2 (F) XR3 (R), Goodridge SS Brake Lines, StopTech STR-660 Race Brake Fluid, Quantum Brake Cooling Ducts, ZL1 Rims 20"x10" (F) 20"x11" (R). Toyo R888 285-35-20/315-30-20, RX oil catch can, Dynomax Ultra Flo SS Axle-Back Exhaust, ECS dyno tune 422.3rwhp/422.9tq stock engine. ZL1 Aerodynamics. GM Dovetail Rear Spoiler. Z/28 Wicker Bill Z/28 Axels
plumber84 is offline   Reply With Quote
Old 08-06-2013, 09:43 AM   #13
GTAHVIT
Blessed
GTAHVIT's Avatar
Agreed. JDP will get you sorted out.
Old 08-06-2013, 09:44 AM   #14
GTAHVIT
Blessed
GTAHVIT's Avatar
T.
