Old 08-05-2013, 02:48 PM   #1
Orange Crush 1LE
Orange Crush 1LE's Avatar
Drives: 2013 SS 1LE
Anyone running 305/30-19 tires?
If so, what wheel sizes front and rear?
Is your car lowered, and if so with what set up?
Trying to see if the Z/28 set-up will work on the SS 1LE for my track tires and wheels. I'm thinking about running Toyo R888 305/30-19 on 19 x 11 front and 19 x 11.5 rear.
This set up would only be used to drive to/from the track, and at the track. I hope I won't need the Z/28 fender flares to do this. I've got the lower half of the car clear-bra'd to protect against rock chips already.
Pros and cons?
Thanks
Sold but not forgotten! Pedders Supercar Coilovers, 32mm rear sway bar,bushings; APR wing and splitter
Forged 416 road course stroker. 514 RWHP, 497 RW Ft-Lb
1 Camaro, 75 Vipers: http://www.camaro5.com/forums/showthread.php?t=393697
Buttonwillow Raceway: http://www.camaro5.com/forums/showthread.php?t=389086
Orange Crush 1LE is offline   Reply With Quote
Old 08-09-2013, 01:52 PM   #2
MPR
MPR's Avatar
Drives: 2013 Camaro ZL1
+1
or 19x11 front and rear with 305/30/19 R888. offset info anyone?
LSA VR38DETT 4B11 2ZZ-GE-SC N55 B18C5 302
MPR is offline   Reply With Quote
Old 08-09-2013, 03:18 PM   #3
Moreno Motorsports
Moreno Motorsports's Avatar
Drives: G5.R
Forgeline has done the most work to get the proper offsets for a 10.5" or 11" on the front and rear. here's a thread with tons of pictures of a member that is running 19x11's with 315/30/19's all around. Planning on running something similar.
Forgeline keeps the offsets secret, but I did some calculating on my own, concluding that you would need 25 offset or lower (with 10.5" wheels) to fit 305's in the front, and those will stick out a little. This is untested, so i am not positive. not sure if it would work with oem struts.. camber plates will help. This is backed up by the fact that a few members are running 285's on 10.5 +35. pushing those out another 10mm should give clearance for 305's
If you dont wanna or then just give Steve Schardt a call and buy a set of forgelines he has all the info ready to go.
Moreno Motorsports is offline   Reply With Quote
Old 08-09-2013, 03:30 PM   #4
Inferno LSX
Supercharged LSX
Inferno LSX's Avatar
Drives: 2011 2SS/RS Black/Carbon Fiber
Damn that sounds like a sweet set up.
Inferno LSX is offline   Reply With Quote
Old 08-09-2013, 04:24 PM   #5
Orange Crush 1LE
Drives: 2013 SS 1LE
Yes but he's running coilovers, some of which have additional clearance. Not sure if 315s will fit unless you spring for coilovers.
I did call Forgeline and the gentleman that I spoke with wasn't sure even if 19x10.5s with 305/30-19s would clear the stock suspension, let alone 19x11s. Pete from Pedders is looking into it, I'll report back when I hear anything.
