08-05-2013, 01:48 PM | #1 |
Emerald Coast Camaros
Drives: 2010 RS/SS Rally Yellow & 68 SS Join Date: Dec 2012
thinking about 3.70 gear
Ok am running the 4L80E trans shift point at 6600 rpm was trapping 5200 rpm with 3.27 put in a M6 rear with the 3.45 now trapping at 5400 rpm in 3rd gear. I would think i need to trap at 6000 are a little more. Maybe go with 3.70 to off set the high gear of the 4L80E? What do you track pro's think?
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135 AS OF 1/31/15 @ 633 RWHP=10.16@135 AS OF 1/29/16 @ 633 RWHP=10.10@136 TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF |
08-05-2013, 02:25 PM | #2 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
What does it run and what power does it make. And what is your goal?
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
08-05-2013, 03:20 PM | #3 |
With good temps high 10s @127 but in this heat low 11s @ 122. 585 rwhp right now would like more down the road but will need lots of $$$$. For now want to make the best of the HP that i have.
08-05-2013, 04:37 PM | #4 |
Drives: 2010 camaro ss Join Date: Nov 2012
Put 4.10s in the car if you want to make the most out of your setup and cross around peak power. 3.91s would be a compromise gear. 4L80 1st gear is a turd, you need rear gear to get the car going.
From 3.45/5400rpm 3.70 - 5788 rpm 3.91 - 6118 rpm 4.10s - 6372 rpm I cross ~135mph with 3.91s, and it isn't enough gear (car needs 4.10s) |
08-05-2013, 07:22 PM | #5 |
With the rpm you have there dose that takes in count with 3rd coming in sooner? am past the 1/8 when 3rd hit as of now.
08-05-2013, 07:39 PM | #6 | |
Quit being a pu$$y
Go woith the most gearing that will have you at the top of your rpms crossing the traps. That's why I went with 4.57s.
08-05-2013, 08:23 PM | #7 |
08-06-2013, 11:17 AM | #8 |
Writer
What size converter do you have mr nasty.
PROJECT HEAVY CHEVY
08-06-2013, 03:07 PM | #9 |
FTI 10.5 T/D 3000 stall
08-07-2013, 02:52 PM | #10 |
Writer
So how does it 60 now?
PROJECT HEAVY CHEVY
08-07-2013, 03:26 PM | #11 |
when temps are 80 and lower 1.51 to 1.61. Was at the track this pass saturday temps was 95 60' 1.65 to 1.72 the heat kills the supercharger.
08-07-2013, 03:28 PM | #12 |
Drives: 99 Camaro; 2010 Camaro 2SS/RS Join Date: Nov 2009
Nasty what's your combo? cam,boost and so on? any dyno #'s?
2018 Camaro SS A8 Edelbrock 2650 FBO 93 octane 9.54@144 Pump E 9.59@152
2010 Camaro Stock bottom end with 46,000+miles JRE remote tuning Whipple A6 and Drive it to and from the track 9.46@146 |
08-07-2013, 03:49 PM | #13 |
whipple with 12lb boost blower cam LT header forge bottom end stock head with studs. 585 rwhp 525 rwq. I feel like am leaving a better et time trapping at 5400 rpm with the 3.45 gears.
08-07-2013, 03:54 PM | #14 |
Writer
Where do you want to trap, like 6500 for example? Where does the combo start to die off?
60 is pretty good for the tire/converter + 2.48 first gear in the trans. Just hooks and goes?
PROJECT HEAVY CHEVY
Thread Tools | |
