sjm autoprod
Old 08-05-2013, 02:51 PM   #1
Srm1135
Drives: 2013 Camaro
Difference between lfx engine and llt
Can someone explain please
Srm1135 is offline   Reply With Quote
Old 08-05-2013, 02:55 PM   #2
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
couple of the biggest differences, is that the lfx has a composite intake manifold, where the llt has an aluminum intake manifold. also, the lfx has an integrated exhaust manifold, meaning you can't get aftermarket headers, whereas the llt, has the standard exhaust manifolds, and can be replaced with short or long tube headers. also, the ECU is different.
Old 08-05-2013, 03:00 PM   #3
Revrider550
Revrider550's Avatar
Drives: 2015 1SS/RS
One of the big things is that the heads and exhaust headers on the LFX are one piece which means no buying aftermarket headers for it. The LLT has the regular heads with separate exhaust headers. I believe the LLT was rated in 2010 at 306 horsepower but then in 2011 at 312? And then the LFX is rated at 323. Basically if you're a modder and want to put headers on your car try to get an LLT. Otherwise the LFX is the most power u can get from a V6 in a camaro
Revrider550 is offline   Reply With Quote
Old 08-05-2013, 03:37 PM   #4
Srm1135
Drives: 2013 Camaro
Thank you for the info. Too bad I can't put headers on my lfx. Oh well. But thanks for the quick response.
Old 08-05-2013, 03:47 PM   #5
911medic
911medic's Avatar
Drives: 2012 SIM 2LT/1970 Camaro
Here's another post with some more details: http://www.camaro5.com/forums/showthread.php?p=6307702.
The LLT came with a Bosch ECU which wasn't as tune-friendly as the Delphi unit the V8s got. The LFX got a Delphi ECU, and have been easier to tune. However, I've heard the 2013s had another change to the ECU, not sure exactly what, though.
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller
RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting
Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting
911medic is offline   Reply With Quote
Old 08-05-2013, 03:50 PM   #6
PoorMansCamaro
Drives: Really Slow
you don't need headers. put on a turbo/SC and nitrous that thing. lmao
Old 08-05-2013, 04:56 PM   #7
13blackLS
13blackLS's Avatar
Drives: 2013 camaro ls; 2005 rx8
What is better on the lfx that gives it more power? Is there a major difference in the heads? Aside from the exhaust manifolds? Possible to swap out heads?
13blackLS is offline   Reply With Quote
Old 08-05-2013, 10:20 PM   #8
911medic
911medic's Avatar
Look at the video in the link I posted above. They improved air flow through the engine and reduced weight.
There is a major difference in the heads, as the LFX integrates the exhaust manifold as part of the head. I don't think you'll be swapping them out.
I don't know why you'd want to.
Old 08-06-2013, 07:38 AM   #9
meissen
Founder - Michigan FBody
meissen's Avatar
Drives: 1994 Camaro LT1, 2016 Camaro LT
Yeah, you literally don't NEED headers on the LFX because your car comes STOCK with the HP benefit. Seriously, the consensus is that the LFX bottle neck is the muffler, not anything before it.
2016 Camaro 1LT V6 A8 - "Elmo" - LGX V6 with 8-Speed Automatic, NPP Dual Mode Exhaust
1994 Camaro LT1 A4 - "Red Alert" - v6-to-LT1 Swapped Cruiser; Cammed, Stalled, Enjoyed
"Gone But Not Forgotten"
2014 Camaro 1LT M6 - "Cherry Bomb"
2012 Camaro 1LS M6 - "Clifford"
Michigan FBody Association
http://www.mifbody.com/
meissen is offline   Reply With Quote
