HURST
Old 08-06-2013, 08:51 AM   #1
K32 Camaro
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6
Subframe bushing removal
I have some pfadt solid subframe bushings and the instructions say to take a sawzall and cut through the stock bushings. The aluminum center cuts easy but going through the rubber SUCKKSSS! It wraps around the blade and acts like brakes.
So my dad comes up with idea of taking a spade bit and drilling into the side and down. Soo much easier! Just wanted to share an idea from a wise man.
K32 Camaro is offline   Reply With Quote
Old 08-06-2013, 09:01 AM   #2
lakersftbl69
lakersftbl69's Avatar
Drives: 2010 camaro 1ss/rs
Thank you I should be installing mine this weekend
ordered dec 15 2008 picked up on june 8 2009.
upgrades kooks 1 3/4" LTH w/ deleted cats, corsa exhaust, Mm catch can, hurst short throw shifter stage 3 comp cam, 3.91 gears ecs kit blower, meth injection, upgraded axles, drive shaft, McLeod rxt clutch, 634rwhp 537 rwtq all installed and dyno tuned from slowhawk performance.
lakersftbl69 is offline   Reply With Quote
Old 08-06-2013, 11:08 AM   #3
K32 Camaro
V8 lounge member #5
We still had to sawzall the center aluminum piece and went about half way into the rubber. We didn't try and fight it if it was grabbing though. Just push the spade to the outer edge so it's just tapping the metal casing. There's no chance of cutting the subframe when doing it this way also.
Old 08-06-2013, 01:40 PM   #4
lakersftbl69
Thank you
Old 08-06-2013, 02:28 PM   #5
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
I just put a socket on the alignment post and used a propane torch and heated up the metal around the bushings to melt the glue holding them in. then jacked up the cradle into the socket and let the weight of the car press them out took about 3 mins each bushing.
LS3, JRE Smooth Idle cam, CAI Inc, ARH 1 7/8, Corsa, MSD Wires, MGW Shifter, Street slayer clutch, Tick braided clutch line & speed bleeder, DSS 1000hp ds & 1400hp axles, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Spohn lcas, Whipple, LPE dual fuel pumps, Rx catch can, Id850s, Powerhaus Performance tuned.
BigMatt is offline   Reply With Quote
Old 08-06-2013, 05:30 PM   #6
429
Drives: 2010 camaro ss
goes through rubber like butter with cutting fluid or wd-40, which you should have been using anyway.
429 is offline   Reply With Quote
Old 08-06-2013, 09:24 PM   #7
danvillekidd
2013 ZL1
danvillekidd's Avatar
Drives: 2013 ZL1 m6
Did the same thing on my SS. Works great, especially when you don't have a sawzall.
danvillekidd is offline   Reply With Quote
Old 08-07-2013, 11:51 AM   #8
BMR Sales
BMR Sales's Avatar
Drives: Race Car
The sawzall/reciprocating saw method is what most of our customers do because it is generally pretty quick and easy to do. I have had some customers use a torch to heat them up to help get them out but a lot of guys are hesitant to go this route. Either way works so just go with whatever option you are the most comfortable with.
T.C. Davis
tc@bmrsuspension.com
813-986-9302
Old 08-07-2013, 02:08 PM   #9
Rob@WretchedMS
Drives: His Wife Crazy
I highly advise against the sawzall, one slip and you are cutting in to your subframe.
Use the propane torch, place a socket between the bush and body, and jack up the subframe as you heat the bushing, once the fiberglass reaches a high enough temp it will melt and drop a bit of goo, and poof, the bushing will slide right out.
Rob@WretchedMS is offline   Reply With Quote
Old 08-23-2013, 09:45 AM   #10
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
Got PVC?
http://www.camaro5.com/forums/showthread.php?t=289431
jeremywes is offline   Reply With Quote
Old 09-04-2015, 12:36 AM   #11
camarosspower
camarosspower's Avatar
I'm bringing this thread back to life as I'm thinking about doing this myself in the next couple ofmonths. I'd like more info on the heat way with the 1" socket on top. Looks real easy that way
camarosspower is offline   Reply With Quote
Old 09-08-2015, 03:49 AM   #12
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
Use the Heat Method. Not if's and's or but's about it. Good luck
PerformanceHeartbeat Supercharger -BTR Stage 3 PD Cam -BTR Supporting Mods -CHE Rocker Arms -Roto-Fab Cold Air -VMaxx TB -Elite E2 Catch Can -NGK Trix7's -ZL1 Fuel Pump/ADM FPCM -ID-850 Injectors - JDP Clutch Res Relocation -Kooks LT's/Cat-less -Corsa 3" ZL1 Black Tip Exhaust-
Suspension1.25'' Front & 1" Rear Drop- BMR (Sway's, Toe Links, Trailing Arms, Front End Links, Upper Control Arm Bushings, Outer Trailing Arm Bushings)-FMT Solid Subframe Bushings
Brake's/WheelsPowder-coated Calipers-Goodridge Lines-Slotted and Dimpled Rotors-Hawk HPS Pads-OEM ZL1 10 Spoke Wheels (285 Front/315 Rear)
Nighthawk89 is offline   Reply With Quote
