Caryle Racing
Old 08-06-2013, 10:51 AM   #1
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Drives: A 2016 Challenger R/T M6 STP
Finally got the 1LE track pack installed! My Street/Track review
I finally got the 1LE track pack installed on my 2010 SS LS3
Okay, first impression: Did I pay all that money for nothing?
I took the car from the garage home, drove 40 miles on it since and nothing is really different at first sight, I can feel a bit more damping on bump but really nothing dramatic.
I'm getting the alignment done this afternoon and heading for the Track at 5pm. I'm hoping the difference will raise & shine there!
I look forward comparing data with you guys.
Track Day Videos: http://www.youtube.com/user/mrgoodman2000/videos
Built #83817, Born January 18th, Christened June 11th 2010, Stolen October 3rd 2016.
Mikamaro is offline   Reply With Quote
Old 08-06-2013, 11:30 AM   #2
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
IMO the stock 1LE suspension is deceivingly compliant on the street but works well at the track. There is still some body roll and dive, but with 1LE 285 Goodyears it works very well.
Old 08-06-2013, 11:54 AM   #3
RenegadeSS
RenegadeSS's Avatar
Drives: Camaro LLT
Where did you order the kit from?
RenegadeSS is offline   Reply With Quote
Old 08-06-2013, 01:35 PM   #4
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
Besides the track pack, did you have to buy anything extra to make it fit on a 2010?
Old 08-06-2013, 01:45 PM   #5
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
I am curious what that kit cost.
gajagfan is offline   Reply With Quote
Old 08-06-2013, 02:27 PM   #6
Fraxum
Fraxum's Avatar
Drives: 2016 SS M6
+1 IMO the Goodyears are a big part of the 1LE. OP what tires are you running?
My 2011 SS had a full suspension work over with no dive, zero rear stepout, zero wheelhop, and neutral cornering but with the stock Pirellis. The 1LE with a little stepout, some wheelhop, a little understeer, and despite all that feels better planted than my '11. I feel more confident in the corners, but I have not tracked the 1LE yet.
Switching over from the modded '11 SS to the 1LE I did feel a difference. Not night and day, but noticeably better balanced.
Could it be the tires?
M6, Pray Ported TB and MSD, E85, LTs, cats, Rotofab Dry, BMR Trailing Arms
Old 08-06-2013, 03:26 PM   #7
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Okay, so back from the alignment shop and my second impression is very good. The alignment has absolutely change the car (off course). I think the front ends feels about 25% tighter than before, turns in a lot quicker and the damping does feel compliant but it gets stiffer at speeds were has the stock got softer it seems.
I got onto 180 degrees highway ramp at about 55 mph and the front was not even close to understeer but it was too much for the Stability control, it put the front brakes to slow down the car. Something that didn't happen before. I've put it in Comp mode to avoid the intrusion of the system since I think it's now way to secure for the 1LE setup on the 2010 SS. I guess they've changed the configuration of the ECM on the 2013 1LE since no one made that remark before.
I got a relatively ''Aggressive'' alignment for Street & Track.
I've used the FE6 setup but double de front negative camber only.
Front Camber: -1.66
Front Toe Total: -0.2
Rear Camber: -0.78
Rear Toe Total : -0.2
Old 08-06-2013, 03:34 PM   #8
Mikamaro
MikeNoMaro
Mikamaro's Avatar
No. except one minor detail, you need to open up the 10mm hole to attach the 12mm front sway bar link bolt.
Old 08-06-2013, 03:39 PM   #9
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Humm, maybe, I've run the Pirelli'S to the bare rubber on my square setup 275/40R20 with about 9 track days and I have to admit there were good, well balanced tire. I could get them to perfrom with only 32-33 psi hot.
This year I have the Nitto NT05 275/40R20 x4 and track the car 5 times. They are more sticky and needs to run at a higher temp about 38 to 40 psi hot. Otherwise the sidewall ''collapse'' on hard braking and get the feeling you' in the Flinstone Rolling with 4 square tires!! lol
Data wise they both hit 1.04G lateral on my stock SS suspension
Old 08-06-2013, 03:45 PM   #10
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Many GM parts store sells them, between $1000 to $1500 plus installation ($300) plus alignment ($114)
Old 08-06-2013, 04:22 PM   #11
Mikamaro
MikeNoMaro
Mikamaro's Avatar
I'm leaving for the Track, Can't wait anymore...
Old 08-06-2013, 04:32 PM   #12
Outlaw77
Outlaw77's Avatar
Drives: 2010 2SS/RS I.O.M. Camaro 6MT
Did you get the different gears as well?
2010 Cammed & Blown Inferno Orange 2SS/RS LS3 6M
Maggie TVS 2300 8 psi/1:1 overdrive cogs/3.6 pulley/LPE GT-14 cam/BTR valve train kit/KB BAP/LPE ZR1 65lbs injectors/NGK TR71X plugs/Roto Fab CAI/Kooks LT's & cat deletes/Magnaflow x-pipe & mufflers/BMR springs/carbon fibre stripes/20% tint
Cam specs: 223/235 duration @ .050 lift - .610/.620 115.0 C
640 rwhp 603 rwtq
Built and Dyno Tuned by Davenport Motorsports
Wheels: Rohana RC7 Matte Graphite 20x10, 20x11 Super Deep Concave + 275/40, 315/35 Nitto NT05
Outlaw77 is offline   Reply With Quote
Old 08-06-2013, 05:43 PM   #13
cornerspeed92
cornerspeed92's Avatar
...oh sure he leaves us hanging bet he's having a ton of fun!
cornerspeed92 is offline   Reply With Quote
Old 08-06-2013, 11:33 PM   #14
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Well, not so much. I was only able to get 5 laps. There was a crash in my first session out. It took 2 hours to clear the track. By then it was dark and went home.
I will take the time to write my review tomorrow but let me tell you this, It's not the same car anymore, I' ve pulled a 1.15g lateral.
