Cold Air Inductions
Old 08-09-2013, 09:50 AM   #29
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Drives: A 2016 Challenger R/T M6 STP
Originally Posted by sycraft View Post
Why did you have to open the hole, i swapped to the 1LE suspension too, the sway bar was already opened up and the 1LE struts are opened up too, the only ones you need to open up are the standard struts, are you sure they installed the 1LE struts?
Let me confirm with my mechanic.
Thanks
Track Day Videos: http://www.youtube.com/user/mrgoodman2000/videos
Built #83817, Born January 18th, Christened June 11th 2010, Stolen October 3rd 2016.
Mikamaro is offline   Reply With Quote
Old 08-09-2013, 11:33 AM   #30
Orange Crush 1LE
Orange Crush 1LE's Avatar
Drives: 2013 SS 1LE
Mike, I had another thought about why your car has a new issue with snap oversteer. Any chance that the alignment may be off, with the new set up? Maybe they didn't properly torque the fasteners and it moved? I remember reading the Motor Trend Viper Vs. ZR1 review, where the Viper was very difficult on the track. They found out later that the alignment was way off. When they returned to the track with the alignment corrected, it drove like a vastly improved car and shaved seconds off of it's lap time.
Sold but not forgotten! Pedders Supercar Coilovers, 32mm rear sway bar,bushings; APR wing and splitter
Forged 416 road course stroker. 514 RWHP, 497 RW Ft-Lb
1 Camaro, 75 Vipers: http://www.camaro5.com/forums/showthread.php?t=393697
Buttonwillow Raceway: http://www.camaro5.com/forums/showthread.php?t=389086
Orange Crush 1LE is offline   Reply With Quote
Old 08-09-2013, 12:40 PM   #31
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Thanks
Sycraft is correct.
My mechanic did not have to widen the strut hole to 12mm. The 1LE kit has the right fit. My mistake. Sorry.
Old 08-09-2013, 12:55 PM   #32
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
2010 vs 2012?
Old 08-09-2013, 01:04 PM   #33
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
I also wondered if maybe some part of the new components came loose. I do not have much suspension experience, but it seemed to make some sense. I find this thread very interesting.
gajagfan is offline   Reply With Quote
Old 08-09-2013, 01:51 PM   #34
AG454
I am not "Fast & Furious"
AG454's Avatar
Drives: 2010 Camaro LSX454 1LE
Sycraft is correct.
My mechanic did not have to widen the strut hole to 12mm. I had the right fit. My mistake. Sorry.
Mike, can you confirm with your mechanic how he attached the rear sway bar links to your lower control arms? There is apparently a difference between the 2010-11 and '12 and newer lower control arms where the rear sway bar links attach. This is why some people are telling me I need newer model lower control arms. What is pictured in the kit photo are the newer toe links. Thanks.
The day I take a bend too fast
Judgement that could be my last
I'll be wiped right off the slate
Don't wait up 'cause I'll be late, I'll be late
AG454 is offline   Reply With Quote
Old 08-09-2013, 03:10 PM   #35
Mikamaro
MikeNoMaro
Mikamaro's Avatar
I've read that too, well, it could be. I need more track time to determine that first. I will bring the car back to the shop to make sure all the bolts are tight and verify if all is good. I will be back at the track the last tuesday of august. Im leaving for vacation for 2 weeks now! I'm heading to the ST-Madeleine Islands of in the St-Lawrence Gulf.
Old 08-09-2013, 03:13 PM   #36
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Originally Posted by slick rick View Post
2010 vs 2012?
No 2010-12 Struts versus 2013 1LE struts
Old 08-09-2013, 03:19 PM   #37
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Well He didn't mentionned anything about it. There was no fuzz about anything. He told me all went smooth and the parts fitted very well.
Sorry, I don't have more info about it.
Old 08-09-2013, 04:55 PM   #38
Orange Crush 1LE
Drives: 2013 SS 1LE
Mike, one suggestion on the rear sway bar. Pedders told me that the change to the rear sway bar in 2012 was significant in improving the handling. You may want to confirm that there is absolutely no difference between your rear swaybar connection and a 2013 1LE. If there is a difference, I would strongly suggest looking into swapping parts to make it exactly like the 1LE. This really is a magic suspension combo, you're gonna love it when you get it dialed in.
Old 08-09-2013, 06:36 PM   #39
sycraft
COTW 5/06/2013
sycraft's Avatar
the rear sway connection the LCA'a is in a hole in the outboard portion of the LCA, the 2012 has it, the 2010 and 2011 must be changed.
Old 08-09-2013, 06:49 PM   #40
Orange Crush 1LE
Drives: 2013 SS 1LE
Can the 2010 be upgraded to 2012+?
Old 08-09-2013, 06:55 PM   #41
sycraft
COTW 5/06/2013
sycraft's Avatar
yes, direct bolt in.....
Old 08-09-2013, 07:24 PM   #42
intensifi
Drives: '12 2LT Convertible
In the GM performance catalog they "mention" the tire/wheel setup of the 1LE below the 1LE track pack upgrade.
Reading this it makes me feel like they are trying to push you down the path of a tire/wheel change to obtain the full benefits.
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
intensifi is offline   Reply With Quote
