Old 08-06-2013, 01:57 PM   #1
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 Camaro 2SS & 16 Suburban LT
Oil Breather line removal & Oil Breather Cap
I have read a ton of threads where users have installed catch cans and tried to cap off their oil breather line and they get crazy noises. In my case the noise was happening, but only because my oil breather cap that I put on seemed to have a pressure valve in it.
I am not sure why it has this restrictive cap on it... Could it be to stop any oil that may splash up to not get on the filter? I am not 100% sure, but in the end it was preventing my engine to properly get the air flow it needed with the oil breather line capped off.
But overall the entire reason for this is to remove the 2nd way oil can get into your intake line and into your valves. I think most users do not think to remove this line, but I feel it is important to make sure your engine runs clean and to prevent long term damage that can and will happen to your engine.
Here is the breather line that you need to remove. It is easy to identify as it is the only other line that plugs into your Cool Air Intake. In my case I have a K&N CAI.
While this is a breather line and is sucking air, it has been seen time and time again that oil finds its way through this line and WILL dump oil into your intake.
This image isn't very clean, but you can see the oil that dripped into my intake tube after just a few months of driving. I found oil in the tube and on the Throttle Body which in my opinion is a bad thing.
I know this image isn't showing much, but that is just what was in the tube that dripped. Think of the drops that feel and just got sucked into the engine.
So to stop this, I purchased a 3/4" high heat plug and a brass plug to plug the little hole in my K&N Intake.
I removed the long Breather line as seen in this image and pulled off the 4" long rubber tubing to use to hold the plug and cap the old breather inlet on the back side of the engine.
Once I capped that off I installed the oil breather cap and the brass fitting into my CAI to seal it off.
Now this is when I found out about what i think is a pressure valve on the oil breather cap. As when I started the car you could hear a high pitched noise that sounded like sucking and it quickly got louder to the point of me saying 'WTF'. I quickly pulled off the cap on the old breather inlet and you could instantly hear it gasp for air and the noise went away.
This happen each time I started and turned off my car... I used a OBD II reader and the car was also throwing an error for low pressure in the engine. I should of captured a screenshot of it on the Torque app :(
But that was when I decided to look at the breather cap I was using. When I took it off, that is when I noticed it had this brown inlet that had some sort of metal piece on the inside of it.
This piece sat flush with the black plastic and when I blew into it our tried to suck air through it, it seemed to be restricted both ways.
I am sure this is by design for once it is under pressure, but that noise was terrible... I took a pair of pliers and simply pulled the thing out.
I used a shop knife to clear out some of the glue and residue that was left behind... but after doing that and putting the cap on, the noise was gone!
Overall I am not 100% sure I should of done that, but it fixed the issue and the error that torque was showing is now gone.
Sledgehammer70 is offline   Reply With Quote
Old 08-06-2013, 02:59 PM   #2
Kessler
Kessler's Avatar
Drives: 2012 IOM 2LT RS A6 w/ BA
ToDones -
Apex Scoop & Washer Relocate - CAI cai - VMAX Ported Throttle-body -
Elite CC - Elite Clean Side Separator - MRT v1 Axle Back customized w/ J-Pipes -
Blacked Out Headlight/Tail Light Areas - Blacked Out BowTies - Blacked Out 'camaro'
Brake Light Chrome Bezel delete - Front Plate Relocate
JL Audio XD400/4 - Sub Thump Sub Box 2 10"s - DRL to Halos - Escort Redline
Gary's Customs ZL1 Front Bumper, ZL1 Rockers, & ZL1 Spoiler - Paint matched IOM
ToDos -
?Vitesse Throttle Response Controller?
Kessler is offline   Reply With Quote
Old 08-06-2013, 04:40 PM   #3
911medic
911medic's Avatar
Drives: 2012 SIM 2LT/1970 Camaro
OP, I had the same issue with noise as you when I put my RX breather on and removed the stock clean side breather tube. I ended up putting my stock setup back in place as I was afraid I was going to wreck a seal somewhere with the excessive vacuum in the engine.
The problem with removing the check valve, as you did, is that the valve serves 2 functions. First, it prevents crankcase gasses from venting to the atmosphere, and second it is supposed to meter the incoming air. Since you've removed this meter, you now have unchecked airflow entering that breather, which is eventually drawn into your intake manifold via the PCV system.
The problem is that this air does not pass the MAF sensor and is therefore unaccounted for by the ECM. This can screw up your fuel trims and cause issues.
Supposedly some were able to get replacement breathers/check valves to remedy the issue, but in the end I decided it wasn't worth the hassle and just removed it.
I've been periodically checking my intake tube for signs of oil ingestion and haven't seen any yet, although I did have some prior to installing my catch can and drilling out my PCV valve.
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller
RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting
Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting
911medic is offline   Reply With Quote
Old 08-06-2013, 05:09 PM   #4
Sledgehammer70
Lethal Camaro
Well, we shall see what may or may not happen. But in looking at performance I am only seeing good things and no errors popping up. Considering the air is coming from the same place (under the hood just above the CAI) I don't see how this will harm anything in the long run, especially now that 0 oil is able to get in through the CAI into the TB.
Old 08-06-2013, 10:26 PM   #5
911medic
911medic's Avatar
It's not the quality or origin of the air that is of concern, it's the fact that in stock form that PCV intake air is drawn AFTER it has passed the MAF sensor, so its volume is accounted for by the ECM. The breather with check valve is not, but is metered to stay within the parameters that the ECM can adjust for, based on feedback from the O2 sensors, etc. Without the check valve this unmetered air can exceed those parameters, then you can have problems.
Maybe you never will, but I wanted to get that information out there as it seems you're advocating removing the check valve, which may not work as well for everyone as it is for you.
Old 08-08-2013, 11:40 PM   #6
Sledgehammer70
Lethal Camaro
The problem is the check valve is not breathing at all. Took it down to chevy and the tech mentioned the way i have it should be fine.
Old 08-16-2013, 03:32 AM   #7
Mvp_Me
I Use Three Pedals
Mvp_Me's Avatar
Drives: 2011 VR M6
Anybody else have a take on this?
Mvp_Me is offline   Reply With Quote
Old 08-16-2013, 06:22 AM   #8
911medic
911medic's Avatar
Take a look at Ted Jannetty's posts toward the end of this thread: http://www.camaro5.com/forums/showthread.php?t=309513. Sounds like he basically recommends using the stock setup over any breather.
Old 08-16-2013, 01:35 PM   #9
intensifi
Drives: '12 2LT Convertible
I gave up on the breather and ordered the 1LE separator from Maureen at Rodgers.
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
intensifi is offline   Reply With Quote
Old 08-17-2013, 01:04 AM   #10
Mvp_Me
I Use Three Pedals
Mvp_Me's Avatar
Drives: 2011 VR M6
When I had my cobalt SS I did a turbo swap (mine was the supercharged version) the car ran fine but after some time I got a breather used that in place of my oil cap (which had no check valve) and from the minute I drove off it was a big difference, like the car shaved a few pounds, everything was smoother and it ran a whole lot better. Now I know it's not a camaro and it was a 4cyl car that was not direct injected but wouldn't the same concept apply? This is the first time I have ever seen a check valve in a breather for a car. Plz let me know if im missing something.
Old 08-17-2013, 01:06 AM   #11
Mvp_Me
I Use Three Pedals
Mvp_Me's Avatar
Drives: 2011 VR M6
ive seen that thread before but many cars run breathers so i dont see why the camaro cant or doesnt benifit from it.
Old 08-17-2013, 09:52 AM   #12
911medic
911medic's Avatar
You asked for another take, I pointed you to one from a very reputable source, which includes an explanation as to why the Camaro might not benefit from a breather that pulls unmetered air without the MAF sensor seeing it.
Or are you looking for a take that tells you what you want to hear?
Old 08-17-2013, 04:26 PM   #13
Mvp_Me
I Use Three Pedals
Mvp_Me's Avatar
Drives: 2011 VR M6
Is someone catching feelings?? all i said is that i have seen this thread before, no need to get smart.
Old 08-17-2013, 11:11 PM   #14
911medic
911medic's Avatar
I'm not "catching" anything.
You said more than just that you'd seen that thread before. You also said that since other cars can run breathers that you don't understand why the Camaro can't benefit from one, even though the thread you say you've read contains a clear explanation from a respected and knowledgeable source as to why the Camaro shouldn't run one.
