Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 08-06-2013, 10:13 PM   #1
Drives: SS
What the?
130R is offline   Reply With Quote
Old 08-08-2013, 10:06 AM   #2
blazzin1's Avatar
Drives: 2016 2SS (A8)
The only thing I see is that you have 1/16 toe-in (positive). According to PFADT, they recommend -1/16 to 0 (toe out) for the "street-performance" setting. But hard to believe that would wear down your tires that much!!! I would question the validity of your last alignment. All you can do is get it aligned again, and use the "street-performance" settings as recommended by PFADT.
File Type: pdf Camaro Alignment Guide Rev 9.12.2011.pdf (84.8 KB, 97 views)
blazzin1 is offline   Reply With Quote
Old 09-04-2014, 10:04 PM   #3
CamaroSS sleeper
Drives: Sleeper_NOT
I know this is an old threat, but for any one looking for the answer.
that is excessive toe-in/out (if it was toe-in; the wear would be towards the outside of the tire and vice versa.)
I can tell you the wear you show was not due to 1/16 of an inch.
factory sets toe-in to about that value from factory so that when you are traveling in the FWY in a loaded condition the toe actually becomes close to 0.
hope this helps some one..
CamaroSS sleeper is offline   Reply With Quote
