Old 08-07-2013, 01:57 PM   #1
CocoaKid
CocoaKid
Drives: 2011 Camaro LS
Need help with tire sizing!
Hi, I'm looking at two winter tires for the front of my 2011 V6...(Already have the back two 235/60/17)...this size was recommended by a tire shop btw.
I need to know by tomorrow if 235/50/17 would work for the front two wheels or am I just asking for trouble? I'd like to get 235/60/17 to match the front but I've got a smoking deal if I get the 235/50/17 tires...
Thank you!
CocoaKid is offline   Reply With Quote
Old 08-07-2013, 02:37 PM   #2
JR 1
JR 1's Avatar
Drives: 2014 2SS/RS Convertible
What wheels do you have??
JR 1 is offline   Reply With Quote
Old 08-07-2013, 02:43 PM   #3
~ChipsAhoy~
Shenanigans
~ChipsAhoy~'s Avatar
Drives: 2010 CGM 2SS/RS L99
They will be the same width (235), but your sidewall will be shorter.
And yes, they will fit just fine assuming the 235 width is what your car had before.
2010 CGM 2SS/RS L99
~ChipsAhoy~ is offline   Reply With Quote
Old 08-07-2013, 08:12 PM   #4
Scalded Dog
Scalded Dog's Avatar
Drives: 2011 1LT
I thought all 5th gens had 18s or bigger? Aftermarket 17s, or am I simply mistaken?
Scalded Dog is offline   Reply With Quote
Old 08-07-2013, 08:43 PM   #5
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
Yes, I thouht the factory wheels were 18s or larger too. Not sure if 17" rims would even clear the front disk brakes and calipers. You don't provide enough information to know if they will fit so be careful to check before buying.
Mark114 is offline   Reply With Quote
Old 08-08-2013, 01:51 AM   #6
CocoaKid
CocoaKid
Thank you all, I can clarify! I'll be getting just plain Jane steelies for the winter (Calgary, Canada), the tire shop said 17" wheels will work for my car. My car (used) came with 19" front 20" rear , with summer tires only when I got it. I know the SS have the Brembos, but mine doesn't being a V6.
I have 245 & 295 right now so want some thing a little thinner all around during the winter (235s all around). I'm mostly just concerned about the sidewall height (235/50/17 in front, 235/60/17 in rear tentatively)...basically is that 10mm difference between 50 and 60 crucial?
Thanks!
Old 08-08-2013, 09:40 AM   #7
~ChipsAhoy~
Shenanigans
Actually, the 50 and 60 designates the percentage width of the tread to get your sidewall...if that makes sense. If the tire is 235/50, then your sidewall is 50% of the 235 width. So, your sidewall height on the 235/50 tire is 4.6", whereas your sidewall height on the 235/60 is 5.5".
2010 CGM 2SS/RS L99
Old 08-08-2013, 04:00 PM   #8
Group-A Wheels
Drives: Camaro SS
The factory size tires on the V6 are 245-55-18, which is 28.6" tall. The 235-60-17 is 28.1" tall. The 235-50-17 is 26.25" tall.
That 2.35" in height is huge. Especially since you have a taller tire in the back. Typically, people go slightly taller for snow use so they can drive over, and plow through the snow. A 235-65-17 would be more ideal.
Group-A Wheels is offline   Reply With Quote
