Emblempros
Old 08-07-2013, 08:19 PM   #1
ddck24
ddck24's Avatar
Drives: 2012 Camaro 2ss 45th M6
LsX build
Wanting to get a new bottom end underway to handle even more power...
Am wanting to pull the trigger on a LsX block
Part number 19260095.. This shows it to be a complete finished block.
Says fully machined, bored, honed.. (4.065 bore)
Thoughts are to do a fully forged 3.622" (376) or 4.00" stroke (416ci) rotating assembly in this block..
Any one have experience with these lsx's??
Any thing you have to do to it before you can start assembling?
Any extra parts you have to purchase? Cam bearings, covers?
Will be swapping over the ls3 goodies on to it..
Thanks guys.
ddck24 is offline   Reply With Quote
Old 08-07-2013, 08:37 PM   #2
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
Buy it bare and the. Have a machine shop do all the work on it. Everything needs to be balanced before assembly too. What internals?
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 08-07-2013, 08:44 PM   #3
ddck24
ddck24's Avatar
This part number is the block they use for the 376 (4.065) crate motor, shows that it's 100% finished!! Which would be sweet. The non finished blocks are the same price. Which would make no sense if I wanted a 4.065 bore anyways.. That's what caught my eye, no machine work!! Start bolting things up! Just going to see if anyone had any more knowledge about this "finished" block.. Don't want to spend 2,500 on a block and then it shows up and have to do a bunch of work on a "finished" block. Lol
Old 08-07-2013, 08:45 PM   #4
VanquisherSS
Hasbin of Stock Bottom HP
Drives: CTS-V Coupe, 04 TT Viper
I'd just buy a built shortblock from TSP.
VanquisherSS is offline   Reply With Quote
Old 08-07-2013, 08:48 PM   #5
2SS45th
2SS45th's Avatar
They're not fully finished. They need to be bored again with simulated heads on. The pressure of the heads clamping down will move the bores, so they need to be done again. GM doesn't do it this way, but it's the right way of doing things. The marines need to be line bored too. Nothing can just be bolted in, you need to take it to a machine shop and have everything balanced, even if you just pulled it out of a motor. You'll need new rings too.
Again, what internals are you using? Stuff you have or need to buy?
Old 08-07-2013, 08:52 PM   #6
ddck24
ddck24's Avatar
Will buy all new internals for build.
Old 08-07-2013, 08:54 PM   #7
2SS45th
2SS45th's Avatar
Not trying to offend you here, but have you done this before? Just checking so I can give you the right advice without overwhelming you with information.
Old 08-07-2013, 08:59 PM   #8
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
What he said. You can get a built SB starting around 5500.00
Nitroman28 is offline   Reply With Quote
Old 08-07-2013, 09:00 PM   #9
ddck24
ddck24's Avatar
LsX block I believe is a lot higher
Old 08-07-2013, 09:07 PM   #10
2SS45th
2SS45th's Avatar
You keeping the LS3 heads? And what kind of power adder?
Old 08-07-2013, 09:32 PM   #11
ddck24
ddck24's Avatar
Yes ls3 heads with ecs kit
Old 08-07-2013, 10:09 PM   #12
2SS45th
2SS45th's Avatar
No need for an LSX then, only needed after 1k wheel.
Old 08-07-2013, 10:40 PM   #13
Unreal
Drives: 2006 Z06
And cheaping out on skipping a little machine work that will probably still be needed when building a $6k+ short block isn't the best idea. All the machining will have to be checked and cleaned up anyways.
Nick
Corvette Z06 -1200ish rwhp
Old 08-07-2013, 11:20 PM   #14
Nitroman28
Nitroman28's Avatar
Think the LsX block is 1000.00 more then the LS3.
