Old 08-08-2013, 12:45 PM   #1
Powhusku
Powhusku's Avatar
Drives: 2010 2SS/RS M6
Michelin Pilot Super Sports Fitment Question
I'd like to do the setup recommended by Whiteside Customs (275 front/295 rear), or even 285 front/295 rear recommended by another member. I'm not sure if either of these are a safe/reasonable setup for my wheel specs and was hoping for a recommendation. If it helps, I'd like the setup that will offer the best performance, I'm not concerned about looks. Wheel specs are below. Can anyone offer any advice?
Front: 20X9 5-120 +20
Rear: 20X10.5 5-120 +42
Powhusku is offline   Reply With Quote
Old 08-08-2013, 02:22 PM   #2
bkscott
bkscott's Avatar
Drives: 2010 Camaro 2SS/RS
Michelins run wide, so while the 285 would fit, the 275 would probably work better on the 9 inch front. The 295 rear is a s wide as some 315's so you are good there on the 10.5 inch rear.
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10.
ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller.
bkscott is offline   Reply With Quote
Old 08-08-2013, 02:55 PM   #3
Orange Crush 1LE
Orange Crush 1LE's Avatar
Drives: 2013 SS 1LE
If your goal is road course performance, try not to make the rear tire much wider than the front, or you will have more understeer. Preferably same size front and rear, but your wheels are too different in width to allow for that. I would go 275s in front, 285s in rear.
For straight line drag racing, you could go wider in the rear. Not sure how wide, I would look on Tire Rack's website. They have specs for the tires, tread width, section width, Etc. That will help you compare between tires.
Agree with bkscott, some of the Super Sports run wider than the typical tire. But some of the Super Sports don't, so take a careful look at dimensions.
Sold but not forgotten! Pedders Supercar Coilovers, 32mm rear sway bar,bushings; APR wing and splitter
Forged 416 road course stroker. 514 RWHP, 497 RW Ft-Lb
1 Camaro, 75 Vipers: http://www.camaro5.com/forums/showthread.php?t=393697
Buttonwillow Raceway: http://www.camaro5.com/forums/showthread.php?t=389086
Orange Crush 1LE is offline   Reply With Quote
Old 08-08-2013, 03:58 PM   #4
Daniel Linnett
TAGURIT
Daniel Linnett's Avatar
Drives: 2008 G8 GT
I've ridden in the Whiteside Customs Camaro with the 275/295 combo. It handles like it's on rails! I do believe he runs a 10" front and 11" rear with those tires too. He can probably get you a pretty good price if you call them.
Current G8 record holder at 9.569@138.22 *sold
2004 GTO Stock Bottom End Record chasing
Daniel Linnett is offline   Reply With Quote
Old 08-08-2013, 04:54 PM   #5
Termin8r27
Termin8r27's Avatar
Drives: 2012 45th Camaro L99 2SS/RS
I second the wide comment, they do run 'true' or a little wide to spec. I've got 255's up front and the 295's out back and they are phenomenal tires! On your wheels I'd also say running the 275/295 combo should work good.
2012 45th L99 Camaro 2SS/RS
2015 Jeep Wrangler Unlimited Sport
Termin8r27 is offline   Reply With Quote
Old 08-09-2013, 01:54 PM   #6
Powhusku
Powhusku's Avatar
Thanks for the help guys. I'll contact Whiteside and see what they think.
