Old 08-08-2013, 02:03 PM   #1
faSSteddie
faSSteddie's Avatar
Drives: 2013 Victory red/white stripes SS
service TPMS
While driving to work this a.m. my dash said that I needed to service the TPMS system. My car is a 2013 with 6000 mi. The screen where it shows the actual tire pressure shows a dash for the left rear tire. I checked the tire and it was fine. I looked up the problem here and got a headache with all the back and forth mess. : you can, you cant, you need a tool, you don't need a tool, my '12 does, my '12 does not....ad naseum. Can I reset the sensor/system myself without a tool or not ? (remember it is a 2013.) If I have to go to the dealership, is it covered under the warranty? how long does it take the dealership?/should I have to leave it there? Does any body know for sure?
faSSteddie is offline   Reply With Quote
Old 08-08-2013, 02:39 PM   #2
So Cal Camaro
So Cal Race Team
So Cal Camaro's Avatar
Drives: 2013 Camaro
No, you need a tool for a 2013...it takes no time to do if you have the tool, under 5 minutes...they should reset it for free....
So Cal Camaro is offline   Reply With Quote
Old 08-08-2013, 05:13 PM   #3
faSSteddie
faSSteddie's Avatar
cool
Thank you kindly!
faSSteddie
Old 08-08-2013, 05:15 PM   #4
joeybsyc
joeybsyc's Avatar
Drives: 2010 Aqua Blue Metallic 2SS
You do need a tool for a 13, but you may also have a bad sensor if it just suddenly quit reading pressure.
joeybsyc is offline   Reply With Quote
Old 08-09-2013, 11:57 AM   #5
lionssfan
drive it like U stold it
lionssfan's Avatar
Drives: 2010 2ss camaro
I thought the manual setting could still be done on all the Camaro years. where you put it in reset mode on your IP cluster and let the air out at each wheel starting at the front left...right front and working clock wise around the vechicle. that's how I did my 2010
lionssfan is offline   Reply With Quote
Old 08-13-2013, 07:42 PM   #6
joeybsyc
joeybsyc's Avatar
Well you thought wrong. On a 2010 you can, but not a '13.
