Cold Air Inductions
Old 08-08-2013, 08:11 PM   #1
sliver
sliver's Avatar
Drives: 2012 2lt rs
I want an Axel back w/ minimum drone at highway speeds
I am thinking about getting an axelback for my 12 2lt rs. not a fan of raspy exhaust, prefer a lower tone. But i keep hearing about the drone. Comming from a 2002 silverado w/ a flowmaster, I know how anoying it can be. Does anyone a have a video crusing at highway speed w/ the drone 65-75?
sliver is offline   Reply With Quote
Old 08-08-2013, 09:02 PM   #2
bkdamon
bkdamon's Avatar
Drives: Rally Yellow 2012 1LT
I had a MRT v2 and found it too droney for the amount of highway miles I run.
I've heard the Borla is has much less drone but have no 1st hand experience with it.
bkdamon is offline   Reply With Quote
Old 08-08-2013, 11:00 PM   #3
SirZeusor
SirZeusor's Avatar
Drives: 2012 Camaro LS
the GMPP GM offers for the LFX has no drone at 65 mph.
I have it paired with a BBK intake.
it doesn't "fart" on the downward rev either like the mrt or the corsas do.
pure low tone.
somewhere here I have vid and sound...
GMPP is made by Borla tuned for the Camaro.
I love it.
not a fan of MRT
just doesn't sit right putting that on a Camaro...and I have owned mustang tech.....
ps....GMPP= general motors performance parts.
I think....
SirZeusor is offline   Reply With Quote
Old 08-08-2013, 11:09 PM   #4
Joe@CPR.com
Joe@CPR.com's Avatar
Drives: 03 vette, 94 trans am, 04 gto
Magnaflow #endthread. they are my favorite when a customer wants no drone and want's to wake it up in the sound department we have great pricing on it to btw.
Joe@CPR.com is offline   Reply With Quote
Old 08-08-2013, 11:45 PM   #5
ENV US
ENV US's Avatar
Drives: 2011 Synergy Green RS, 1999 Camaro
I just installed MRT V2 a couple of weeks ago. The drone isn't really that noticeable. But then again I have owned a number of Camaros with headers and side pipes. As well as a couple of Vettes with headers and side pipes. Maybe those cars affected my hearing, but really? If its to loud you are to old. I love the way mine sound, if I ever get tired of the noise ill just turn up the stereo. A?????��
ENV US is offline   Reply With Quote
Old 08-09-2013, 01:07 AM   #6
SeaCompiler
...not a marine biologist
SeaCompiler's Avatar
Drives: 2012 Camaro RY SS LS3
I purchased two Cherry Bomb extremes, 2.5 inch in and out for my SS. Cut the stock mufflers off, used a wide band to mount it on where I cut the stock mufflers off and then got my local muffler shop to weld some pipes from the muffler out to the back again and it sounds really good. Not much drone at all going down the road, but definitely louder than stock. I will tell you that before I got the extensions put on and the sound was dumping out right under the back, I thought about getting rid of them because it was so loud, but after the extensions were put on post-muffler, I was really shocked at how good it sounded and not much drone at all over stock. Once I put my long tubes on, I think it will be just right.
I am familiar with Flowmaster, I put one on my 300. Although the sound is awesome, it does drone, not to mention it doesn't flow as well as other mufflers.
Turbocharged with Huron Speed & Cammed with Cam Motion from Spartan Performance, 25% PowerBond UDP, Ported TB, shaved heads, LS9 gaskets, chromoly pushrods, BT trunnions & dual valve springs, IWIS, Might Mouse CC, SJM Line Lock, Turbosmart controller, MSD 2-Step, ZL1 spoiler, Strut Brace, ARP bolts, Skip shift elim, A-Pillar Gauges, FR Style 41 20X10, CAI, Cherry Bomb, blackouts, Lowered, Custom badges, VDI lambo doors, Hines vents,RPI fender vents, BlackVue 1080P Dashcam, Technostalgia Tail Lights, KW 500W on 10", Metra Kit, Pioneer AVH 4600BT, Morimoto RGB Halos, Tuned by Pat G
SeaCompiler is offline   Reply With Quote
Old 08-09-2013, 03:13 AM   #7
BigVic
Speed Racer
BigVic's Avatar
Drives: 2012 AGM 1LS
11776
I am thinking about getting an axelback for my 12 2lt rs. not a fan of raspy exhaust, prefer a lower tone. But i keep hearing about the drone. Comming from a 2002 silverado w/ a flowmaster, I know how anoying it can be. Does anyone a have a video cruising at highway speed w/ the drone 65-75?
I have the Borla axle-back 11776 and really like it. It is not raspy and no drone. I have some video's at the link below. Look at post #12 for a HQ video. No cruising video's, but at 60-80 mph in high gear, I have no drone.
http://www.camaro5.com/forums/showthread.php?t=307540
Just be advised, it is very quiet until you really get on it. I would venture to say it is one of the quietest one's available.
install was easy, and parts are high quality. LMK if you have any questions.
BigVic is offline   Reply With Quote
Old 08-09-2013, 03:19 AM   #8
BigVic
Speed Racer
BigVic's Avatar
You have a V8...comparing apples to oranges. With all due respect, completely irrelevant for a V6 comparison.
Old 08-10-2013, 08:11 AM   #9
bkdamon
bkdamon's Avatar
So we all have to like it because you do and if we don't like it we are too old? And I love the part about covering up the poor quality sound by turning up the radio to drown it out!
OP, as you have read there are several quality options that will get you a properly tuned axle back. I trust you won't let reasoning like above influence you to purchase a product you won't be happy with.
Old 08-10-2013, 11:10 AM   #10
Kessler
Kessler's Avatar
Drives: 2012 IOM 2LT RS A6 w/ BA
I got the MRT v1 for the loud start up and idle. I had warning of the highway drone so I installed the j-pipes before installing. That was only an added 65$ and added about 2 hrs to install because we went by pictures and had to fit and adjust. But, I have 0 drone at 65-75. But in Az, where the limit is a little higher, I began to hear that drone. But as said earlier, a stereo 'fixes' that for some of us.
ToDones -
Apex Scoop & Washer Relocate - CAI cai - VMAX Ported Throttle-body -
Elite CC - Elite Clean Side Separator - MRT v1 Axle Back customized w/ J-Pipes -
Blacked Out Headlight/Tail Light Areas - Blacked Out BowTies - Blacked Out 'camaro'
Brake Light Chrome Bezel delete - Front Plate Relocate
JL Audio XD400/4 - Sub Thump Sub Box 2 10"s - DRL to Halos - Escort Redline
Gary's Customs ZL1 Front Bumper, ZL1 Rockers, & ZL1 Spoiler - Paint matched IOM
ToDos -
?Vitesse Throttle Response Controller?
Kessler is offline   Reply With Quote
Old 08-10-2013, 05:26 PM   #11
ENV US
ENV US's Avatar
Like a lot of trolls here you took the post out of context. I didn't say you had to like it. Everybody is entitled to their own opinion. I was simply stating that I didn't find the drone that bad.
I am sure OP can make an educated decision without you holding his hand. There are all kinds of sound clips on here and YouTube that will help in the decision making process. Simply stated I have the MRT V2. Apex was awesome as well as MRT support.
Old 08-10-2013, 07:21 PM   #12
sliver
sliver's Avatar
Drives: 2012 2lt rs
right now im leading towards the magnaflow not sure yet though
Old 08-10-2013, 09:12 PM   #13
Firebird2xc
Firebird2xc's Avatar
Drives: car
I put Dynomax V/T's on my 1LT and love them. The V/T means valve-tuned:
Check out their website and watch their demos and see for yourself. A really solid buy and totally easy to install yourself if you want.
http://www.dynomax.com/mufflers.php
http://www.dynomax.com/application_i...l-engine-38493
Firebird2xc is offline   Reply With Quote
