BeckyD@RodgersChevrolet
Old 08-09-2013, 09:42 AM   #1
intensifi
Drives: '12 2LT Convertible
1LE Oil separator on LFX
Does anyone know if it would fit on an LFX with the engine cover on and the hood closed?
I know I'd need to buy a hose to connect to the intake as the included one is only for the V8s.
NOTE: I'm talking about the OEM part, not the RX performance version.
Mods: GM Locking Gas Cap, RS License Plate Frame
intensifi is offline   Reply With Quote
Old 08-09-2013, 10:07 AM   #2
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged V6
Friend of mine just installed his on his LLT with no engine cover last night...but he had to get a reducer for the intake tube and a plug for the rear drivers side to make it work.
Lil' Nasty is offline   Reply With Quote
Old 08-09-2013, 11:09 AM   #3
intensifi
The rear plug is expected.
What is the size/shape of the separator air tube port?
Any pics?
Old 08-09-2013, 11:23 AM   #4
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Any pics?
Just saying its hard to find a plug or anything automotive in my area...
Needs a 1/2 to 3/8 hose adapter ...
Old 08-09-2013, 11:33 AM   #5
simt3k
Drives: 2011 Camaro RS 2LT
How do you drain that?
simt3k is offline   Reply With Quote
Old 08-09-2013, 11:58 AM   #6
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Theres a piece called the quick release fitting that you use to drain it.
Old 08-09-2013, 01:44 PM   #7
intensifi
Thanks for the info & pics!
I was under the impression it drained back into the engine after the "out" pressure subsides.
Old 08-09-2013, 02:09 PM   #8
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
You are right. It does drain the way you are saying. Reason I left the quick release was for when i go to change the oil i don't need to play around to get the hose off. The above pictures are of my car and I will be posting a DIY later tonight of the install. I will also check to see if it fits with the cover for you. That I know of I am the first V6 (both LLT and LFX) with the separator. More details will come tonight when I'm on my computer and not my iPhone.
Proud owner of litho #179 Click Picture for Build Thread
Old 08-09-2013, 02:12 PM   #9
menendez1293
Here are some slightly better pictures
Old 08-09-2013, 02:35 PM   #10
intensifi
Thanks!
While I'm waiting for my brakes to come back from the powder coater, this is moving to the top of my mod list.
Old 08-09-2013, 06:55 PM   #11
menendez1293
As promised here is my DIY for installing it on the LLT which will probably be very similar for the LFx. I would say it might be possible to run it with the engine cover but it would be a very very tight fit.
http://www.camaro5.com/forums/showth...80#post6879580
Old 12-19-2013, 02:21 PM   #12
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Here is another choice for an oil separator. I received word from Tracy at RX about a month ago about testing this out for him. I was not able to get it hooked up until the day before I put my Camaro into storage. Installation was clean and simple. It replaces the breather that I had in this location. Looks good sitting in my engine bay. I will have more information about it in the spring after I get some miles on it. Also, I have attached a photo from Tracy showing the separator on his latest top mount supercharger build.
