Old 08-09-2013, 08:34 PM   #1
parkermoeder
parkermoeder's Avatar
Drives: 2011 Camaro ss
Help with 305
Okay so I've read through about 20+ threads about this subject. WHAT'S THE WIDEST TIRE YOU CAN RUN ON A STOCK 9in SS RIM!??? I like the look of running wide tires. So I was thinking nitto invo for my tire. I've heard they run smaller so would a 295 or 305 work for the rear? Some say it will hurt handling. Will it? And some say that the traction path or I forget what they called it contact path will be the same as a 275 and the extra inches are just for looks. Can someone please clear this up
[2011 Camaro 2ss L99
-OEM Painted GFX
-Borla Atak axle back
-Stainless Power headers
-Cold Air Inductions Intake
-Blue oracle halos
-Satin black ZL1 replicas
-315 invos and other cosmetic mods
parkermoeder is offline   Reply With Quote
Old 08-10-2013, 10:27 AM   #2
parkermoeder
Anyone?
-OEM Painted GFX
-Blue oracle halos
Old 08-10-2013, 10:41 AM   #3
AG454
I am not "Fast & Furious"
AG454's Avatar
Drives: 2010 Camaro LSX454 1LE
I don't think you want to go wider than a 285 on the stock 9" rear rim. 295's and 305's will fit safely on a 10". A wider tire on a rim smaller than it was made for will have a rounded contact patch and will wear out faster.
The day I take a bend too fast
Judgement that could be my last
I'll be wiped right off the slate
Don't wait up 'cause I'll be late, I'll be late
AG454 is offline   Reply With Quote
Old 08-10-2013, 11:46 AM   #4
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 10 Legacy 2.5GT, ...
275 is the widest you'll likely find by researching actual tire sizes and their minimum wheel width requirements. 275 is also the widest I'll ever suggest for anything short of brief emergency needs where you can't find 275/40's and absolutely need to use that car.
275/40's are pretty squeezed down as it is when you put them on wheels that are only 9" wide.
Norm
Norm Peterson is offline   Reply With Quote
