Old 08-09-2013, 07:37 PM   #1
GVA 45TH 2SS
KNGTFALL
GVA 45TH 2SS's Avatar
Drives: 2012 2SS 45th edition
Tire pressure VREDS
I got some Vredestein sessantas recently, Just wondering what everyone else is running for tire pressure on these models.
Thanks
GVA 45TH 2SS is offline   Reply With Quote
Old 08-09-2013, 07:38 PM   #2
HardrockSS
Drive Fast Take Chances
HardrockSS's Avatar
Drives: 2012 45th anniversary SS
I've been going stock with 36
2012 45th Ls3 M6:ECS 1500, Custom Cam ,Alky Meth kit, Mcleod Rxt, MGW shifter,Pfadt Tri-y headers Solo Mach X, 20%tint,3.91 gears ,Suspension upgrades, G-force axles.700 RWHP
http://www.slowhawkperformance.com/
HardrockSS is offline   Reply With Quote
Old 08-09-2013, 07:46 PM   #3
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2012 2LT RS
mine are 36 I believe...after driving for awhile they seem to increase to 41
2012: e85, 80mm TBody, CAI w/scoop, Solo HFC, ZL1 FP, Magnaflow TruX, Dynomax VT, Elite catch can, HP Tune, Throttle Contoller, BMR; Springs, Sways, Trailing Arms, Toe Ends, & Safety Loop, Koni str.t, Pioneer Z150bh, Phoenix Gold Sub, Hertz speakers & 5ch Amp, 1LE rear with 3.91 gears, BMR bushings, Baer Decela Rotors, Goodridge brake lines, Brembo(GM) 4 piston calipers, Hawk Ceramic pads, ported intake, Circle D 5c. 12.3@112 old setup
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
IneedAZ is online now   Reply With Quote
Old 08-11-2013, 06:29 AM   #4
GVA 45TH 2SS
KNGTFALL
Thanks guys, I will keep them around 36.
Old 08-11-2013, 09:18 PM   #5
camaro4mybday
"Camaro Joe"
camaro4mybday's Avatar
Drives: 2010 SILVER ICE 2LT/RS CAMARO
Send a message via AIM to camaro4mybday
i run 33 cold goes to 36ish hot
camaro4mybday is offline   Reply With Quote
Old 08-12-2013, 12:14 PM   #6
Group-A Wheels
Group-A Wheels's Avatar
Drives: Camaro SS
For street use, you can run them at the factory settings. If you hit a lot of potholes, then run more air pressure to help prtect your tire and wheel.
If you ever do a track event or solo event we set them at 23 and 26 cold.
Group-A Wheels is offline   Reply With Quote
Old 08-12-2013, 07:37 PM   #7
GVA 45TH 2SS
KNGTFALL
thanks again guys
