JUICEDMOTORSPORTS
Old 08-10-2013, 03:45 PM   #1
jbrown13
jbrown13's Avatar
Drives: 2011 Camaro SS L99
I'm about to give up on drag racing!
I'm still having a ton of trouble getting a decent 60' time with my set-up. I'm either a poor driver/slow learner or the track prep at Silver Dollar in Reynolds, GA stinks. I have added LT headers, HF cats, cam, WCCH heads, 3600 triple disc stall, 3.91 gears and various Pedders/BMR rear suspension parts. I'm dynoing right at 480 rwhp/430 ft-lbs on a Dynajet and am running MT 305/45R18 ET Street Drag Radials. My 60' times are in the 1.9s and 2.0s depending on pressure and brake stall speed, but I'm seeing guys be in the 1.7s on Pirelli street tires on this forum. I've had the rear alignment set at zero toe and zero camber as was suggested in a former thread of mine. Needless to say I'm frustrated and about ready to have it put back to stock and forget drag racing. I'm running low 12 seconds @ 115 + MPH in the August GA Heat so I don't think it's because of a lack of power.
Anyone want to try to help me out? If you happen to be in the middle GA area I'll even let you drive it down the track to see whether it's me, the car or the track. I'll be 69 years old in 4 weeks and don't have time to be frustrated with this crap.
jbrown13 is offline   Reply With Quote
Old 08-10-2013, 03:54 PM   #2
mlee
www.CamaroFans.com
mlee's Avatar
Drives: 2017 A10 ZL1
Drop your tire pressure to 16 psi. and do a GOOD burnout and really heat them up. At your power you should easily hook and get at least a 1.8
Old 08-10-2013, 04:18 PM   #3
Jayrcr3
Jayrcr3's Avatar
Drives: 2011 IOM 2SS/RS
That's an easy 11 second car.
Extracting every last bit is not as easy as the seasoned veterans make it look. Keep practicing and the timeslips will begin to show it. Forget about cutting a good light, and the guy in the other lane, and concentrate on the launch.
Sent from my HTC One X using Tapatalk 4
American Racing 1 7/8" Headers and Hi-Flow Cats, CAI cold air intake, Flowmaster AT exhaust, Vengeance Racing Stage 2 cam, VMax ported throttle body, TEA valve springs and titanium retainers, Trick Flow hardened pushrods, 180* T-stat, Comp Trunion kit, ZL1 Fuel Pump, ADM Fuel Pump Control Module, 20% window tint, Whipple Supercharger. Tuned by Mike Norris Motorsports. 656rwhp/584rwtq @10 PSI.
Jayrcr3 is offline   Reply With Quote
Old 08-10-2013, 06:00 PM   #4
Motion427
Drives: 2010 2SS/RS Red Jewel L99
My car seems to work better foot stall at 1200rpm.
If I go higher,it spins the tire just abit,I don't here it,but I see it on the log.I have a 3400 converter and 3.45 with 17". So far, my best 60 ft is a 1.77
Motion427 is offline   Reply With Quote
Old 08-10-2013, 06:06 PM   #5
Supercharged SS
Drives: 2010 Camaro
I always leave between 1000-1100. That's yielded me the best results.
Old 08-10-2013, 06:12 PM   #6
Motion427
Don't be hard on yourself. Track condition,location,temperatures plays a big role in timeslip.
I know some racers have to deal with tracks that the DA is about 3000+ in their coldest day.which is a good 3-4 tenth slower if you would race the same car at a track that would have a 0 DA.
You should compare to other Camaro owners in your area and what they run.
Old 08-10-2013, 06:14 PM   #7
Motion427
Yours is special.I'll race ya right now. Lol....
Old 08-10-2013, 06:41 PM   #8
Supercharged SS
Drives: 2010 Camaro
Well, it still runs. They started it on Friday. Whats the worst that can happen....It's already broken. I'm in!!!!
Old 08-10-2013, 07:07 PM   #9
white ZL1
Drives: none
The combo of the 3600 and the 3.91's is going to be more difficult to hook, even on a M/T DR, due to the 4.03 first gear in the 6L trans.
What tire pressure are you running cold and hot?
What are you doing for a burnout?
What's your launch technique?
white ZL1 is offline   Reply With Quote
Old 08-10-2013, 09:39 PM   #10
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
if u dont do it alot , it takes time. watch most dd or true street cars at the track most will be 2.0 and worse. just have fun try diff stuff. u cant find out what works if u dont try diff stuff. what works for my car may not work for urs . same as what works for me as a driver may not work for u. keep at it tho. find someone at the track that dont care to help u . thats usally the best way to learn , having someone there with u.
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 08-10-2013, 10:14 PM   #11
jbrown13
jbrown13's Avatar
At 16 PSI and a good burnout I had 60' times of 1.999, 2.043 and 1.950, all at different brake stall RPMs. Spun the tires like crazy.
Old 08-10-2013, 10:15 PM   #12
Camarojt
Camarojt's Avatar
Drives: 2011camaro SS
I bet you are not getting your tires hot enough and that you are up on the converter too high when you launch. Try leaving the line right above idle. If it still spins, you need to practice fast rolling the throttle until you get better at it. Also like others said, drop your tire pressure to 16 and see how it goes.
Camarojt is offline   Reply With Quote
Old 08-10-2013, 10:17 PM   #13
jbrown13
jbrown13's Avatar
The problem seems to be a lack of 5th gen Camaros at the track. Friday night I was the only one there, but must have been 50 Mustangs. At least I'm beating most of them.
Old 08-10-2013, 10:25 PM   #14
jbrown13
jbrown13's Avatar
I thought after I was talked into the 3.91 it was a bad decision, but I'm not willing to blame every crappy 60' time on the gear.
I tried every pressure between 15 and 19 (MT recommends 12 to 16) and left at different brake stall speeds, and my 60' times did not vary much, 1.947 to 2.043. Frankly, the rear tires felt squirrely at 15 and 16 PSI.
I'm trying to do a reasonable burnout, some smoke, but not a whiteout.
I bring the throttle up to the RPM I want to leave on w/ my left foot on the brake, and then mat the throttle and release the brake at launch.
