JUICEDMOTORSPORTS
Old 08-11-2013, 02:23 PM   #29
midnighter
Drives: nothing
Giving up would be the easy way out, but it would make your pride suffer.
Old 08-11-2013, 02:26 PM   #30
UF4LIFE102SS
Treasure Coast Camaro 5
UF4LIFE102SS's Avatar
Drives: 2010 2 SS
I have been to SGMP for the Pony wars.U might ck out this tread. I don't much about GA. how close this would be by u. But they r talking about going to SGMP after there meet. They r a great group. Mr. Nasty (W) would help u out he gets his CAMARO down the strip QUICK!!!!!!!!!!!!!!!!!!!!!!!!!
http://www.camaro5.com/forums/showthread.php?t=311550
Old 08-11-2013, 02:31 PM   #31
Camarojt
Camarojt's Avatar
Drives: 2011camaro SS
U need to be at a track with other gen5's with similar mods to see how you compare on the same day with same conditions. It could be that you are blaming yourself for a track that just isn't hooking.
Come down to Texas this fall and we can make a track day. Lots of guys to compare to here and track won't be an issue.
Camarojt is offline   Reply With Quote
Old 08-11-2013, 04:48 PM   #32
jbrown13
jbrown13's Avatar
Drives: 2011 Camaro SS L99
Originally Posted by UF4LIFE102SS View Post
I have been to SGMP for the Pony wars.U might ck out this tread. I don't much about GA. how close this would be by u. But they r talking about going to SGMP after there meet. They a great group. Mr. Nasty (W) would help u out he gets his CAMARO down the strip QUICK!!!!!!!!!!!!!!!!!!!!!!!!!
I'm about 105 miles from SGMP. I looked at your link and SGMPs schedule, and it appears SGMP has a Summit Series race scheduled for that Saturday. I'm assuming the group is going to SGMP to watch, or do they have some kind of racing set up?
jbrown13 is offline   Reply With Quote
Old 08-11-2013, 05:13 PM   #33
UF4LIFE102SS
Drives: 2010 2 SS
Let me ck
Old 08-11-2013, 05:32 PM   #34
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Instead of stomping on the gas, gradually squeeze the pedal.... Like slow motion. If you dead hook next time floor it faster.
Mike from New Era made an interesting comment. Mike you mean like pulling timing in certain spots?
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 08-11-2013, 05:49 PM   #35
Fore58
Drives: 2011 L99 Camaro
If you are going around 12.1's/12.2's with a 2.0 60ft, @115 mph, then your car is fine. It may need some shift point tuning. You have at least .3 left in you 60ft alone. I have not been to the track as of yet. So, I guess I will have my own experience. Your car will definitely run 11's. I was also disappointed with my C6 M6 LS2 when I just ran 12.98@112......432rwhp/389rwtq. Just my .02.
Fore58 is offline   Reply With Quote
Old 08-11-2013, 06:32 PM   #36
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
Hey I go to SGMS a lot its a 2 hour plus trip for me also I don't have the same set up as you but was cutting 1.57 to 1.65 with nitto 20" with a 3200 stall and stock trans there and with the 4l80 on 305/45/18" MT with 3.45 gears I have cut as low as 1.51. if you want to meet there one day let me know am not a pro but hold my own at the track.
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
Old 08-11-2013, 06:38 PM   #37
UF4LIFE102SS
Drives: 2010 2 SS
Mr. Nasty can HELP!
Old 08-11-2013, 06:43 PM   #38
Mr. Nasty
Mr. Nasty's Avatar
Also just my 2 cents with the 6l and 3.91 gears you may be blowing the tire.
Old 08-11-2013, 06:59 PM   #39
Allanski
Drives: Car
more burnout
Allanski is offline   Reply With Quote
Old 08-11-2013, 09:52 PM   #40
Motion427
Drives: 2010 2SS/RS Red Jewel L99
Yes,theirs a timing table that can add or remove timing when your at WOT at pretty much any given RPM range. One a stock tune,it's active,but most tuner zero it out.
Motion427 is offline   Reply With Quote
Old 08-11-2013, 10:14 PM   #41
jbrown13
jbrown13's Avatar
I just want say again how much I appreciate all the suggestions you guys have given here. I'm going to keep plugging away, probably until I'm too old to do so.
Thanks to all.
Old 08-11-2013, 10:42 PM   #42
white ZL1
Drives: none
I would imagine you're talking about the PE/COT spark advance table?
It would probably be easier to pull timing out of the base timing map since you can base it on load and RPM.
I had to do it on my SS since I probably had too much timing there to begin with.
white ZL1 is offline   Reply With Quote
