Emblempros
Old 08-11-2013, 12:39 PM   #15
RonnieG
RonnieG's Avatar
Drives: 2013 AGM 1LE/2SS/RS
Thanks all for the replies and advice!
__________________________________________________ _________
Originally Posted by hworth18 View Post
Is this the 2013? I'd take it to your local Chevy dealer and explain the situation. You shouldn't have to take it back to the dealer you bought it from, any dealer can fix it.
I was thinking about this... however I've been doubting their abilities/willingness to do anything without me shelling out $$. I will see what they can do though when the 2014s finally get there.
Originally Posted by Sapper12b View Post
YOu have ants and i have spiders, baby spiders at that. Just crawling all over the freaking car, inside and out, leaving mini threads of webbing behind.
lol.. I get them too every now and then.. but its usually 1 or 2 small ones that I see once and then they disappear.
Originally Posted by GMTool View Post
Ants, that's just crazy. I guess living up here where it freezes is why I have never seen an ant problem in a car. I have a truck that is parked outside and the spiders like to make their webs in the wheel well area and sometimes those dang mud dauber wasps like to make nests on the engine in various places. I get the shop vac out and suck em up every once in a while.
Yep. When I was in NY this problem was unheard of. Down here I've asked some people and they give me these .. that or recommend raid or bombing.. seems fairly common though.. most of the time they tell me they've had the same issue. I sure hope I never have a wasp problem.. hate things with stingers.
Originally Posted by 05stram View Post
mix some honey with some boric acid and bait around where you believe they are originating from before getting on the car
this sounds like an idea.. I will definitely try this if the garage bomb fails
Originally Posted by MYDLIFECRISIS View Post
Summertime = little spiders leaving highways of web trails all over the car. Whether its parked in the garage or outside, it happens. Yup, I've got them too.
yep... whenever I park at my uncle's farm, I come back to see those threads =/
Originally Posted by Squillo View Post
they make little ant traps with glue on them, you could stick those in the places you think they inhabit
glue? I've tried the liquid ones that are supposed to attract them all with a delayed poison that will wipe everyone out. the videos on youtube looked promising, but didn't work for me.. so many different ant species and different baits to use its sucks.
Originally Posted by OHIOSS View Post
Set off a small bug bomb with the windows shut. When the bug bomb takes care of the ants then clean all of the surfaces that has chemicals on them. We had a spider outbreak along with a lady bug invasion both at the same time. We let off 5 bug bombs which took care of the any living bugs. There really wasn't much residue/smell from the bug bombs.
Russ
I tried this in my accord and there were still ants crawling around.. my theory is that when the fumes spread to leak outside it dilutes and isnt enough to kill the ones living in well ventilated crevices.
Originally Posted by Rhyder View Post
I would take it to a dealer and have them do a complete inspection...They love Styrofoam I know, I had some pavers separated by foam once and left it in the yard for a couple weeks before starting the project, and they had made their colony all through the whole pallet in the styrophone dividers.
What Im leading to is I dont know what they may use as deadeners or if there is something they may of riddled similar to it, but its possible you have more than just the actual infestation that needs to be corrected.....take it by a dealer, as stated, any dealer will work, to look at it, if for nothing else, if you have problems further down the road you will have it on record as being a problem.
wow. thanks for pointing that out. i really hope that's not the case. i have heard of some ants being attracted to electrical housings and when there are enough of them they can mess things up real good there.. and now there's this.. really appreciate the advice
Originally Posted by Kleeeb View Post
This just recently happened? I though you got your car awhile back...
EDIT: OH. You didn't let it bother you, but now you want them gone. GOTCHA!
heh... yeah.. it wasn't until yesterday when i saw so many of them.. they say that ones roaming around are only 5%~10% of the whole colony.. so after seeing so many, i thought i'd be time to see if i could get rid of em.
Originally Posted by derklug View Post
If you have a garage, put the car in and leave the windows down. Bug bomb the garage and the problem should be gone.
omg.. this. i don't know why i didn't think of it..
this should clear the problem right up... thanks
we have our winner!
Originally Posted by Dizzy82 View Post
Put a good spread of Ortho Home Defense or Raid barrier around and under the car to prevent any more from crawling onto the car and kill any that climb off.
yepp.. I've learned to do this round these parts =P
Originally Posted by Airmaster View Post
Florida? Yep, used to happen to my old truck and old Rav4 all the time. We had a few ant piles that would gather nearby and then find a suitable home on/in the cars. The best thing was to spray for them around the nearby lawns and areas of the condos. Get rid of them from the source. By winter they might be gone anyways, and by next summer just make sure you use some preventative ant killing products
when i used to visit florida i hated mosquitos. but i realize ants are actually the real pests... at home there are fire ants and these other small fast bright red little bastards.. good thing they stay outside though. cars safe in the garage
Originally Posted by CamaroJoe96 View Post
I had a little spider problem once, as a matter of fact, I had one bite my girlfriend's a$$ and it really burned her up They mostly like to form a web between the mirror and window on the door. Let me tell you what I did though, you take a lighter and burn the bastards (careful of the paint) and before I knew it, they were gone inside and out >
haha.. yeah that's usually my weapon of choice against spiders. eats their web and when they hang off a single strand they're done.
RonnieG is offline   Reply With Quote
Old 08-11-2013, 05:35 PM   #16
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
Terro...its made of borax ..like in the soap, and will not hurt animals if eaten yet does attract and kill ants in time....I have used it for decades.....just put some on a piece of cardboard by the car, and refill as necessary as it will harden if not depleted by lines of chowing ants.
2013 2SS/RS LS3 M6 ,CRT, NPP, Forged 428 ls3 stroker, GMPP ported heads, Katech chain, Mast windage, Cam Motion Cam, trunnion upgrade, Stainless Power headers HFC, CAI w/kit, Vmax PTD, Fluidampr25% udp, LPW diff cover, BMR strut brace,trailing arms, toes, bushings, Rocket racing wheels,Toyo Proxes 4+, elite catch can, clutch reservoir, dash/body LED, DRL rewire, Sparks billet badges, Forza 3way, tint, MRT louvers, ZL1 spoiler, MGW short throw, Monster dual LT1S clutch, bleeder, support, high vol pump, Speed hut shift light, ACC flames stripes, Driven ls30 oil, NGK TR6IX , Granatelli wires.
Old 08-12-2013, 04:29 PM   #17
RonnieG
RonnieG's Avatar
This is the liquid bait that I had actually tried. After seeing reviews and watching the videos I was amazed and, excitedly, i tried it that night. Placed on lip spoiler, behind lip spoiler by wheel well, as well as the ant trails along the roof. I had given the car a bath to rid the exterior of bug residue that might possibly distract them from the terro. Was dismayed to find they were there untouched the next morning... I went so far as to grab some and place them on the bait so they could alert their buddies.. nothing.. I chalked it up to the reads online that said different bait for different ant types...
I will be bombing the garage this weekend!
I do appreciate the tip though
Old 08-12-2013, 05:07 PM   #18
Iwantone2
Voice Of The Voiceless
Iwantone2's Avatar
Drives: CGM 1SS RS
First thing that came to mind:
Old 08-12-2013, 06:17 PM   #19
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
Are these Fire Ants and do you park your car outside (not garaged)?
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint
PalmerGA is offline   Reply With Quote
Old 08-12-2013, 06:34 PM   #20
RonnieG
RonnieG's Avatar
No, not fire ants.... thank god. At home it is in a garage free of any ants. At work, where there are a lot of ants, I park it outside.. but I make sure to spray around to keep them out of the car.. but that just made me realize some may jump on board when it rains... damn florida weather..
Old 08-12-2013, 07:23 PM   #21
slomaro3.4
slomaro3.4's Avatar
Drives: SS/RS L99 Crew
When I had my firebird in Florida the same thing happened. Do not bug bomb or use raid, it wreaks havoc on your plastics. What actually solved it for me was cinnamon, I basically made a perimeter in the door sills, trunk, and even hood area. It messes with the ant's way of navigating, its like removing all of the signs from a hiking trail and they will stop coming back.
When I had this problem, there was no food in the car and it was detailed bi-weekly, I tried all of the raid and ant killing stuff but in the end the cinnamon solved my issue. Best of luck.
#YOLO
slomaro3.4 is offline   Reply With Quote
Old 08-12-2013, 07:29 PM   #22
Blk-Ice
750HP of Twisted Reaper!
Blk-Ice's Avatar
Drives: Blk 2SS/Blk Carb Fibr NS-1 stripes
This thread makes my skin crawl...lol!
Fear the LMR Twisted Reaper Brotherhood!
Blk-Ice is offline   Reply With Quote
Old 08-12-2013, 08:42 PM   #23
jerisc
Drives: CAR
Originally Posted by RonnieG View Post
Looking for suggestions on how to get rid of ants.
Any help is appreciated.
I had that problem last year, I bought these no pest strips, cut top out of package (so that strip is exposed, but won't touch carpet) and slide under drivers seat. That handles inside problems, for outside, cinnamon works about as well as sevin dust without chemicals. Just sprinkle on your driveway.
jerisc is offline   Reply With Quote
Old 08-12-2013, 11:22 PM   #24
tom231
tom231's Avatar
Drives: 2012 2SS/RS
tom231 is offline   Reply With Quote
Old 08-13-2013, 12:29 AM   #25
Blk-Ice
Blk-Ice's Avatar
Originally Posted by tom231 View Post
Gotta try that!
Old 08-13-2013, 12:44 AM   #26
yellowrs
Drives: 2010 SS 426 V8 M/T
Here we got Black Widows and Scorpions.
Occasionally we get Rattle Snakes too.
yellowrs is offline   Reply With Quote
Old 08-13-2013, 01:02 AM   #27
IncrediblyX
Drives: Red
I've been having an ant problem at my house for a couple of weeks. Got rid of them really fast with AMDRO ant bait. Kills off the entire colony in a couple of hours. You can get it at home depot. Just wet it a little to activate it and it turns into a thick syrup and place it on top of newspaper or something. It works great. http://www.amazon.com/Amdro-4-Pack-K...amdro+ant+bait
IncrediblyX is offline   Reply With Quote
Old 08-13-2013, 01:31 AM   #28
slomaro3.4
slomaro3.4's Avatar
^^The problem is, if the colony isn't in the car itself which it most likely isn't, it has something to do with the chemicals in the carpets or something which draws the ants in, you most likely won't kill the colony, I'm dead serious about the cinnamon...
It can be messy, but fine if you're careful: http://www.ehow.com/how_2310653_get-...-cinnamon.html
#YOLO
