ADM PERFORMANCE
Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum All audio, video, bluetooth, nav, radar, and electronics discussions.
Old 11-15-2011, 12:22 PM   #851
Strider044
Strider044's Avatar
Drives: 2012 White Camaro LS 6 speed
I just sat in the dealership for 3 hours having Them install a pdim and they just told me my radio isn't comparable and they are taking it off... I'm running a 2012 ls and I'm pissed
2012 1LS -Summit White -M6 -Black out kit, ported TB, SS 20" wheels - MRT 2.0 exhaust - Hurst Shifter - K&n CAI - Hurst Equipped badging - Dynomat installed - footwell lighting - eagle eye headlights - 2lt/2ss gauge pack - custom iPad mount - dealer installed pdim - hood spears - trunk back out
Strider044 is offline   Reply With Quote
Old 11-15-2011, 12:42 PM   #852
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '10' Camaro 2LT/RS,'08' Caddy STS
OBVIOUSLY your dealer is a BONEHEAD, as you could have gotten it from the factory that way!!!
Find another dealer.
Old 11-15-2011, 03:57 PM   #853
Jonny
Jonny's Avatar
Drives: 2011 2LT RS Convertible Camaro
Well, I just had my car in the shop for the 5th time for the PDIM. I'm not really sure it's worth it any more, but GM Corporate asked me to take it in, so I did. I'm hoping that they learn something from my experience and can make some fixes in future updates that will help the masses.
I'm at DB/DD, and still have the following four issues, two of which I feel like should be fixed by now.
1) Static/popping. Mostly intermittent, but sometimes it's so constant that you can't hear anything BUT the static. The only fix for that is to unplug the device.
2) Still have the "..." lines in playlists, and sometimes it causes the entire PDIM module to crash. It used to crash the device, now it just crashes the PDIM, and the only way to "reboot" is to unplug the device.
Then there are 2 repeatable issues that I suspect everyone has, and I'm hoping they can fix them in an update if they know about them.
3) If I get or make a call on my phone, even after I tell my phone not to use the bluetooth connection to my car, my radio no longer functions until I end the call. The ONLY button/knob that works is the volume. You can't stop, go forward, backward, or use the menu button at all. This may not seem like a big deal, but if you're listening to an audiobook, it's a deal breaker. You can turn the volume down, but after the call, you have to back up to where you were, which can be a complete pain if the call was any length of time.
4) Also related to audio books, the position counter only goes up to 99:59. If you listen to audible.com audio books through a supported device, it won't count right after you get to that point. With DB/DB starting the radio up w/ a counter somewhere past 99:59 would cause the device to crash. DB/DD works better, but 1 time out of every 10 or so the book won't start at the right index.
Combining three and four creates a real PITA situation, as when the call comes in, you can't even check the counter to see where to back up to after the call is over.
3 and 4 should be fixed easily enough, as I suspect the software isn't written to handle these situations and can be. 1 and 2 are obviously causing problems for GM, and though they may be related only to Apple devices, if GM is going to say that the PDIM works w/ Apple products, then it needs to work with Apple products.
GM Corporate is very interested and calls me often asking for and giving updates. They say they'll "compensate" for the trouble once everything is fixed. We'll see...
2011 "Victory Red" Camaro 2LT Convertible RS • Custom Painted "Corvette Black" Racing Stripes • SLP Rear Quarter Gill Graphics • Painted Engine Cover • EmblemPros Underhood Bowtie • River City Creations Custom Painted Bowties • Vararam Intake • JDP V6 VMAX Ported Throttle Body • Hypertech Max Energy Programming • SubThump Large Sub Enclosure • 10" DC Sound Labs Level Four Subwoofer • Sundown SAX-1200d Amp • 2SSRS Rear View Backup Camera Kit
Jonny is offline   Reply With Quote
Old 11-15-2011, 05:52 PM   #854
Sir Nuke
Sir Nuke's Avatar
maybe they will buy you a DROID OS phone.....lol.....sorry.....I just couldn't help myself.
Old 11-16-2011, 06:40 AM   #855
Strider044
Strider044's Avatar
Anyone know a good dealer in central Florida then?
Old 11-16-2011, 07:37 AM   #856
Sir Nuke
Sir Nuke's Avatar
Try the Florida section of the forum and ask around, someone certainly has had a good experience that they would share and give you a recomendation.
and seeing as how you are in Orlando.....is must be more than one there.
Old 11-16-2011, 07:57 AM   #857
Strider044
Strider044's Avatar
Thanks sir nuke, ill check it out
Old 11-18-2011, 08:53 AM   #858
VaderSS
VaderSS's Avatar
Drives: 2010 SS/RS 6sp
GM just wants me to accept and live with song data loss and intermittent ipod connection drop. After talking to GM CS and to the dealer, they now say that part 2297219 is not even for the Camaro.
"the DD software equipped module is not meant for the Camaro as the DD software adds pause and play functionality which the Camaro radio doesn't have. If you've got the DB software that is the latest and greatest software that is meant for the Camaro at this time."
Yet another problem with no fix. Swell.
VaderSS is offline   Reply With Quote
Old 11-18-2011, 04:27 PM   #859
Jonny
Jonny's Avatar
This is what they told me as well. Then they went ahead and put in part 2297219 anyway, and though it works better, it still doesn't work well. I believe them when they say that DD isn't for the Camaro, yet it clearly works better. I guess we can only hope that they come out with at least one more software update that IS for the Camaro that resolves more of our issues.
Old 11-19-2011, 08:57 AM   #860
Sir Nuke
Sir Nuke's Avatar
well I have the DB/DD module....and mine works like a champ....the only difference between me and the people still having issues is that they all are using some sort of APPLE hardward, either an IPhone, IPod, OR IPad. I have a different phone (its an antique, lol) and as far as playing music, I use a flash drive, or fpor long trips I use me ZUNE. and ever since I did the upgrade a few months ago to DB/DD, its all operated flawlessly.
Old 11-19-2011, 09:03 AM   #861
Jonny
Jonny's Avatar
What model Zune do you have?
Old 11-19-2011, 09:07 AM   #862
Sir Nuke
Sir Nuke's Avatar
I have an older one my wife bought me about 1 1/2 years ago....its their 30 gig unit. but I just read where microsoft is about to stop or alread has stopped making the ZUNE altogether......
Old 11-26-2011, 06:30 PM   #863
Nemo13
Nemo13's Avatar
Drives: 2012 1LT
Carl Black is cool, I installed the #22872777 myself, went there with some other diagnostic thing, mentioned "Hey, my USB doesn't work?!?" And they updated my radio at no cost! Works great! I'm using a regular flash drive for all my music. They've been really cool with me there.
Nemo13 is offline   Reply With Quote
Old 11-29-2011, 12:26 PM   #864
CajunSS
CajunSS's Avatar
Drives: 2010 Camaro 2SS
from my understanding, it will only play mp3 not mpeg-4 formated songs, on itunes you can convert them to mp3, this is what I did and now all my music is listed.
Now I upgraded from an iphone to a samsung galaxy s2 android, and it's not supported
CajunSS is offline   Reply With Quote
Old 12-02-2011, 11:41 AM   #865
Bunker
Drives: 2010 RJT 2SS/RS 6M
so without reading through 35 pages... will the updates be covered under warranty in my 2010 SS?
I currently show:
HW ID: CB
SW ID: CC
I have USB indexing issues
2010 Red Jewel Tintcoat 2SS/RS 6M
-One day your life will flash before your eyes. Make sure its worth watching.
Bunker is offline   Reply With Quote
Old 12-02-2011, 12:34 PM   #866
Jonny
Jonny's Avatar
I currently show:
HW ID: CB
SW ID: CC
Yes.
Old 12-02-2011, 05:58 PM   #867
Sir Nuke
Sir Nuke's Avatar
I currently show:
HW ID: CB
SW ID: CC
not only YES, but there is a TECHNICAL SERVICE BULLITEN (TSB) about the problems and what the dealer should do.....attached is a copy of the TSB for you that you can download and print.....and TAKE IT WITH YOU. and the pard number you will need to get the LATEST AND GREATEST HW/SW version is on the top of the file.
PI0055B with GM PN#.pdf
Old 12-03-2011, 05:23 PM   #868
Lgndryhr
Camaro for Life
Lgndryhr's Avatar
Drives: 2010 2SS/RS A6 CGM & 2013 1LT A6 VR
Send a message via AIM to Lgndryhr
Originally Posted by DNA View Post
Save yourself some money on module replacement.
Amazon – AC Delco 22797218 PDIM Module Assembly, $92.08 with free shipping.
http://www.amazon.com/ACDelco-227972.../dp/B0055B0QUS
Except for available for shipping in one to two months
Build Thread
Current ride: 2010 CGM 2SS/RS A6 #128349 (his) &
2013 VR 1LT A6 #147344 (hers)
Exterior: Cyber Gray Metallic / Interior: Ebony
Nickname: Valkyrie
Best run: 13.5 stock on Pzero's with barely any tread left
How to hug your camaro
Buy the car that you would most like to get beat in. The other guy will always be faster.
Lgndryhr is offline   Reply With Quote
Old 12-09-2011, 03:14 PM   #869
LiveStrong
LiveStrong's Avatar
Drives: 2012 Transformers Edition - 2SS/M6
All,
I'm experiencing the same popping and crackling with my radio. However, mine is a 2012, just built in October. I would think my radio would have the latest hardware/software updates to date. To include the above mentioned TSB.
Now the funning thing is, I hear the popping and crackling with my iPhone and while listening to XM. Not sure if it does it on the FM/AM since I never listen to regular stations. Could this issues actually have something to do with the AMP instead?
LiveStrong is offline   Reply With Quote
Old 12-09-2011, 03:23 PM   #870
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
Originally Posted by LiveStrong View Post
All,
What version PDIM hardware/software does your car have?
Old 12-09-2011, 03:30 PM   #871
LiveStrong
LiveStrong's Avatar
DB
DB
Old 12-10-2011, 08:52 PM   #872
Sir Nuke
Sir Nuke's Avatar
the real problem is the fact that you are using a APPLE product.....whethger its a IPhone, IPod, or IPad.......the ONLY products that are having this problem regardless of which HW/SW version you have are APPLE products.
if you go back and read post after post and the only people that have this issue are folks which are using those products.
Old 12-10-2011, 08:56 PM   #873
LiveStrong
LiveStrong's Avatar
the real problem is the fact that you are using a APPLE product.....whethger its a IPhone, IPod, or IPad.......the ONLY products that are having this problem regardless of which HW/SW version you have are APPLE.
I'm having the issue listening to XM as well as music through my iPhone. Any chance it might be the amp?
Old 12-11-2011, 09:56 AM   #874
Sir Nuke
Sir Nuke's Avatar
well thats a new one......as far as I know.
Old 12-11-2011, 03:37 PM   #875
FNG
...the effin' new guy.
FNG's Avatar
Drives: '11 2LT/RS
I have DB / DB and I constantly have indexing issues. The pop/static problem is intermittent and impossible for me to reproduce at the dealership.... the track names and playlists being displayed as "..." happens constantly.
I found that it doesn't matter if I use my Zune or new iPod Touch; the static/pop/index issues are there. Index / track name issues are less of a problem if I keep my devices less than half full... which sucks.
FNG is offline   Reply With Quote
Details about PDIM & Bluetooth functionality & upgrading your non C&C car with them Matt'sSS Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 54 12-14-2010 10:41 PM
USB port intermittent... shall we compile a list of PDIM failures? JDBeck23 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 49 09-01-2009 01:57 AM
Potential Huge Problem.... 2010 Camaro Nose Cracks (UPDATE: NOT A PROBLEM AT ALL!) Nine Ball 5th Gen Camaro SS LS LT General Discussions 328 05-03-2009 08:55 PM
