| Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum All audio, video, bluetooth, nav, radar, and electronics discussions. |
Thread Tools |
#901 |
![]() Drives: 2012 Transformers Edition - 2SS/M6 Join Date: May 2010
FYI....
I was having the same issue with cracking/popping while listening to music from my iPhone via the USB connection. I have a 2012 SS and the radio software/hardware was already at DB/DB. So I got to thinking. I had been using a Belkin cable, made for the iPhone, for plugging my iPhone into the USB port in the car. Everthing worked fine, except the music would crakle/pop. So I thought I would try the Apple cable that came with the phone and use it in the car. Guess what? All of the crackling/popping is gone. It sounds great. So, in the end, it could just be that the Camaro's PDIM only works correctly with the Apple supplied cable that comes with the iPhone. Just my observation and .02.
#902 |
US Veteran
Drives: 2011 Silver Ice Metallic 2SS/RS A6 Join Date: Jan 2011
Can someone update the O.P. with the latest and greatest information(service #, software/hardware versions, etc)? Standard practice on most informational forums!
Thanks! Sent from my iPhone using Tapatalk
Dear Lord, give me the strength to carry on despite my Camaro addiction!
#903 |
Master of All Things
Drives: '10' Camaro 2LT/RS,'08' Caddy STS Join Date: Jul 2009
OR you send a PM to the OP and ask him to do it.
#904 |
Born 9/29/2011
Drives: 45th Edition 2LT RS Join Date: Dec 2011
Well, bummer, my blue tooth intermittent non-connect issue is back. Not all the time, but some is still a hassle. Yeah, I can hit "discoverable" on my phone but I feel like I really shouldn't have to...
#905 |
More Human Than Human
Drives: 2011 1LT IOM M6 Join Date: Feb 2011
My iPhone 4 had really poor sound quality through bluetooth. I just picked up a Samsung Infuse (Android) and the bluetooth sound quality is EXCELLENT. I haven't had any disconnect issues with either phone.
#906 |
![]() Drives: 2012 White Camaro LS 6 speed Join Date: Oct 2011
So I got the pdim, and it worked great for like 40 miles. Now the aux and USB seem to be cutting out on my passenger sider randomly and then coming back on... Any ideas?!
2012 1LS -Summit White -M6 -Black out kit, ported TB, SS 20" wheels - MRT 2.0 exhaust - Hurst Shifter - K&n CAI - Hurst Equipped badging - Dynomat installed - footwell lighting - eagle eye headlights - 2lt/2ss gauge pack - custom iPad mount - dealer installed pdim - hood spears - trunk back out
#907 |
SoCal Mayhem
Drives: 2010 Camaro 1SS/RS Join Date: Aug 2008
What version hardware/software is the PDIM? While in USB mode, press and hold the MENU button on the radio till the versions display on the radio LCD.
#908 |
i have the DB/DB, im now getting no sound at all
#909 |
I have DB/DB and have sound pop/crackle intermittently when using the iPhone 4 via USB. Brought into dealer and they couldn't replicate. Is there a DIY way to update the S/W on your PDIM, it seems that the dealer will not do it unless they can see the issue. I think DD is the new one right?
DJ RFBT: House/Techno
2012 Camaro 2SS/RS: Black on Black, Hurst [AAC DRL LED's, AAC LED's for trunk, cabin, license plate, CAI Intake, RX Catch Can, Skip shift eliminator, Pedders Sub-Frame Inserts, Pedders Radius Rod Inserts, Pedders Rack & Pinion Bushing, 1LE front and rear sway bars] |
#910 |
SoCal Mayhem
Unfortunately there isn't :(
#911 |
![]() ![]() Drives: 2010 Camaro 1LT, IBM Join Date: Oct 2009
If I'm streaming Bluetooth music from my tablet and charging my Android phone via the USB port in the console, it frequently switches to No Device Found and then kicks back to the last source. This is even with the phone set to Charge Only. When I disconnect the phone, it's fine.
Anyone else seeing anything like this? My PDIM is up to DB/DD, IIRC. |
#912 |
The delaer replaced the PDIM today in my 2011 Camaro. It now shows DB/DB. Is this the most up-to-date module/software? It still takes forever to index and repeats the process every time the ignition is switched off/on. I've tried using my Android phone and a USB memory stick. It still has to re-index every time even if I leave the flash drive in the port.
#913 |
SoCal Mayhem
I believe that's how it works since in order for it to tell if there are new audio files on the drive it has to re-index. The only exceptions are iPods/iPhones as they do the indexing themselves.
#914 | |
in case you don't have it, here is the TSB about this problem, and the part number is on the top. PI0055B with GM PN#.pdf I leave my flash drive in the port all the time, when I turn off the car, when i turn on the car, it starts to play as soon as the car starts. but the drive reindex's a small protion and only takes about 30 seconds.
#915 | |
![]() Drives: 2011 Victory Red Auto 2SS Join Date: Aug 2010
For me, it Took SEVERAL trips to the dealer to get it right. Even took 2 after I showed the dealer service tech and service rep th PI. Even then I took me complaining to the owner/manager to get it resolved. |
#916 | |
![]() Drives: 2012 Camaro Convertible 2SS RS M6 Join Date: Mar 2012
Ed 2012 2SS RS M6 'Vert
#917 |
Keeper of the Faith
Drives: 2001 Z28 Agressively Join Date: Apr 2008
Would be nice if these updates could just be downloaded through Onstar.
2010 Camaro SS R6P 2001 Camaro Z28 1969 Camaro SS clone ![]() |
#918 | |
Dan, you can either download the TSB from the link I put up above or in nothing else, I have some printed oun in the trunk of my car, you can get one from me next time we see each other.
#919 |
It bean 9 days
that my dealer try to fixe my USB module they try to reprogramm it does'nt work, they change the module does'nt work KNOW they are changing all the radio system, they will do it tomorrow... Hope that will work (the problem with it that it does'nt read nothing) Only my CD and radio work's More news tomorrow if i can have my car back
#920 | |
#921 |
That is if the dealer actually tell you......let us know what the final out come is as far as what they ended up finding what the problem was.
#922 | |
Got my music know thanks (and thank's to camarorick too because his the one who told me this thread
#923 |
Congrats!
#924 |
my garranty finish in july
so it's for sure that i will extend it just in case that apen againand before it's stop working, everytime that i wanted to put my MP3 i was alway took it out and plug it in again and know just press on the selection (2 times) on my wheel and do not have to take the MP3 out.....
#925 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2LT Cyber Gray Join Date: Oct 2011
Great info!!
No longer owned: 1993 Camaro Z-28 |
| Thread Tools | |
| Details about PDIM & Bluetooth functionality & upgrading your non C&C car with them | Matt'sSS | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 54 | 12-14-2010 10:41 PM |
| USB port intermittent... shall we compile a list of PDIM failures? | JDBeck23 | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 49 | 09-01-2009 01:57 AM |
| Potential Huge Problem.... 2010 Camaro Nose Cracks (UPDATE: NOT A PROBLEM AT ALL!) | Nine Ball | 5th Gen Camaro SS LS LT General Discussions | 328 | 05-03-2009 08:55 PM |
