Old 08-12-2013, 02:08 PM   #1
BOSS_HOSS
BOSS_HOSS's Avatar
Drives: 2010 Camaro SS
Lowering spring install help
I have the OEM strut (front) out of the car with the spring removed. I have the Eibach spring in placed properly seated. I hand started the upper spring perch retaining nut...
This is where I run into problems. I know the proper torque spec here should be 52 ft/lb or Pfadt says 65 ft/lb.
Getting to that spec is a different story since the assembly obviously spins as you try to torque it down. If you use the T50 torx bit to prevent it from spinning you obviously aren't getting any torque wrench in there.
Am I missing something here? In all the instructions it just states to simply torque the nut down to 52 or 65 ft/lb. I feel this is a critical spec because if you tightened too much you pre-load the spring and not enough it would be too loose.
Any help would be appreciated...
2010 2SS/RS 1 7/8" Long Tube American Racing Headers w/high flow cats, Borla S-Type Catback Exhaust, Roto-Fab CAI, VMAX Ported Throttle Body, MGW Shifter, JRE 445 Street Cam Package tuned via SCT, Pedders Street 1 Kit.
BOSS_HOSS is offline   Reply With Quote
Old 08-12-2013, 05:18 PM   #2
BOSS_HOSS
BOSS_HOSS's Avatar
Anyone?!
Old 08-12-2013, 05:40 PM   #3
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
Get a wrench and torx on it a use the elbow torque. It hits a stop and does not keep going the more you tighten it. The 52 to 65 ft pounds is just snugging the nut, it is not a preload or anything.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 08-12-2013, 06:33 PM   #4
Bmags
Bmags's Avatar
Drives: 2013 Camaro 2SS/RS SIM
put the torx socket on the torque wrench, set the torque wrench to reverse, pull on the Hand wrench while holding the torque wrench. When it clicks you are at the torque spec.
Bmags is offline   Reply With Quote
Old 08-12-2013, 06:56 PM   #5
BOSS_HOSS
BOSS_HOSS's Avatar
Awesome...thanks guys.
Old 08-13-2013, 03:26 PM   #6
Cammarrah
Camaro Racing Specialist
Drives: 2010 Yellah 2SS
+1
Nice suggestion.
Cammarrah is offline   Reply With Quote
