Emblempros
Old 07-07-2009, 04:30 PM   #1
hd48
hd48's Avatar
Drives: SS2 Rally Yellow Lt Grey Leath
Cool Shifting procedure A6 SS2
Icant figure out how to use this trannythe book is a joke I am trying to get it in first to start with is it only possible when using paddles, Im lost i thought after reading this forum info for 5months while waiting for the car but im stumped. Any bodty with any info please let me know or where i can find the info either or. thabnks hd48 Rob S.W. Florida
hd48 is offline   Reply With Quote
Old 07-07-2009, 04:33 PM   #2
6 Shooter
Six Speed Freak
6 Shooter's Avatar
Drives: 2000 LS6 Millennium Yellow Roadster
DUDE - Drive it like you stole it!
Later . . . . . .
6 Shooter
6 Shooter is offline   Reply With Quote
Old 07-07-2009, 04:49 PM   #3
toehead93
Drives: 2014 2SS/1LE
If it is in the shifter is in D it will start in first gear from a stop.
If it is in the shifter is in M (S displayed on DIC) it will start in first gear from a stop.
If it is in the shifter is in M (M displayed on DIC) it will start in first gear from a stop only when you down shift to 1st, otherwise it starts in 2nd.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 07-07-2009, 04:54 PM   #4
BLT4SPD
BLT4SPD's Avatar
Drives: 2010 SS, 2011 Z71, 1980 Camaro
What kind on info you won't
Tranny in M paddle shift to first is the only way to start in first gear.If you are going to make a quater mile run start like that,but after you get rolling shift to D,and just let the trans. shift it self,using the paddle shift runnig hard the Torque Management lets it fall on it's face
BLT4SPD is offline   Reply With Quote
Old 07-07-2009, 06:17 PM   #5
SubSolar
SubSolar's Avatar
Drives: 2009 Corvette, 1987 Buick GN
What the, so you need to switch from M to D in the middle of a quarter mile pass for the best possible time? This seems complicated.
SubSolar is offline   Reply With Quote
Old 07-07-2009, 06:37 PM   #6
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
If your drag racing leave it in D or use M (Sport mode -without touching the paddle shifters). You'll go slower using the paddle shifters (trust me).
There's a slight delay on the shifts when using the paddle shifters and it can be hard to get the shifts just right. The computer does a much much better job of shifting.
The paddle shifters are fun to play with. You can up shift and down shift and have some fun. But the car is faster when the computer does the shifting.
Old 07-07-2009, 06:40 PM   #7
mike@newera
mike@newera's Avatar
Drives: 2016 Camaro SS
D (Drive) and S (Sport) both start off in first gear. No, you don't have to switch things around racing the 1/4 mile, just put it into drive or sport and run it.
See my 1/4 mile testing I have done so far with my L99 SS here:
http://www.camaro5.com/forums/showthread.php?t=26818
Now, if you are driving around in M (Manual mode) and using the buttons (paddles) on the back of the steering wheel to shift manually, and you come to a stop, the transmission will automatically downshift for you as you decel, but it will never downshift into first gear, so even once you come to a stop, you will then still be in second gear and it will remain in second, until you manually shift it.
mike@newera is offline   Reply With Quote
Old 07-07-2009, 06:40 PM   #8
SGOS252382
SGOS252382's Avatar
No, he's just saying you could if you wanted. I wouldn't recommend it. It's bound to just screw up your run and slow you down.
Do what I suggested. Just put it in D (regular drive) or M (regular sport mode) and turn off the traction control. Then just mash the gas. I wouldn't use M (manual mode using paddle shifters) when drag racing.
Old 07-07-2009, 06:48 PM   #9
hd48
hd48's Avatar
Cool A6 Shifting
Hey thanks everbody but sw florida you are the one im going with because i heard this before on this forum but couldnt remember exactly what thanks for the jog in my memorie. hd48
Old 07-07-2009, 06:58 PM   #10
SubSolar
SubSolar's Avatar
Is there a consensus on which is the fastest? Seems like there are so many combinations, some say put it in D, some say M, some say hit the traction control button twice, some say hold it in for 6 seconds. I have a pea brain, I want someone to just tell me to put it in this mode and do this with the traction control button when I go to the dragstrip.
Old 07-07-2009, 07:37 PM   #11
hd48
hd48's Avatar
Cool Shifting
I agree whats the deal with the traction control button hold it down, push it once , push it twice is it once in one mode and another in a different mode good question Corona ,CA
Old 07-07-2009, 08:46 PM   #12
LSX-80MM
Ghostly Unknown
LSX-80MM's Avatar
Drives: Silver Ice 2010 SS/RS A6
Leave it in drive,push button once to turn off traction control,and then press it again for 7 sec to disable stabilitrac,And then bring it up to bout 1200 - 1500,and then mate the hell out of it.............you WILL LIKE
TS416,GMPPLSX-LS3 6 Bolt Heads,Custom 80mmComp Turbo,ID850 Injectors, Lonnies Twin Pump Setup,Level 3 4L80E,DSS,3in Magnaflow Exhaust,CoolingMist Meth,RX Dual Catch Can,InnovateWB,Aeroforce Interceptor,AEM Truboost Controller,matte black CF5 Forgestars.700rwhp/712rwtrq
LSX-80MM is offline   Reply With Quote
RJM 2010 SS2 no status change FYRFTR02 Camaro Price | Ordering | Tracking | Dealers Discussions 2 06-05-2009 09:28 AM
L99 / Auto First Gear procedure? mcernik V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 0 05-13-2009 07:42 PM
No Lift Shifting on Camaros?? 02bluess 5th Gen Camaro SS LS LT General Discussions 15 02-27-2009 12:38 PM
Shifting Problem? TonytheTiger 5th Gen Camaro SS LS LT General Discussions 13 12-10-2008 08:46 AM
SS2 RS Package....quick ? JameSS Cosmetics and Lighting Modification Discussions 6 10-18-2008 10:53 AM
