Jason 98 TA
Old 08-13-2013, 09:06 AM   #1
SixGracing
SixGracing's Avatar
Drives: 2010 2SS/RS LS3 A6
Arrow The Perfect Nitrous Kit! Everything you need!
***UPDATED*** Changed some information on the controller and timing retard sections after some much appreciated feedback.
After much research, and some N2O/Nitrous verbage corrections, I have found and settled on a kit for my already modded and fast 2010 2SS/RS. Here's what I'm going with and if anyone is looking for the ultimate kit, I think this is a good start. Maybe I can save you the research time I had to endure by posting this. Plus I'll spell out what everything does. The learning curve was slight but this should save anyone interested in Nitrous a lot of footwork or mouse clicks.
There are several good Nitrous companies on the market, i.e. Nitrous Outlet, ZEX, Nitrous Express, NOS, etc. I went with Nitrous Outlet as they were the only ones to reply to my requests for quotes and info (No disrespect), and I know of a couple kits installed already that are bad to the bone!!
First the Kit. Nitrous Outlet makes a plate kit for the 2010+ Camaro SS in 90mm TB size (bigger if you have an aftermarket manifold). You need to specify what bottle size you want. I went with the 10 lb. bottle. The plates kits are nice as they mount between your manifold and your Throttle Body and have more consistent spray and atomization. This is the base kit you will need to get started but not the only thing you will need. That is if you want to do it right, and keep the system somewhat self sufficient and safe.
Name:  Nitrous Plate Kit.jpg
You will need some nitrous goodies to make the system NHRA compliant if you race, plus safer as it provides everything you need in one kit. The Nitrous Outlet Stage III accessory Kit. You can buy the Stage II or I as well but I wanted the extra stuff i.e. the in line filter and purge valve. Plus it gives you a bottle heater and mount (the heater keeps your nitrous pressure up when your bottle starts to empty) which mounts on a plate to the inside edge of your trunk using factory studs. Nice and easy. A blow down tube and fuel pressure safety switch. I wouldn't do this any other way. All of these components will help you keep your system monitored and safe.
Name:  Stage III Kit.jpeg
To get rid of the fuel pressure headache and having to install a higher output fuel pump or BAP I decided it would be much easier (although more costly) to go with a dedicated fuel system. This way the fuel system is totally independent of the cars fuel system. It provides the proper amount of constant fuel pressure and can be filled with C16 race gas giving you an excellent wet shot of fuel and nitrous. After talking to some performance shops and doing a lot of reading, this is the way to go. The Fuel system runs about $900, but well worth the time and ease without having to drop your fuel tank, install a different pump and reassemble. Only a couple hundred dollars more in the long run and well worth it.
You'll want to change your plugs too if you are using more than a 50-75 shot of nitrous. I am going for the 150 shot first and see how the car responds so I will need to drop my plugs 2 steps colder. Nitrous Outlet sells a couple choices. I am going with the NGK BRE7F plugs.
Now the brain of this madness. You will need a controller to make all of this craziness work smoothly with your car. NOS makes a mini 2-stage controller that is popular and easy to work with. LPE makes a unit called the LNC2000. This awesome little device does a couple things. It's both a launch controller and it pulls timing. Since I'm using the NOS unit for the launch control, I am utilizing the LNC2000 by Lingenfelter to pull timing. You can use one of the two accessory outputs of the NOS controller to trigger or activate the LNC2000. So the two units will work well together. The reason I opted out of using the LNC2000 Launch control portion is because this particular feature will kill spark and can cause a build up of fuel in the exhaust or cats which can damage or completely ruin them. I still have high flow cats on my car so I went with the NOS controller for launching. This NOS controller lets you choose at what RPM the nitrous comes on and when it should shut off to avoid spraying while hitting your rev limiter. Even cooler is it will allow you to ramp the nitrous up if you want instead of a full on at the desired RPM level. Basically an RPM sensing, on/off controller. Plus it connects to your TPS (Throttle Position Sensor) so it knows to activate fully when you are at WOT. Very cool little unit. Even though the system I am installing has one stage, this controller has two stages if you ever want to upgrade and two remote outputs one of which I'll be using to activate the LNC2000 timing retard feature.
Name:  NOS Controller mini.jpg
So while utilizing nitrous you need a way to pull timing when the system is engaged or "armed". Sullivan inc has a "Black Box", where you can control the timing. They set these up to hold your NA and N2O tunes. Just load the tune, check bottle pressure and you're off. Sam at Sullivan posted below and you can see his information there if you are interested in going this route.
Another very cool feature which I would not go without is a remote bottle opener. This way you can open and close your nitrous bottle from inside the car. It wouldn't be cool to have to pop your trunk each time, turn the bottle on, close the trunk and get back in every time you want Nitrous. I mean, you can do it this way. It would be cheaper. But I'm spending the $200 bucks and getting the remote opener. I went with the NOS opener because I got it for a low $135 also on Amazon. Waaay cheap considering. It's normally a $220 opener.
Name:  bottle opener.jpg
Last but not least, the switch panel that controls it all from the comfort of the cockpit. Nitrous Outlet makes a really cool switch panel in two styles. One that mounts in one of your cup holders, or one that mounts in your center console compartment. I chose the latter because it's hidden this way. And when this kit is installed, short of opening the trunk to expose the bottle, the rest of the kit is pretty much entirely hidden. Very cool. So here's the switch panel that give you the arm switch to activate the system, the Purge button that blows the air and gas out of the nitrous line for instant hit off the line, bettering your 60' times if you're drag racing, the switch to turn on the bottle warmer if your pressure starts dropping, and lastly the handy little button that opens your nitrous bottle remotely. Very cool eh? I might mention that there are some other products out there that are excellent for keeping your bottle pressure consistent. The Nano system is excellent but around $500. It's a separate bottle that hooks to your nitrous bottle, keeping the pressure regulated and consistent. I'm doing the heater option for now but will probably upgrade later.
Name:  Switch panel.jpg
So there you have it! A complete, awesome system that will make even a stock Camaro hell on wheels. The 150 shot jetting will put a stock manual in the mid to high 500 HP at the wheels range. The torque numbers are off the charts with Nitrous as well. My car should be running over 600 HP when this system is installed since I already have several engine and exhaust upgrades.
Hope this helps the noobs like I was. You might have more questions and feel free to post. If I don't know the answer there are several guys that will more than likely chime in and help you out. Also, don't forget to get your car professionally tuned. You don't wan to buy all of this stuff and end up blowing your car up. Here's the best part. Everything above I'll be about $2500 out of pocket not counting the tune. Pretty extraordinary since it would cost me well over $10K to supercharge my car. Best bang for the buck for sure!
Enjoy!!
PS- Sam at Sullivan GM Performance in Las Vegas was a huge help in explaining some of this stuff. If you need anything in the GM performance arena and can get to him, DO NOT hesitate. He's a magnificent tuner and he knows his stuff on these GM platforms. He built my car and it has been flawless for over a year now.
SixGracing is offline   Reply With Quote
Old 08-13-2013, 09:39 AM   #2
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
Very Nice write-up!!! As a "newb" to nitrous, I'm sure I'll use some of this information in the future.
Thanks!
blazzin1 is offline   Reply With Quote
Old 08-13-2013, 10:15 AM   #3
SixGracing
SixGracing's Avatar
Thanks!
You're welcome.
Old 08-13-2013, 02:43 PM   #4
SNSSTR
All About That Speed
SNSSTR's Avatar
Drives: 2010 Camaro 2SS/RS
Thanks a bunch for the list of stuff!
How are you going to be adjusting your timing for the nitrous?
2010 SS M6 | 416 CI | H/C/I | GPI TUNED | SNSSTR
SNSSTR is offline   Reply With Quote
Old 08-13-2013, 04:01 PM   #5
Ryan@Lingenfelter
Ryan@Lingenfelter's Avatar
Drives: 1998 Camaro Z28
Originally Posted by SixGracing View Post
Now the brain of this madness. You will need a controller to make all of this craziness work smoothly with your car. NOS makes a mini 2-stage controller that is popular and easy to work with. LPE makes a couple nice ones too but you have to be careful with them because they kill spark when operated and cause raw fuel to collect in your exhaust which can damage or ruin your Cats.
I think you are referring to our launch controller (LNC-2000). The launch control will cut spark and could cause raw fuel to accumulate in the exhaust. Please do not confuse this with our nitrous controller (NCC-002).
Also, you could use the LNC-2000 to pull timing only (not utilize the launch control function)
Ryan@Lingenfelter is offline   Reply With Quote
Old 08-13-2013, 04:53 PM   #6
SixGracing
SixGracing's Avatar
No disrespect Ryan. Yeah I was referring to the LNC2000 for pulling timing and cutting spark. I didn't elaborate much in this paragraph about your products and maybe should have. Also, I should have stated that without cats this system wouldn't be an issue. I wish I didn't have cats because I really like the fact that the LNC interfaces between the ECU and pulls timing when it senses WOT. Right now I am just going to tune for the timing change that is needed, but need to find a way to have either two quickly selectable tunes, or a unit like the LPE. I have HP Tuners to load the tunes but I want something a little easier to load.
Old 08-13-2013, 04:56 PM   #7
Sullivan
Sullivan's Avatar
Drives: powerful
You can control the timing using a "Black Box." We set these up to hold your NA and N2O tunes. Just load the tune, check bottle pressure, and spray that girl!!
http://www.camaro5.com/forums/image.php?type=sigpic&userid=63046&dateline=137469  5581
Sullivan is offline   Reply With Quote
Old 08-13-2013, 04:59 PM   #8
SixGracing
SixGracing's Avatar
See the couple of posts above. I'm still deciding on a long term method. Right now I'm just going to have two tunes. The regular tune I'm running now and a tune for the Nitrous that I'll load for racing when I'm using the system.
Old 08-13-2013, 05:01 PM   #9
Ryan@Lingenfelter
You can use the LNC-2000 to pull your timing safely. Just do not utilize the launch control feature as that is the part that would damage the cats.
Old 08-13-2013, 05:07 PM   #10
SixGracing
SixGracing's Avatar
Read my mind! I emailed so disregard that. Perfect, so yeah, here you go. The black box. Will hold both tunes and is selectable on the fly.
Thanks Sam.
Old 08-13-2013, 05:09 PM   #11
SixGracing
SixGracing's Avatar
I see. Cool, thanks for the info.
Old 08-13-2013, 05:21 PM   #12
striker1703
striker
striker1703's Avatar
Sent you a Pm for more information
striker1703 is offline   Reply With Quote
Old 08-15-2013, 08:08 AM   #13
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: '15STI,'10Expy,'10 2SS/RS M6,'47KB1
Why not use the LNC2000 to pull timing without using the launch control feature? How convenient is it to switch tunes with the black box? Loading tunes with an SCT tuner takes some time, so might be a pita. Also, rev limiter cuts fuel on stock tune, not sure about black box tune. Make sure spray cutoff is below rev limiter. Fuel cut with nitrous spraying would be bad, even with a wet plate. LNC2000 has a rev limiter, if not using the launch contol, that cuts spark.
Nitrous Outlet Plate (progressive, fuel hose upgrade, remote opener, heater, filter, console switches), LNC2000, ARH 1 7/8" LTs/gutted cats/X pipe/mufflers, Jet Hot coated LTs, JRE SCT Tune, CAI, Scoop, Rx Catch Can, Gates heater hose relocation, Remote clutch & auto brake res, Metco loop, Momentum Tunnel Brace, TSW Nurb 18" 555 & 555R, Pfadt trailing arms & toe rods, Autometer wideband, Fesler Pillar Pod, LED strips (int), Lloyds floor & trunk mats, LED DRL/front turn & license plate, DRL harness, VLEDs tail lights, Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17 @ 112.6 stock
Badbubba is offline   Reply With Quote
Old 08-15-2013, 08:21 AM   #14
SixGracing
SixGracing's Avatar
Agreed! I actually just over an hour ago emailed Nitrous Outlet and LPE to see if I could use their LNC2000 with the NOS mini progressive controller. Even though the black box is a solution, I was struggling with the same dilemma. Having to load a tune, like you said isn't exactly a quick process. I have HP tuners and dragging out the laptop, hooking up the OBD plug, waiting for it to read, then load, etc. Cumbersome if I'm going to be switching frequently. The LNC2000 deals with that problem. I can't use the launch control on it because I still have cats but I definitely want that built in timing retard. Especially since it interfaces between the cars ECU and is automated after it's set up.
I planned on setting the Controller to engage nitrous at about 3000 RPM, not sure yet if I want it to come full on at that point or ramp. I guess playing with it at the track will help. Also was going to set the cutoff at about 200 RPM below the rev limiter for safety. Where I'll be running a dedicated fuel cell, I shouldn't have any issues with fuel pressure and/or nitrous spraying when it's not wanted if the controller is configured properly. I just want to get it set up, tuned and I'm assuming that the LNC2000 arms when the nitrous system does and is dormant when the system is off?
I'm hoping to do a full on picture tutorial of the install when I get all of the components. Some are on their way and I have a couple more to order still. Brandon at Nitrous Outlet has been great to work with, responds quickly, and that's what I'm looking for in these new horizons.. Customer service! Thank you.
Thanks for the info
