JUICEDMOTORSPORTS
Old 08-13-2013, 02:18 PM   #1
2010camarolt
2010camarolt's Avatar
Drives: Victory Red 1LT
Question upgrading v6 rotors question
I have no idea if this is possible but i figured id ask. Is it possible to put v8 rotors on a v6? I know its not a direct swap so what would i need or would it be too much hassle it wouldn't be worth it? Reason behind this idea is i like to look of the bigger drilled and slotted rotors on the SS. I saw the v6 drilled and slotted rotors at the fest and they just looked so much smaller. Its mainly for looks, dont track my car too often so i dont want to upgrade to brembos to do it. If its not possible ill stick with the v6 rotors.
Any help would be appreciated!
2010camarolt is offline   Reply With Quote
Old 08-13-2013, 02:25 PM   #2
Synner
Drives: not stock
You must upgrade caliper, rotor, and lines to the SS Brembos. All or nothing.
Old 08-13-2013, 02:30 PM   #3
2010camarolt
was hoping that wasn't the case but thanks!
Old 08-13-2013, 02:30 PM   #4
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
Yup this is the only way of doing it. Honestly I just went with V6 rotors
Proud owner of litho #179 Click Picture for Build Thread
Old 08-13-2013, 07:46 PM   #5
2010camarolt
yea i guess thats the way i have to go. this is a bummer!
Old 08-14-2013, 06:14 PM   #6
ryanyoung1768
Drives: 2013 Camaro 2LS
Any idea how much it'd cost to upgrade to the Brembos?
2013 2LS
T-Rex billet grille, CAI intake, Magnaflow mufflers, VMax ported throttle body, Elite Engineering catch can.
ryanyoung1768 is offline   Reply With Quote
Old 08-14-2013, 06:21 PM   #7
ryanyoung1768
I found the answer on the JDP site:
http://www.jdpmotorsports.com/manufa...vrolet?cat=532
A little more than I want to spend right now... but cool.
2013 2LS
Old 08-14-2013, 06:33 PM   #8
RS111341
RS111341's Avatar
Drives: 2011 SS IOM auto
Look for take-off sets...I was able to do my swap for less than a grand
RS111341 is offline   Reply With Quote
Old 08-14-2013, 06:45 PM   #9
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Try to find someone upgrading to our CTS-V kit and buy their stock stuff. You will end up with a lot nicer setup than you have now and it makes the upgrade a lot cheaper on the both of you!
Best regards,
Tyler
888-308-6007
Old 08-18-2013, 03:07 PM   #10
CamaroLS
CamaroLS's Avatar
Drives: 2014 Blue Ray Met. Camaro 1SS Vert
I have a question to. I am looking to upgrade to the Brembo brakes and see different pictures that show some with rollers and some without. Also I see some calipers with weights on them. So what is the difference and when I install the system do I have to or how would I get them balanced if that is what the weights are for?
CamaroLS is offline   Reply With Quote
Old 08-18-2013, 03:19 PM   #11
Synner
Drives: not stock
They were some of the idiotic methods GM attempted to deal with squealing complaints. None are necessary but neither will they hurt anything if you get a set that has them. Calipers do not get balanced, they don't spin.
Old 08-18-2013, 03:29 PM   #12
CamaroLS
CamaroLS's Avatar
Ok. Thanks for the info!!!
